17 hours ago, flashmark said:
SUZUKI ATF 3317, Mobil ATF 3309 and Toyota T-IV  which ATF fluid is best for Swift ZC71S 2010?
I always thought the ZC71S came with a CVT..at least the JDM variant came with a CVT. There are variants with standard ATs but not ZC71s (they are ZC 11/21/31). You should double check what you have. The fluids you have put up there are standard Automatic Transmission Fluids. Not CVT fluid
This is what I have. So Toyota TC CVT fluid Ok, right? WhatsAppImage2025-08-18at19_24.08_a6b181bd.thumb.jpg.78f1412bedaebe7e582a771cb3727022.jpgWhatsAppImage2025-08-19at09_39.20_bba48fd1.thumb.jpg.3fa68f6812902e51d50315a5449deadc.jpg
You are going to have to double check it through your chassis number (I am not sure if Suzuki ID plates have the transmission on them).
By looking at the picture that looks like a CVT. The Automatic has P, R, N, D-3, L while the CVT had D-S instead of the D-3.
Again...YOU SHOULD DOUBLE CHECK ! If you are uncertain about how to do it, you should give it to a reputable garage to take care of the entire process (i.e. buy the proper oil and do the change along with replace any seals, filters, etc..).
As for the oil itself, you need to make sure you get the CVT fluid that meets the manufacturer's specifications. The owner's manual says Suzuki CVT F-Green 2. I don't know what the spec of that oil is. A quick internet search should tell you what other brands and types meet this spec.
