Dear All,
I’m planning to buy one of these car, Please advice on the Parts availability of Nissan FB13 diesel version and Toyota Visa, and what will be the good one?
better go for b13. ample spares.
Dear All,
Nissan will have enough parts. :rolleyes: But its very hard to compaire a sunny with a vista they are simply tow worlds apart. :) but i find SB13 engine a bit under powerd. our more experianced mebers will be able to give you mor info
One thing is for sure that is sb13 aka doctor sunny holds a better market and availability of spares. Vista is not in par with other toyota diesels in sl in terms of spares availability and marketability except it's being toyota :) also sb 13 known as an economical car to run and maintain. Once i can recall we went to kataragama and return back to kottawa in less than a tank full.
True! It struggles when climbing hills in Nuwara-eliya area. Otherwise it is a competant car for daily use and also very economical in diesel consumption. [it has a 1680cc naturally aspirated diesel engine (with a mechanical injector pump)].
agreed .. my GF drives a SB13 and she pumps 500rs diesl per week.. she comes to work for 5 days + other day to day travelling ( shopping and stuff ) which is very economical. :)
also the vista's suspension tends to bottom out even for the most tiny pot-hole...i've experienced this when hitching a ride with a guy i know...he says it's a common problem...this might be untrue but worth looking in to, if anyone is buying one...
Dear All,
Thanks for comments.
Well..this time it goes for Nissan! well, enough reasons why you shouldn't buy a Vista! if your selecting between these two, go for the FB13..
  • 2 years later...
From those two car you have mentioned, I would recommend SB13. But if you give a try for CE100 or CE110, It is a different matter!
