Nissan K11(2000model) With Lifetime Timing Chain
  • 10 months later...
i have the same car. there is no timing belts or chains! :)
it has anooying churu churu from steering due to eps :angry-smiley-024:
No Belts or Chains?? What is your engine then?
Never thought that a tiny, relatively newer Nissan Engine would use timing gears or pushrods :D
is nissan K11(2000model) with timing chain???
are there any common problems with nissan march k11 EPS?
thnx
If it`s a CG series motor (e.g. CG13DE) it should be using a timing chain.
You can always Google for more info. :)
No the K11 March does have one of those with the 1.3 engine, if it's a CG13DE it's a timing chain and CGA3DE will have a timing belt if I'm not mistaken. And neither are for lifetime, unless you plan on throwing the car away like in developed countries :)
  • 1 year later...
i am having Nissan march K 11 manuafacuring year 2000 with 1000CC engine.can anyone tell me does it has timing belt or Chain
Its got a timing chain.
  • Thanks 1
