jdnet Posted December 30, 2010 Posted December 30, 2010 Ok guys, Basically I was thinking of making my own battery jump starter. I used to have a bvlack and decker one but can't find anything locally and shipping one in would be useless considering the weight. So here's my idea 1. Find small battery that would be capable of giving the vehicle a sufficient charge (need yourhelp in picking the type of battery, also please let me know how long a fully charged sealed battery can maintin it's charge) 2. Get down or purchase locally a trickle charger. 3. Fabricate a metal bracket with a handle to hold the battery and trickle charger (basically it should look like a small basket) 4. Make a cover out of fiber glass so that the indicator lights of the trickle charger are visible and the entire unit looks like it was from the factory. 5. make a cool paint job and stick decals on it. lol. Anyway let me know what you think and please do help me decide which battery would work the best. Please stay on topic and only offfer input related to this as this will be turned into a DIY thread with pictures. Thanks. Quote
jdnet Posted December 30, 2010 Author Posted December 30, 2010 (edited) Here's the trickle charger i'm looking at. If you find something smaller and cheaper let me know. Basically I want to make this a low cost project anyone could do. BTW the charger should have indicators for identifying whether the battery is charged or not. Edited December 30, 2010 by jdnet Quote
jdnet Posted December 30, 2010 Author Posted December 30, 2010 lol my bad http://www.amazon.com/Schumacher-SE-1-12S-Automatic-Onboard-Battery/dp/B0000AXTUY/ref=sr_1_7?ie=UTF8&qid=1293712483&sr=8-7 Quote
MasterDon Posted December 30, 2010 Posted December 30, 2010 Macho I hate to be the one to pee in your fire But wouldn't it be easier to just buy one here.Try Robert agencies. Quote
jdnet Posted December 30, 2010 Author Posted December 30, 2010 Macho I hate to be the one to pee in your fire But wouldn't it be easier to just buy one here.Try Robert agencies. Where's the fun in that? lol... seriously they have em? did not know I checked the usual places.... Quote
MasterDon Posted December 30, 2010 Posted December 30, 2010 Where's the fun in that? lol... seriously they have em? did not know I checked the usual places.... http://www.robertagencies.com/battery_chargers2.htm http://www.robertagencies.com/battery_chargers.htm I doubt the website gets updated frequently so give them a ring and see.The may have newer models. Quote
jdnet Posted December 30, 2010 Author Posted December 30, 2010 Well those are chargers dude. Not actual jump starters. What I need is a jump starter to keep in my trunk. Quote
MasterDon Posted December 30, 2010 Posted December 30, 2010 (edited) Well those are chargers dude. Not actual jump starters. What I need is a jump starter to keep in my trunk. oops my bad.got confused....eitherway give robert agencies a ring they may have it or point you in the right direction. check this...Sylvi maybe able to help you. Edited December 30, 2010 by MasterDon Quote
Sylvi Posted January 1, 2011 Posted January 1, 2011 Here's the trickle charger i'm looking at. If you find something smaller and cheaper let me know. Basically I want to make this a low cost project anyone could do. BTW the charger should have indicators for identifying whether the battery is charged or not. Jdnet, I presume you want to build a battery charger to jump start cars and small Diesel vans you will have to have a battery above 6o Amperes ideal will be 90 appears. Charger you cam build your self can buy a small transformer 12 volts AC 3 to 5 amps will cost you Rs.500.00 to 1250.00 and have full wave bridge to convert AC Volts to DC Volts cost will be Rs.75.00 to 150. if you want can fix up a small 10 Ampere meter and Dc Volt to monitor the battery charge. Meter each will be Rs.500.00. Fully charged battery with good cells charge will remain for 10 days it is good to plug the charger every two days for 1 Hour and if you use for jump start then charge the battery for about two hours. Have a hydro meter test the SG of Acid every month. Then jump start cables ( Electric Welding cables 150 Amps) to your required length with end clips above 200 Amperes.This will be around Rs 4000.00. If you want a Quick charger then you have to get a bigger Transformer with high amperage Secondary winding to give about 25 Amperes this cannot be used for long time as battery will start boiling you have to monitor battery temperature. Can use Electric welding transformer by modifying the secondary Welding winding with high Ampere DC Diodes with a switch 6 12 and 24 Volts Dc to jump start Automobiles. Sylvi Wijesinghe. Quote
Watchman Posted January 1, 2011 Posted January 1, 2011 Having a couple of vehicles which idle for weeks/months without being started at home i know the pain of having to jump start a car. Something you cant cut down on weight is the battery itself. Thats shit heavy and lifting/carrying it aint that easy, i'm sure you all know. But wouldnt it be easier to have a set of jumper cables in the trunk. Its very rare that you'll be stuck on a road where there's absolutely no other motorist nearby. Plus a battery itself will set you back about 10k and that'll need changing every 2-3 years or so. So thats a lot of cash you''re dishing out for something you might not be using that frequently. from a financial and practical standpoint the cables to me seem the more logical choice. But if you want a DIY project, i'm sure it'll be a fun job Quote
jdnet Posted January 1, 2011 Author Posted January 1, 2011 Having a couple of vehicles which idle for weeks/months without being started at home i know the pain of having to jump start a car. Something you cant cut down on weight is the battery itself. Thats shit heavy and lifting/carrying it aint that easy, i'm sure you all know. But wouldnt it be easier to have a set of jumper cables in the trunk. Its very rare that you'll be stuck on a road where there's absolutely no other motorist nearby. Plus a battery itself will set you back about 10k and that'll need changing every 2-3 years or so. So thats a lot of cash you''re dishing out for something you might not be using that frequently. from a financial and practical standpoint the cables to me seem the more logical choice. But if you want a DIY project, i'm sure it'll be a fun job I do have myself a few sets of jumper cables lying around but do you think i'm doing this because I'm scared I will be in the middle of nowhere with a dead battery? lol.This is just a project to kill time. I am looking at some options for lighter batteries though to make the unit more portable... Quote
