Urgent Help Needed To Find A Mazda Bhalp(1996) Auto Gearbox
samiram
Hi Guys,
My car was suddenly refused move forward while i was driving. Engine was started ok but when shifted to any position including the reverse gear, car wont move. Also the hold light is blinking too. So i had to tow it to a garage called 'Wheel base' at Meegoda because this was happened around 8pm and mazna motors was closed at that time.
Iam expecting the worse and hope to have a place to get a gearbox if needed. If you guys knows a place or a contact where i can buy a good one please let me know. I will try to contact mazna motors tomorrow too.
Thanks in advance.
Samira
Edited by samiram
Hi Guys,
Thanks in advance.
Samira
Is it an Auto or Manual? From what you have told, I think it will be more of a clutch related issue as you might have burnt the clutch plate. If its a manual and when you are shifting gears, do you hear any noises? or feel like the gear is jumping. If so it might be a gear box issue. Btw, when was it last since you changed your transmition fluid? I mean how many kms ago? The same happened to me when the car would start and not move and I had to get a new clutch plate etc. My gear box was fine. Clutch plate should be relatively cheaper than a gear box but depends on the clutch plate you wanna get since there is a variety.
Thanks for the reply machan but its an auto. I recently change the ATF oil and when draining the oil yesterday, there were some metal particles in it. :(
  • 1 year later...
Hi Guys,
Thanks in advance.
Samira
well i know its too late , but i would like to know what happened to your car????
Mazna Motors is the preferred location,
Alternatively there is a place on high-level road (opposite Sujatha/Petrol shed) and they have gear boxes.
Is your side a basic auto or a tiptronic ? If it’s the later – U need some serious luck to get hold of one. A basic auto will set you back 50,000/- or so + fixing up etc. Dropped u a PM
Did not get the PM????
What do you think about repairing the box. I was told to take it to chandana in ambuldeniya. He is an expert????????
