Hi
I spotted some oil marks under my car when it is parked and i figured out that they were coming from the auto gear box.
could you recommend a guy to get this repair
if I repair this at a garage how can i pump in ATF if the remaining ATF has to be disposed?
Pls advise
thanks
Mike
Edited by maikk99
5 answers to this question
Hi
Pls advise
thanks
Mike
what's the make and model of your car ?
might just be a few simple loose nuts on the sump, with a little oil leaking from the packing. Wouldn't hurt to jack up the car and check for it and tighten it yourself rather than take it to a mechanic to get the same reason and remody :)
Hi
Pls advise
thanks
Mike
Hi Mate.....
first confirm it's the auto gear box oil- One small bit of advise - DO NOT TAKE the car to the way side Garage jokers as I've burnt my hands ( Well my mother) we too had a similar problem and he told that he needed to check the box, which ended out dismantling it..... after that there was a slight jerk when the car changes gears......
Take it to the agents - in my case it was A*W and apparently it was a packing leak.....
All the best
