chams_mini Posted March 11, 2008 Share Posted March 11, 2008 Hi guys.. Jst want to know ur ideas on this...Is gearbox hum a huge issue?? Does it get worsen??? Any solutions to reduce the hum?? How long can we run with the hum (Approx KM)?? Pls share ur ideas.. Cheers Quote Link to comment Share on other sites More sharing options...
0 jaga Posted March 11, 2008 Share Posted March 11, 2008 Is your gear box manual or Auto? In which gear and what RPM u get the hum? Quote Link to comment Share on other sites More sharing options...
0 chams_mini Posted March 11, 2008 Author Share Posted March 11, 2008 Well its manual and just want to know a bit on this.. Lets say ithe hum is dare for all gears (worse scenario i guess ).. so wat will happen?? Quote Link to comment Share on other sites More sharing options...
0 Nisala Posted March 24, 2008 Share Posted March 24, 2008 chams_mini said: Well its manual and just want to know a bit on this.. Lets say ithe hum is dare for all gears (worse scenario i guess ).. so wat will happen?? Hey bro, I experienced this in my recently bought Corolla Wagon (KE72). The hum was in 2nd and 3rd gears. I checked this with 3 mechanics. One of them told that the gear box wheels are worn out. Others told the hum is comming due to worn out razers. The humming noize increased and I removed the gear box with one of the mechanics. He inspect and decided to replace all the razers. And the bush was also worn out and had to remake the bush. But unfortunately I had to remove the gearbox for the second time after running very few km's, bcoz arm got stucked in second gear . Then I took the vehicle to the same mechanic, he replaced some small stick like parts. I had to spent around 11,000/= for all of this. Important: Choose an expert for Gear Boxes Thanx Quote Link to comment Share on other sites More sharing options...
0 jaga Posted March 25, 2008 Share Posted March 25, 2008 Dear Nisala. After all is your problem sorted out???? Quote Link to comment Share on other sites More sharing options...
0 chams_mini Posted March 25, 2008 Author Share Posted March 25, 2008 Well bro do u have to go throuh all this trouble???? Cant we run with the hum?? Whats the worse case??? I mean will the gears get stuck and wont be in a position to change gears?? what did the mechanic say?? Is it ok to run for some time with the hum??? Share ur views guys... Quote Link to comment Share on other sites More sharing options...
0 Nisala Posted April 2, 2008 Share Posted April 2, 2008 chams_mini said: Well bro do u have to go throuh all this trouble???? Cant we run with the hum?? Whats the worse case??? I mean will the gears get stuck and wont be in a position to change gears?? what did the mechanic say?? Is it ok to run for some time with the hum??? Share ur views guys... Yes, problem got fixed. Now its running smoothly. After the repair only the gears got stucked, but now its ok. Mechanic said its now ok but he is not an expert !!. Before the repair another mechanic said 'you can run more'. But that humming was very noisy. However my advice is to meet an expert Quote Link to comment Share on other sites More sharing options...
0 Twin Turbo Posted May 2, 2008 Share Posted May 2, 2008 Don't forget to use good quality gear oil and change it as per manufacturer's recomendations Quote Link to comment Share on other sites More sharing options...
chams_mini
Hi guys..
Cheers
7 answers to this question
