Hey Chaps.
I am considering in UNREG 4X4 Diesel in the Longterm.
1 ) Weekend Fun Trips
2 ) Off Roading
3 ) Day to Day Use
My Choices are the 2003- 2004 Landrover TD5 Pick Up and Landrcruiser Brand New 4.2 DIESEL ( Toyota Lanka ).
Please can some one who has a better insight on these two vehicles Enlighten me on the Best Option.
Please review on
1 ) Comfortability
2 ) Power
3 ) Second Hand Market Value
4 ) Reliability
5 ) Best Off Roader
6 ) More Road Acceptance
Thanks.
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Ask Lakshan K machan - he has a Land Rover TD5 Single Cab...
3 - 3.5 Million will buy you one...
but the Toyota is 4 Million i think :unsure:
The LR will trump the Toyota on points 5) & 6) , and will equal it in terms of points 3) & 2) (might be quicker if you get the TD5 chipped :D )
well leaving all the points aside... i prefer the aesthetics of the Landy with bad-a$$ wide tires :)
I would personally go for the Cruiser. I have driven the LWB Troopy with the 4.2 plant and it is a brilliant 'runner'. Feels utterly solid with a bullet proof go anywhere feeling. The same power plant returns about 7+ km/l in a much heavier Land Cruiser 80.
One of our clients have just bought a Hilux 4x4 single cab for 2.75 mil with the 2.5 D4D. He was very happy with the buy but I felt the ride was a tad bumpy and might be a more economical alternative.
You also need a lorry license to drive all the above and may have restricted access to high security areas in Colombo. i.e Access to most of the 5 star hotels in town.
You would :)
the hilux you mentioned btw, Is it actually a 4x4? thought the single cabs were only 2wd?
You would :)
They were promoting the 2WD single cab at a tad over 2 million. 4WD is also available. 2.75 mil was the price a few months back.
Off Course i am seriously dying for the Landy. But the Cruiser power is what attracts me most. Machan i am planing to keep it UNREG with Red plates. Hopefully can get with the Canopy.
Hey Chaps
how much fuel does the landy and cruiser do. <_<
Hey Chaps
should do 10 Kmpl.... but nothing like someone with first hand expereince with long term use in local conditions to comment...
a chipped TD5 will be quite brisk,so don't write it off on the power front!
Thanks for the Info bro. Machan do you have line to specs of this vehicale.
By the way is there a difference in the Diff of Pick Up and the Full Body version.
i am infact in not in hurry to buy, cos i heard that they will be selling the full installed landy at 5 mil in around 2 months to come.
so just want to check that option too,
no difference a.f.a.i.k , but the 130's came with a different suspension system if i'm not mistaken...
Locally assembled versions of the 110 County Station Wagon will sell at 8-10 million i believe...
but these will be fully loaded
i've lost my TD5 Defender catelogue :( had to go through some old documents to dig up the exact specs , but i fear there may be some small variations :mellow:
2492cc
Inline 5 Cylinder Diesel
Turbocharged
Intercooled
Direct Injection
Common Rail
2-valves per cylinder
OHV
Bore 84.5mm
Stroke 89mm
Compression Ratio 19.5:1
Max Power : 122 BHP @ 4200 rpm
Max Torque : 221 lb ft @ 1950 rpm
0-100 kmph : 15-17 sec
Top Speed : 140 Kmph
Fuel Consumption : 7.5 ~ 10 Kmpl
Fuel Tank capacity: 75L
Length 4438mm
Width 1790mm
Height 2035 mm
Ground clearance 215mm
Approach angle 50°
Departure angle 35°
Ramp break over 152°
Weight 1977kg (unladen), GVM 3050kg, towing 750kg (unbraked) :unsure:
Transmission 5 Forward Manual
2-speed transfer case
Full Time 4WD
Centre diff
(traction control & ABS) :unsure:
Suspension live-coil/ live-coil
Tyres 235/85R16
Edited by Devinda_Z
Pardon my ignorance, what is this Landcruiser pickup you on about? Is it a different model to the Hilux?
Are these brandnew diesel prices?
Velo who are they? Is that recon price or brandnew?
Yup, the new Hilux Single-Cab 4WD with the D4D at 2.75 million is a steal and a half . How difficult is it to get the heavy duty license?
Velo why not a Landy 110 'bouble cab'version? Something like Souhaine's famous LD-0110 ??
MINIACE
That started its life in SL as a Blue Pick Up neda? :)
OT, but been meaning ot ask this myself - does anyone know what the full process is like?
Is it mandetory to do the driving test in a bus??? :blink: ...or have i been wrongly informed? <_<
yes its different machan
its essentially a 70 Series Land Cruiser Chassis Cab powered by a 4.2L Diesel unit
landcruiser70seriescabcdw9.3cf610261f.jp
Edited by Devinda_Z
MINIACE
bro i have not see this.
It must be more expensive as its duty is high.
I am missing 4X4.
These days ideal conditions for it.
i did come acorss a similar pic when i googled since the face looked old i thought velo is after different model
i think he's reffering to the Agents and that local assembly plan (The article you posted :) ) for Land Rover Defenders.. so those will be Brand New but the price will be 9-10 Million for a 110 CSW if i'm not mistaken
Dunno if they will amke the 110 Truck Cab/Pickup here... :mellow:
http://forum.autolanka.com/index.php?s...amp;#entry69323
what is this 5mill price tag velo is on about then?
XXX thats correct one. Devindz thanks for the pic.
this is a hot seller in Aussie if i am not mistaken. even africa. I saw one at fox hill with custom built cabin. looked awesome.
Heard from some one thats its gona be price at around 5 mil. thats why i mentioned it,
i am not sure if its a solid piece of info though. lets wait and see.
How ever with the world weather changing its always better to have 4x4 ready for some action.
its quite a brutish piece of equipment
i've seen quite a few of these in the middle east as well
can't argue with your line of thinking bro :)
but in terms of the price i highly doubt it'll be that cheap :( ...would be nice if it were though :)
I am missing 4X4.
whoa! :o
where is this??
This isn't a river - empty field?? :blink:
thats some serious flooding!!
