evergreen Posted November 19, 2010 Posted November 19, 2010 Hi Guys, Changed my CVT oil few days back after 25 k. (99 EK3 ViRS). Now there is some vibration on "D" position in law RPM. Need ur help. Thanks i dont underastand why you waited for 25k to change the oil. what do you mean by vibration at D position? can you explain it further? Quote
Madhu Posted November 19, 2010 Posted November 19, 2010 (edited) i dont underastand why you waited for 25k to change the oil. what do you mean by vibration at D position? can you explain it further? Things were running smoothly before the change. May be I hv waited too long. On d position specially on the first pick up there is a certain vibration (not hudge) & On D idle olso same. It is not a contonious vibration. I hv notice a RPM drop as well. Tnks Edited November 19, 2010 by Madhu Quote
evergreen Posted November 19, 2010 Posted November 19, 2010 Things were running smoothly before the change. May be I hv waited too long. On d position specially on the first pick up there is a certain vibration (not hudge) & On D idele olso same. It is not a contonious vibration. I hv notice a RPM drop as well. Tnks RPM drop and vibration at at D position may have not anything to do with the oil change. better get the idle control valve cleaned.its a simple job. vibration at the First Pick up is something you should attend. where dis you change the oil? hope you used the correct cvt fluid. Quote
Sumiya Posted November 19, 2010 Posted November 19, 2010 hi Guys Found a reference page here http://rayazmuthalif.wordpress.com/2008/07/08/how-to-avoid-cvt-gearbox-failures-in-honda-city-fit-jazz-a-sri-lankan-perspective/ thanks regards sumith Quote
evergreen Posted November 19, 2010 Posted November 19, 2010 hi Guys Found a reference page here http://rayazmuthalif.wordpress.com/2008/07/08/how-to-avoid-cvt-gearbox-failures-in-honda-city-fit-jazz-a-sri-lankan-perspective/ thanks regards sumith this wan an old article and has been discussed here sometime back. Quote
Madhu Posted November 19, 2010 Posted November 19, 2010 RPM drop and vibration at at D position may have not anything to do with the oil change. better get the idle control valve cleaned.its a simple job. vibration at the First Pick up is something you should attend. where dis you change the oil? hope you used the correct cvt fluid. [/quote Thanks for the tip brother, Its CVT oil from Nippon (Got from tech) My worry is dat the Vibration started after da oil change. coincidence ??? Quote
imike24 Posted November 22, 2010 Posted November 22, 2010 ok __________________ pill sizegenetics review patch exercise female libido semen enhancers weightloss anti-aging web hosting HGHs hair removers pheromones breast enlargement quit smoking Quote
Komisiripala Posted November 24, 2010 Posted November 24, 2010 CVT's are prone to give problems only if not cared for. as mentioned earlier, go for one only if you have a good knowledge of the past service history. agents recommend oil change every 17,000 clicks. an engineer told me that it "jumps" in reverse because the box hasn't haeted up the oils to running temperatures, and this leads to the fidgety behavior. there may be some truth in this because mine only jumps when the engine/box is cold, and is smooth in reverse or forward from a standing start when at optimum temperature. mine has clocked 155,000km without any issues. that being said a multimatic in sport mode is a sublime experience. a manual would have to be fed some forced air to surpass that "aathal" i've had one for a year now and wouldn't give it up for the world... Quote
jdnet Posted November 24, 2010 Posted November 24, 2010 a manual would have to be fed some forced air to surpass that "aathal" IK believe the kids call it a turbocharger these days. Quote
evergreen Posted November 25, 2010 Posted November 25, 2010 CVT's are prone to give problems only if not cared for. as mentioned earlier, go for one only if you have a good knowledge of the past service history. agents recommend oil change every 17,000 clicks. an engineer told me that it "jumps" in reverse because the box hasn't haeted up the oils to running temperatures, and this leads to the fidgety behavior. there may be some truth in this because mine only jumps when the engine/box is cold, and is smooth in reverse or forward from a standing start when at optimum temperature. mine has clocked 155,000km without any issues. that being said a multimatic in sport mode is a sublime experience. a manual would have to be fed some forced air to surpass that "aathal" i've had one for a year now and wouldn't give it up for the world... the main cause of this "jump" in reverse in mornings is the reverse clutch. it takes a while to get the optimum oil pressure and temperature to the reverse clutch in the cold start. Quote
