Kim Posted September 1, 2008 Share Posted September 1, 2008 (edited) just to clarify the grade of fuel which is used by the users of our site Edited September 1, 2008 by Kim Link to comment Share on other sites More sharing options...
0 Kim Posted September 1, 2008 Author Share Posted September 1, 2008 Carina GT - 95 OCT Carina 99 - 90 OCT Link to comment Share on other sites More sharing options...
0 miniace Posted September 1, 2008 Share Posted September 1, 2008 Why no window for Mixed ? I run mixed. MINIACE Link to comment Share on other sites More sharing options...
0 Kim Posted September 1, 2008 Author Share Posted September 1, 2008 Mixed ?? share the results pls.. u mean half 90 and half 95? is it ? Link to comment Share on other sites More sharing options...
0 neasmh Posted September 1, 2008 Share Posted September 1, 2008 Kim said: Mixed ?? share the results pls.. u mean half 90 and half 95? is it ? I am using 95 on my allion and it does 12 kmpl.. and 90 on my march 1.3 and it does only 8 kmpl.. i dont feel any difference between performance as i pumped 95 on march before, so i shifted to 90.. Link to comment Share on other sites More sharing options...
0 miniace Posted September 1, 2008 Share Posted September 1, 2008 Kim said: Mixed ?? share the results pls.. u mean half 90 and half 95? is it ? Well.... 95 when you have money ,90 when you dont !!! MINIACE 1 Link to comment Share on other sites More sharing options...
0 Kim Posted September 1, 2008 Author Share Posted September 1, 2008 neasmh said: I am using 95 on my allion and it does 12 kmpl.. and 90 on my march 1.3 and it does only 8 kmpl.. i dont feel any difference between performance as i pumped 95 on march before, so i shifted to 90.. y using 95 for ur allion? have they specified to use 95 OCT for it ?? Link to comment Share on other sites More sharing options...
0 Kim Posted September 1, 2008 Author Share Posted September 1, 2008 miniace said: Well.... 95 when you have money ,90 when you dont !!! MINIACE hmmmmm...is it so..? as i have heard, if u pump 95 or 90 u just continue with it, and no point in mixing in between.. Link to comment Share on other sites More sharing options...
0 miniace Posted September 1, 2008 Share Posted September 1, 2008 Kim said: hmmmmm...is it so..? as i have heard, if u pump 95 or 90 u just continue with it, and no point in mixing in between.. For me,mixing is a better option than running out of fuel and money. MINIACE Link to comment Share on other sites More sharing options...
0 neasmh Posted September 1, 2008 Share Posted September 1, 2008 (edited) Kim said: y using 95 for ur allion? have they specified to use 95 OCT for it ?? that is a good question... well.. when i bought the car i immediately went for a service at the agents and ive been told to use 95 to get better fuel consumption on vvti engines. and for less maintenance too. Edited September 1, 2008 by neasmh Link to comment Share on other sites More sharing options...
0 SHAI Posted September 1, 2008 Share Posted September 1, 2008 neasmh said: that is a good question... well.. when i bought the car i immediately went for a service at the agents and ive been told to use 95 to get better fuel consumption on vvti engines. and for less maintenance too. hmmmm, I use 95 too. This is basically continuing on from what the previous owner used to put in, but is there really a difference in the two? or is it only the price? I've heard many stories, from "Yes you have to because its a better grade of fuel" to "Don't bother with 95, its as full of impurities as the 90"....... One other thing i've been told is that a once in a while mix is also good for the engine...............go figure. All my previous cars were run on 90, but then to really tell a difference if any I guess I should try the current one on 90. I remember, when my aunt bought a ford a while back, DPMC recommended that she use 95. This they said was better for the engine in the long run, economy etc etc..........simmilar to what neasmh says above. question is.......does it actually work? Link to comment Share on other sites More sharing options...
0 GihanFX Posted September 1, 2008 Share Posted September 1, 2008 well i pump 95 but the ecu tuned to run 100 RON, sometime mix Tolune when i full tank, Link to comment Share on other sites More sharing options...
0 jaga Posted September 1, 2008 Share Posted September 1, 2008 My car with 95 does 9 km/l. With 90 it does 10.5 km/l Link to comment Share on other sites More sharing options...
0 Ripper Posted September 1, 2008 Share Posted September 1, 2008 jaga said: My car with 95 does 9 km/l. With 90 it does 10.5 km/l used to pump 95 even for the bikes until they jacked up the price creating a larger gap etween the variants... used to pump 90 right afterward but now upgraded to 95 again cos i don't have to pay for it anymore Link to comment Share on other sites More sharing options...
0 Ruslan Posted September 1, 2008 Share Posted September 1, 2008 (edited) same story here as well. when there is less gap between 90 and 95 i used to pump 95. now 90 only. there's a slight difference between two when comparin the fuel consumption. but anyway VVT-i engines designed to use with regular gasoline higher than 80 Octane. this i came up with Engine Manual for 1ZZ-FE Engine. Edited September 1, 2008 by Ruslan Link to comment Share on other sites More sharing options...
0 Arc Angel Posted September 2, 2008 Share Posted September 2, 2008 sigh... no choice here. 95 is a must. Link to comment Share on other sites More sharing options...
0 Arc Angel Posted September 2, 2008 Share Posted September 2, 2008 Ripper said: used to pump 90 right afterward but now upgraded to 95 again cos i don't have to pay for it anymore I suppose congrats are in order? Link to comment Share on other sites More sharing options...
0 Kim Posted September 2, 2008 Author Share Posted September 2, 2008 Ruslan said: same story here as well. when there is less gap between 90 and 95 i used to pump 95. now 90 only. there's a slight difference between two when comparin the fuel consumption. but anyway VVT-i engines designed to use with regular gasoline higher than 80 Octane. this i came up with Engine Manual for 1ZZ-FE Engine. r u really sure about this? whats the car u use? and hows its fuel consumption? Link to comment Share on other sites More sharing options...
0 Kim Posted September 2, 2008 Author Share Posted September 2, 2008 Arc Angel said: sigh... no choice here. 95 is a must. oh..whats the car u use ? Link to comment Share on other sites More sharing options...
0 Ruslan Posted September 2, 2008 Share Posted September 2, 2008 (edited) Kim said: r u really sure about this? whats the car u use? and hows its fuel consumption? It's a Corolla Luxel 122 with 1.8Litre 1ZZ-FE.im normally getting 9-10Kmpl figures in Town and 16 17 outstation cruising (below 3000Rpm). this is of course with 90 Octane. once, i got 18Kmpl with 95 Octane (Driving from Maharagama to Embilipitiya at night). that's the best i got from this car. Edited September 2, 2008 by Ruslan Link to comment Share on other sites More sharing options...
0 Kim Posted September 2, 2008 Author Share Posted September 2, 2008 SHAI said: hmmmm, I use 95 too. This is basically continuing on from what the previous owner used to put in, but is there really a difference in the two? or is it only the price? I've heard many stories, from "Yes you have to because its a better grade of fuel" to "Don't bother with 95, its as full of impurities as the 90"....... One other thing i've been told is that a once in a while mix is also good for the engine...............go figure. All my previous cars were run on 90, but then to really tell a difference if any I guess I should try the current one on 90. I remember, when my aunt bought a ford a while back, DPMC recommended that she use 95. This they said was better for the engine in the long run, economy etc etc..........simmilar to what neasmh says above. question is.......does it actually work? yup, thats the same issue that i am having..having read and understood the fact that 'unless the car demands a better fuel' don't pay for a premium fuel, unnecessarily sooner i will be switching to a car having VVT-i (toyota) so, i need to decide on it now it self, as to which i am gonna pump from the start, as it has never been used in SL yet.. also, if the prices go up again, first they had a difference of 3, now its 13, and next who knows how much the difference will be? and having to pay the premium charge, unless having a worth-while point, bothers me a lot, yeh, no one pays for my fuel, and unfortunately what i earn for now is no big deal, and can be packed in the pocket at once Link to comment Share on other sites More sharing options...
0 Kim Posted September 2, 2008 Author Share Posted September 2, 2008 Ruslan said: It's a Corolla Luxel 122 with 1.8Litre 1ZZ-FE.im normally getting 9-10Kmpl figures in Town and 16 17 outstation cruising (below 3000Rpm). this is of course with 90 Octane. once, i got 18Kmpl with 95 Octane (Driving from Maharagama to Embilipitiya at night). that's the best i got from this car. interesting, i have been hearing these 1.8 VVT-i are amazing on fuel on longer trips that is so being used both 95 and 90, do u notice any' difference now?? - i really appreciated if an expert can shed some light here - Link to comment Share on other sites More sharing options...
0 Ruslan Posted September 2, 2008 Share Posted September 2, 2008 (edited) Kim said: interesting, i have been hearing these 1.8 VVT-i are amazing on fuel on longer trips that is so being used both 95 and 90, do u notice any' difference now?? - i really appreciated if an expert can shed some light here - I guess it only affects on long trips. not much in driving around Cities i suppose. herd someone in the forum say that 95 is got more impurities than 90 can anybody confirm this report. if it's true, it's scary! Edited September 2, 2008 by Ruslan Link to comment Share on other sites More sharing options...
0 Optimus Prime Posted September 2, 2008 Share Posted September 2, 2008 (edited) Kim said: oh..whats the car u use ? I guess the car in Arc's signature might give a hint... Coming back to the topic, like most who have replied to this thread, I also use a mix of 90 and 95 depending on my savings level. I'm not too sure whether the octane rating has as big an effect on NA vehicles as it does on vehicles with forced induction. But there is a 'smoothness' across the rev range when running on 95. Edited September 2, 2008 by Optimus Prime Link to comment Share on other sites More sharing options...
0 Pericles Posted September 2, 2008 Share Posted September 2, 2008 Ruslan said: I guess it only affects on long trips. not much in driving around Cities i suppose. herd someone in the forum say that 95 is got more impurities than 90 can anybody confirm this report. if it's true, it's scary! Yeah, I think that was MadMax. Anyway, the number is a indicator of octain content, not quality of fuel. Link to comment Share on other sites More sharing options...
0 Arc Angel Posted September 2, 2008 Share Posted September 2, 2008 (edited) Kim said: oh..whats the car u use ? an evo iii machan Edited September 2, 2008 by Arc Angel Link to comment Share on other sites More sharing options...
Kim
Edited by KimLink to comment
Top Posters For This Question
15
14
13
10
Popular Days
Sep 2
15
Sep 1
15
Sep 21
12
Sep 27
10
Kim 15 posts
GihanFX 14 posts
Bugatti 13 posts
STi B4 10 posts
Popular Days
Sep 2 2008
Sep 1 2008
Sep 21 2009
Sep 27 2009
Popular Posts
miniace
109 answers to this question
