Imesh Umayanga Posted March 12 Share Posted March 12 Hi all, The title sums it up. There is a clicking noise when RPM drops below 1000. Goes away when AC is turned off. I have attached a video with the noise. Anybody with a similar experience? My milage is <100,000. Thanks in advance! https://streamable.com/ubmq3n Quote Link to comment Share on other sites More sharing options...
0 Hyaenidae Posted March 12 Share Posted March 12 Is the AC blowing cold air? Sounds like the AC clutch or the compressor itself is going out. Quote Link to comment Share on other sites More sharing options...
0 Imesh Umayanga Posted March 12 Author Share Posted March 12 On 3/12/2025 at 7:24 AM, Hyaenidae said: Is the AC blowing cold air? Sounds like the AC clutch or the compressor itself is going out. Expand Yes. No problem with cooling. And this doesn't start straightaway after a cold start. Takes some time. Quote Link to comment Share on other sites More sharing options...
0 Hyaenidae Posted March 12 Share Posted March 12 On 3/12/2025 at 7:32 AM, Imesh Umayanga said: Yes. No problem with cooling. And this doesn't start straightaway after a cold start. Takes some time. Expand See whether the noise is from the AC compressor - here's how Quote Link to comment Share on other sites More sharing options...
0 Imesh Umayanga Posted March 12 Author Share Posted March 12 On 3/12/2025 at 8:08 AM, Hyaenidae said: See whether the noise is from the AC compressor - here's how Expand Thanks mate! Quote Link to comment Share on other sites More sharing options...
0 john cooper Posted March 13 Share Posted March 13 What happens if you keep the reves above 1000 RPM, Are any changes to the noise? Quote Link to comment Share on other sites More sharing options...
0 Imesh Umayanga Posted March 13 Author Share Posted March 13 On 3/13/2025 at 12:19 AM, john cooper said: What happens if you keep the reves above 1000 RPM, Are any changes to the noise? Expand No noise above 1000 RPM Quote Link to comment Share on other sites More sharing options...
0 Imesh Umayanga Posted March 31 Author Share Posted March 31 Got it fixed. To give an update for anyone facing a similar issue, it was the AC compressor worn out (bit strange with my milage). Had a wiggling pulley issue as well (bearing was alright). Got a reconditioned replacement for Rs. 35 000/= from Nugegoda. Complete repair cost Rs. 48 000/= (Gas + Labor charge). 2 Quote Link to comment Share on other sites More sharing options...
0 Hyaenidae Posted March 31 Share Posted March 31 On 3/31/2025 at 11:51 AM, Imesh Umayanga said: Got it fixed. To give an update for anyone facing a similar issue, it was the AC compressor worn out (bit strange with my milage). Had a wiggling pulley issue as well (bearing was alright). Got a reconditioned replacement for Rs. 35 000/= from Nugegoda. Complete repair cost Rs. 48 000/= (Gas + Labor charge). Expand Not at all strange with your mileage, the compressor works at its max capacity 100% of the time the car is in operation in a climate like ours. Compressors going out at 50K-60K Kms is fairly common especially if you have a clutchless compressor like 260 Premios and Allions do Anyways thanks for the update and glad you got it fixed without breaking the bank! 1 Quote Link to comment Share on other sites More sharing options...
Imesh Umayanga
Hi all,
8 answers to this question
