[Civic 2018]First Impressions and the basics
matroska
Here's  a write up on my Daily Driver - the new Civic 1 Litre Turbo - I've so far done just a bit over 1500 Km's and  since the engine was new didn't really push it to the max and I have not yet been able to do a really long trip  or a drive uphill to  BUT I will continue to update the blog based  on the experiences as well as services etc.  For a start I will touch the basics as well as all the cosmetic stuff and then get into the overall driving experience and later on the services etc. There is also a dedicated thread in the forum that is quite informative. But I hope this blog will also prove useful to someone.
First of all the basics....
In a nutshell the 2017 Civic is the 10th generation in the line up. The particular model I have, and is getting popular in SL  goes under the model code FK6 and has a P10A2 engine which has a measly 988cc but is turbocharged.
The car is made in the UK (at Honda's Swindon Plant). I have heard that the agents now bring it down as well. (6.2M for the SR)
There are 3 grades for the 1L turbocharged civic. SE, SR and the EX.
The SE is the most basic model with the EX being the highest (the Tech pack is a further extension of the EX) There is roughly a 5,000 GBP (~ 1 Mil LKR) price difference between the SE and the EX. The SR on the other hand sits comfortably in the middle - it does not have stuff like adaptive damper system that comes on the EX. The Honda UK website lists down the differences of each grade under a section called 'Build your Honda' or something. If you're interested do have a look.
There are 7 colors available and the Rallye Red is the standard . Every other color will cost around 500 GBP more . There is also the  "Orange Line Pack" - which is basically an accessory kit that adds a touch of orange into everything - I've seen a few such cars in car sales in SL. Though I initially contemplated Sonic Grey, ended up with a Polished Metal Metallic specimen.
With the 2017 Budget a new tax structure was introduced and under the engine capacity based taxation  you'd be paying 17.5 m in taxes  (1,754,976 LKR  to be precise) for a brand new car with reasonable creature comforts and a bunch of bells and whistles which costs something between 4-5 mill based on the grade ( see above )
First Impressions
For me the new  Civic hatch  looks like someone started designing and spent too much time  doing a good job with the front and then ran out of time to design the posterior and hastily put an end to it. This explains the rather weird looking behind. The Sedan version I have to admit looks better. There's also waay too much plastic in the rear so much so that it looks like a joint venture between Honda and Arpico.
There's a bit of aggressive styling at the front. The car is quite wide and it has a solid ground hugging look to it.
As for the supposed vents you see at the front and the back - well those are fake. They're simply pieces of plastic made to look like vents.  And yes it does have fog lights. I like the factory fitted black 17" alloys. Note the SE comes with 16" Alloys as opposed to the 17" found in the SR.
Being a brand new car it came with a humongous bible-like user manual (thankfully in English) - along with the wheel lock nut as well as the tool kit and the tire  repair kit (glue and the inflator which by now we are used to)  If any of you intend to buy one from a regular car sale make sure they give you  your wheel lock nut.
  • Like 17
  • Thanks 4
9 Comments
Recommended Comments
Nice review. Have the same colour in EX Tech trim. One of the better colours for this car for sure. Waiting for more updates!
  On 1/11/2019 at 11:08 AM, Magnum said:
This is the hatchback version right? I find this better looking than the sedan
Expand
Yes this is the hatchback - yeah no complains but I'm not a big fan of the plastic y rear.
Add a comment...
