sanjeew Posted May 12, 2010 Posted May 12, 2010 What are the deffarance between Starlet ep95 and ep91 and what is best one Quote
iRage Posted January 18, 2024 Posted January 18, 2024 The main difference is: 95 is the code designation for AWD variants and 91 the code designation for FWD variants. So EP95 is an AWD Starlet with the 4E-FE engine and EP91 is a FWD starlet with the 4E-FE engine. Although they both have the same engine the EP95 was tuned to have a little less torque than the EP91. This was mainly to help the car maintain traction on slippery roads and to prevent wheel spin. Because of the AWD components the EP95 is also about 100kg heavier than the EP91 so feels a bit less nimble than the EP91 and can potentially be a bit fuel hungrier as well. Apart from the above it is mostly differences in trim levels. Quote
