MkX Posted June 19, 2009 Posted June 19, 2009 (edited) What is your suggestion when we buy used car in terms of YOM Vs Registered year for Honda EK3. Suppose both are with good interior and engine condition and VTEC * YOM 96, Reg - 300/301-XXXX * YOM 97/98, Reg - 19-XXXX priced 1lk - 1.5lks below the above one. Which one you go for? Note: This is same model, not 99/00 model. 96-98. Edited June 19, 2009 by MkX Quote
Ripper Posted June 19, 2009 Posted June 19, 2009 What is your suggestion when we buy used car in terms of YOM Vs Registered year for Honda EK3. Suppose both are with good interior and engine condition and VTEC * YOM 96, Reg - 300/301-XXXX * YOM 97/98, Reg - 19-XXXX priced 1lk - 1.5lks below the above one. Which one you go for? if both cars are equal on "condition" both cosmetically and mechanically...i would go for the newer model simply because it would be easier to resell than the older one... Quote
Cham82 Posted June 19, 2009 Posted June 19, 2009 Of this is the thing. YOM does seem to count a lot when it comes to after sale market. But you cant sell the vehicle if it has an older registration number. So it is a touch and go stiuation for you. I would recommend you to go for 19-XXXX only if it has crystal lights in it. Otherwise go for the 300-XXXX more sensible thing to do. What is your suggestion when we buy used car in terms of YOM Vs Registered year for Honda EK3. Suppose both are with good interior and engine condition and VTEC * YOM 96, Reg - 300/301-XXXX * YOM 97/98, Reg - 19-XXXX priced 1lk - 1.5lks below the above one. Which one you go for? Quote
MkX Posted June 19, 2009 Author Posted June 19, 2009 Of this is the thing. YOM does seem to count a lot when it comes to after sale market. But you cant sell the vehicle if it has an older registration number. So it is a touch and go stiuation for you. I would recommend you to go for 19-XXXX only if it has crystal lights in it. Otherwise go for the 300-XXXX more sensible thing to do. crystal lights - are you referring to 99/00 model. Well if it's 99/00 model then, yes i will definately go for it. But this case 96-98 YOM but same model with different price which is based on YOM. Quote
xXx Posted June 19, 2009 Posted June 19, 2009 What is your suggestion when we buy used car in terms of YOM Vs Registered year for Honda EK3. Suppose both are with good interior and engine condition and VTEC * YOM 96, Reg - 300/301-XXXX * YOM 97/98, Reg - 19-XXXX priced 1lk - 1.5lks below the above one. Which one you go for? Note: This is same model, not 99/00 model. 96-98. wait a minute. how come there's such a major discrepancy on the registration numbers???? is the 97/98 one brand new and the other one recon? my memory on YOM against the registration number is very hazy so it well could be i'm talking out of my ass here Quote
Ripper Posted June 22, 2009 Posted June 22, 2009 wait a minute. how come there's such a major discrepancy on the registration numbers???? is the 97/98 one brand new and the other one recon? my memory on YOM against the registration number is very hazy so it well could be i'm talking out of my ass here well the reg no. applies to the year that the vehicle was brought into SL... say i got a 19- sprinter... YOM93..brought to SL in 97 according to papers... recently saw the same model car on the road with HN plates possibly that car was brought to SL much later hence the english plates.... the newer plates might add a bit of value over the older plates though the car can be from the same YOM... Quote
xXx Posted June 22, 2009 Posted June 22, 2009 well the reg no. applies to the year that the vehicle was brought into SL... say i got a 19- sprinter... YOM93..brought to SL in 97 according to papers... recently saw the same model car on the road with HN plates possibly that car was brought to SL much later hence the english plates.... the newer plates might add a bit of value over the older plates though the car can be from the same YOM... you are correct ripper. hence why i thought maybe the 97 car was imported brandnew and registered on the same year whereas the other car was imported 3 years later (arround year 1999) as a recon and registered then. i can't see a reason why someone would import a civic and keep it for so long without registering it. Quote
MkX Posted June 24, 2009 Author Posted June 24, 2009 Guys.. Guys.. as you all discuss YES there is a confusion how 96 got 301, and 98 got 19 numbers.. So tell me which car you go for Quote
abramoon Posted June 24, 2009 Posted June 24, 2009 (edited) Guys.. Guys.. as you all discuss YES there is a confusion how 96 got 301, and 98 got 19 numbers.. So tell me which car you go for Most of us are thinking about reselling price when we buy a car because we don't want to keep it with us for ever.So in this case I go for a new registration number.See even in your case 301 number got a higher price...!! But if I really like to use the car for a long time I will select the latest YOM because buying price and maintenance cost should be low and will balance the cost I loss when reselling.. Edited June 24, 2009 by abramoon Quote
xXx Posted June 24, 2009 Posted June 24, 2009 Guys.. Guys.. as you all discuss YES there is a confusion how 96 got 301, and 98 got 19 numbers.. So tell me which car you go for MkX if one car is brandnew and the other is not then it adds a whole new variable to the equation. i think the very first thing you need to do is find answers to the 'confusing' question. Quote
MkX Posted June 26, 2009 Author Posted June 26, 2009 MkX if one car is brandnew and the other is not then it adds a whole new variable to the equation. i think the very first thing you need to do is find answers to the 'confusing' question. Those are recon ones. Din't come across Vi/Vti brand new ones. All brand new import were Exi model. Considering the SL market I also feel go for new number (300/301/302) irrespective of YOM. Quote
jaga Posted June 26, 2009 Posted June 26, 2009 Don't forget that recon ones are comming with more options than BN ones. (ABS brakes SRS etc etc ) Quote
MkX Posted July 15, 2009 Author Posted July 15, 2009 http://www.autolanka.com/ad.asp?ID=11147 Guys is there a way to undo the mods in bonnet of above car? It's look little ugly to me. Is this price acceptable? Quote
gunat Posted July 16, 2009 Posted July 16, 2009 Another SL'kan 'ism' that amazes me. A buyer is more than willing to spend a premium (200-300k) on a English plate car with say, 100k mileage (possibly more hacked too) than an equivalent older plate with half as much mileage. Where's the logic? (Shake head) Quote
VPJ Posted July 16, 2009 Posted July 16, 2009 http://www.autolanka.com/ad.asp?ID=11147 Guys is there a way to undo the mods in bonnet of above car? It's look little ugly to me. Is this price acceptable? did you check the car?? what sort of a modification is that?? the price looks ok if you are happy with other modifications. check the milage too. Quote
MkX Posted July 16, 2009 Author Posted July 16, 2009 (edited) Another SL'kan 'ism' that amazes me. A buyer is more than willing to spend a premium (200-300k) on a English plate car with say, 100k mileage (possibly more hacked too) than an equivalent older plate with half as much mileage. Where's the logic? (Shake head) Simple logic. re sell value Edited July 16, 2009 by MkX Quote
MkX Posted July 23, 2009 Author Posted July 23, 2009 Guys I went for 301 (99 Reg) but 96-YOM Vi model. Great car. Quote
VPJ Posted July 23, 2009 Posted July 23, 2009 Guys I went for 301 (99 Reg) but 96-YOM Vi model. Great car. welcome to world of civic!! what are the specifications?? how much did yu pay?? Quote
