Kavvz
Everything posted by Kavvz
  1. lol !! Well at least it only takes five minutes to get rid of the bloody kit and toss it out!
  2. Your car should be able to cruise at 100-120 without vibration. Those highway speeds are pretty common and most cars including yours are designed to cruise at those speeds smoothly without issues. If it does vibrate excessively, you have an issue, and you should look to get it fixed. Based on your list of issues, it sounds like you need to replace the rear tyres as well as the rear shocks before you get on the highway again...once you get those issues sorted: Your car steering wheel shouldn't be pulling to the right or left nor should it be vibrating excessively, a little bit of vibration is normal and some tyre tread patterns will make your car vibrate more, however the vibration should not be excessive where it makes it hard to steer or control the car with your finger tips only (I'm NOT saying that your should go around steering with your fingertips, and I am NOT saying that this is a safe practise, its just the rule of thumb I use, and it may or maynot work for you to determine how excessive your vibration issues are). Common things that I would check if the vibration is excessive are: Check air pressure on all your tyres, making sure that each axle has the same air pressure Check your tyres: Check your tyres and look for uneven tread wear. Ideally all four tyres should have similar treads and wear, but as long as the tread wear and tread patterns on each axle is similar you should be fine. Check for broken belts, bumps and other irregularities in your tyres. If any irregularities are found you need to switch that tyre out (when replacing the tyre most often you'll have to switch both the tyres on the affected axle). Check alignment If all of the above is okay, you should then look at getting your suspension components checked..
  3. Kavvz replied to MADZ's topic in The Lounge
    Its an old hoax. Not a nickel of truth in this report!
  4. Kavvz replied to jdnet's topic in NISSAN
    Detroit?
  5. Edited: Well the rear isn't too bad. IMO its an improvement on the current Corolla rear.
  6. You could use an OBD11 scanner and see if it picks up anything (that's what I would do first). If it does give you an error code, figuring out what's wrong by checking / googling the code generated; is usually a pretty straight forward affair. If you don't have a OBD11 scanner you could take it to the agents or any one of the better equipped garages and ask them to run a scan for you. There's a thread on how to scan your car using a bluetooth interface and a downloaded app for smart phones on autolanka as well which is quite informative.
  7. Capacitor technology might provide an alternative someday as mentioned here. A teen provided a proof of concept as mentioned here, but there is no indication whether it would scale it up...
  8. Quite the interesting upgrade; however I wonder whether the rapid charging impacts battery life significantly?
  9. I suppose. Although it seems like a waste to give up a Carina / full size car and pick up a Corolla. As for the other two: Centre mounted dashboards drive me nuts...I'm biased I guess.
  10. Why not just keep the Carina you currently have? If you've got cosmetic / mechanical issues: You could simply fix it up and hang on to it for less couldn't you? IMO that'd be more appealing than the options you've listed...
  11. Something I was guilty of as well... She certainly is a beauty Max...I got through your list of goodies, but stalled at the BMW performance black grill. I don't see much of a difference there; did you already have it on when you took the first set of pictures?
  12. Whoa dead cool madmax! ( And what a simply awesome wife!! )
  13. Hey that's not bad at all for a student, good job buddy! Now if you really want to make money; I have an uncle in Nigeria who can double that for you in just two days...
  14. But what ever comes about, whether its Rolls Royce's Beemers or Merc's these invitees are going to be 'cumming' in; the bill for all these high-jinks have to be paid by someone and it certainly isn't the VVIP's, their lackeys or the invitees that are going to be footing the tab. What I'm interested to know is: How are the many costs associated with all this ego bolstering, going to be explained to the public?
  15. I wouldn't be surprised. 'The Ceylon Today' isn't really renowned for accuracy...
  16. I'm sorry 'Californikan', but that can't be true. I don't know much about Suddha buggers, nor do I know much about international standards, and do I understand that you're having a tough time on the forum with this thread, but: The Google Gods tell me that Natural Gas is used widely to heat homes in the US and in Canada. This makes it hard to imagine that they (the Suddha buggers) then would not know the difference between Geo-thermal energy and Natural Gas energy?
  17. The Ministry of Finance has opened Letters of Credit (LCs) through the Bank of Ceylon to import 55 Mercedes Benz vehicles of the latest S400 model to Sri Lanka for the use by VVIPs attending the Commonwealth Heads of Government Meeting (CHOGM), scheduled to be held in Sri Lanka in November, Ceylon Today reliably learns.
  18. I'm glad that things are relatively stable and getting better. As harshansenadhir mentioned: Our best wishes and prayers for a speedy recovery.
  19. Kavvz replied to MADZ's topic in The Lounge
    Oh is that where the word 'janela' came from? I know 'almariya' is derived from Portuguese, so I guess its pretty likely...
  20. Kavvz replied to MADZ's topic in The Lounge
    Funniest post EVER!! And then the bugger just casually walks off?! Hilarious
  21. Wow, very interesting: Thanks for sharing!
  22. Ahh! I see, thanks for clearing that up, I catch the drift now...I was thinking cars when it was politics that was on the boards!
  23. Hi Sampath, Any updates on the book project by Mr. Hettiarachchi? Thanks.
  24. Care to elaborate what happened in 1977 please?
