I have got a Suzuki swift and a bad smell coming out from silencer like a smell of H2S.
Specially this will happen on morning and when i have driven in fast.
Any body have an idea what has gone wrong.
Vehicle milage is below 25,000 .
I think you have used oil treatment.
no i don't think.
This will occur specially when goes fast and specially in morning.
Could be couple of reasons mate. Bad O2 Sensor. or Bad plugs. or being worse bad catalytic converter. how's the Gas mileage on your car lately? you smell sulphur cos if there any unburnt fuel coming through exhaust the cat tries to burn it. thts why u smell sulfur dioxide. you better check this with qualified mechanic.
From where can i checked this?
Not more than 11km can be done per liter and is it strange to such a kind of vehicle?
I had smelled this smell from several other swifts too.
Hey Kulunu.... Here's what you should do... B) Drive the car fast for couple of minutes :ph34r: . Leave the engine running & ask your friend to accelerate to about 1,500 RPM..... & take a lighter & Ignite the lighter infront of exhaust Out....... :wacko: If you Barbacue your face then there's a problem & If you find it difficult to ignite the lighter then there's no problem with the car..... :grinning-smiley-003: Simple as that... NO DO NOT DO THAT :action-smiley-060: !!! Just take the car to the Agents & run some Tests :action-smiley-076: !!!
Edited by mishiran
where is the agents service centre?
A M W down Kithulwatte Rd off Baseline Rd , behind the Borella Kanththa
Its the road adjecent to the British School
Edited by Devinda_Z
Sorry Kulunu I missed this topic!
Your car is in very dangerous state!
The exhaust gas is very poisonous now.Could kill someone who tries to have a look.
This happens when your Air-Fuel ratio is upset or when Cat Con is not prossesing well.
Get a tune up done immediately!!
MINIACE
:action-smiley-060:
I may think it is not H2S , might be SO2.
MINIACE
I agree it's coming from the cat but not because it has gone bad just not hot enough to do its work. It could be cured by driving it on a fairly long journey or you have a fuel air mixture problem-too much un burnt fuel getting to the cat causing it to run cool, make sure the car is not misfiring, get the lambda probe tested-it may be contaminated and not signalling properly so the ecu is over fuelling.
Maithri.
hi, did you try the amws suzuki center at "kithulwatta road" , borealla?
were their obd2 scanners working ?
I also want to do a scan on my swift (2003,japanese,HT51s), but when I called tham in mid february, i was told that the tools are out or order and will not be availablr for about a month. :o
http://forum.autolanka.com/index.php?s...amp;#entry62364
hope the scanners are available now.
Edited by Thiwanka Wimalasuriya
Have you got A*W service centres telephone number?
well these are for A*W on Union place but i'm sure they can point you in the right direction -
011 2 329470
