Everything posted by nira74
Battery Water !!!!
How old is the battery in question ? It could be that it 'vented' - if there's something wrong with the acid composition or if it over-charges (i.e- problem in alternator/diode/cut-out) the acid may bubble out. But you would see signs of it..... salt deposits on the top of the battery, signs of acid vapour in the engine bay around the battery. Usually the weather in Sri Lanka around this time of year is not too good for batteries.... especially if they're over two years old. Best thing would to get the battery checked by professionals and if it's OK, then you need to check your cars charging circuit.
Autolanka Drag Racing Championship 2007 !!!
The mini 4 speed autobox is quite good actually. I was quite surprised the first time I drove our old mini after the conversion.
Geez, Its Flooded Anypics
If you actually got across it means the water wasn't really all that that deep. Cause the mini distributor sits pretty low..... 12-15 inches above the road. If that had gotten wet you'd have been pushing the car for sure.
2002 Bmw E46 Or 2002 Jag X-type
Facelift Model 318 comes with a super 2 litre engine and the driving pleasure you get from the RWD chassis is great. (...comments coming after a recent long haul down south in one....) X-Type is basically a Ford Mondeo chassis with a 2.5 Ltr V6 and a Full Time 4WD drivetrain. Not too sure how good it is but the Maintenance and wear and tear on our roads would be a lot more costly than the Bimmer.
Hey Buddy, In case you didn't know, you don't have to actually go to hikkaduwa to collect license. You simply pay the fine at a post office and send the voucher along with a self addressed envelope by registered post addressed to the Traffic OIC. Give them a call a couple of days after sending it to re-confirm. That's the way I did it the last time (also caught "speeding" in Hikk.) and there was no hassle. It was the cops themselves who told me how to do it,.. gave me their phone numbers too..... unfortunately i threw it away after I got my license back
Nuwara Eliya Road Races
Seriously man, With 5 on board, the handling of your car would be pretty different to what you're used to, and you would carry some serious momentum when approaching tight bends. Lots of us tend to over estimate our car's capabilities in situations like this.... There's also the un-written rules of up-country driving like having to give way to the vehicle that's climbing. Quite a few colombo drivers are taken by surprise when busses and lorries drive straight at their face on the wrong side of the road and then blast you for not pulling to the side of the road to let them pass.
Agents Ripping Off Permit Holders?
That's basically because of the difference in climate between europe and sri lanka. Brand new european cars are usually tropicalised before importing here. During this process, components made out of materials which would deteriorate due to our climate are replaced with ones which would withstand the heat better. (Plastics, leather, rubber etc) Cooling systems and Air conditioning systems are also upgraded. Suspension set up is also changed to suit our roads. Fuel systems are modified to suit our petrol. All that said, at times the tropicalisation done on the brand new cars is not enough. Occasionally things start to go wrong with these things just after the warranty period expires......(Interior trim, hood linings, fuel pumps, etc)
Upgrade Headlight Bulbs In E39
Did you use a HID Solution for the H4 Bulbs (with Both High and Low beams) ? And how much did it cost ? Actually my 1987 Sprinter Cielo (AE91) had the bulb failure warning lights, but I think toyota dropped the feature on the subsequent models....
Recently heard of another side effect that could be caused by fitting non-standard HID Conversion Kits. Apparently on cars fitted with Headlight Failure warning circuits, the Headlight Failure warning lights come on due to the extremely low power consumption of the HID Bulbs. Therefore an additional capacitor has to be fitted to ensure that a minimum power is drawn to avoid tripping the warning lights....
Yes, The ones of reputed brand (Polarg, Raybrig, PIAA, Phillips, Osram etc) actually do produce a brighter light with the same heat as the 55w, while their high wattage bulbs are clearly marked 'For Competition Use only'. The cheaper unbranded ones you get in Darley road end up frying your headlights and electricals. I learned the hard way - my bulb holders had actually melted.... Presently using PIAA bulbs which I got down from Japan. Also the filament position and fitting of the genuine competition bulbs is slightly different to the standard ones, and may require minor modification to fit and also headlight beam re-allignment to avoid dazzling oncoming traffic. Alternatively, D*MOs and their dealers have quite a wide range of OSRAM bulbs including the Silverstar and Cool Blue range at a very reasonable price. But all the reviews I've read on the web rate the Japanese premium bulbs very much better than the equivalent european ones. For the E-39 you might also check with Milroy as I've seen a number of branded bulb types in his stock.
Exactly what I was about to say... the Competition spec bulbs should be used only on lights with Glass Lenses as a plastic lense would discolour quickly after prolonged use. Even the reflectors melt on the newer 'Crystal' type lights if the heat of the bulb is too much to handle.
Family Sedan
Hey, the N16 Signal Lights are just as easy to steal as the B15...... They've even been stolen off of the WP-GI series police cars.......
A/c Evaporator Coil Leak
The level of cooling you would get from the malaysian / korean coils is considerably less than the original factory fitted ones. Actual length of the coil, number of cooling fins, material it's made out of is different. If your car is fitted with an electronic thermostat, that too may not work properly if the coil is changed. You may want to consider fitting a second hand original coil (which should of course be properly checked out before buying). It would also be cheaper than the option you have already checked out.
- Audi A4
Weekend Drives
He, he.... we did the same trip (Horton Plains and all) a couple of months back in a 320d, and when we got back to colombo we had done 700+ km and still had quarter tank of fuel left......
2008 Subaru Wtf !!!!
Profile Looks a lot like a Liana to me.....
Nisssan Tida
Took the new 121 Corolla for a quick trip down south last week (a run which I usually do in my Nissan Wingroad or Bluebird) Comfort level was nowhere near that of the nissans..... got back extremely tired and with plenty of body aches due to the uncomfortable seats.... Talking about the handling of the nissans, Wingroad was a bit spongy when I bought it 4 years back. It had 14" rims and narrow tyres. Upgraded these to 15" with 205/65 rubber and it worked wanders for the handling and stability of the car. I chose the rather high profile because I needed to increase the ride hight to stop the bodykit wearing itself out by rubbing on the road and the tyres solved that issue as well. On my third set of tyres now and I went for 195/65 profile this time (because I found there was a bit of rubbing in the wheel wells when cornering hard) and these work just as well.
Nisssan Tida
The similarity to the renaults is because it is actually based on the previous generation Renault Clio platform. The clio is basically a car which can be compared with the Nissan March, so it's a little sad that the replacement for the Sunny is based on a smaller car. Having actually seen one up close, I must say that it is exceptionally spacious for it's size though. Head and shoulder room is excellent. It uses the new nissan HR series engines (replacement for the QG) so hopefully they should have sorted out the inherent problems the QGs had with the ignition sensors.
Speakers
That's right, the normal car stereo amps won't match the impedance of the home stereo speakers. After some time either the amp or the speakers will go bust.
Comments About Yesterdays Accident At Induruwa
What I've noticed since of late down South is that the traffic cops come down very hard on cars and vans going over 50 but simply ignore speeding busses and lorries. One cop actually waved to a bus that went speeding by while his OIC was writing out the speeding Charge sheet for me. (Yes they actually had a table by the side of the road with a constable and the traffic OIC himself there writing charge sheets...... ) Didn't bother wasting my breath asking them whether they didn't think that the bus was speeding...... Some companies in Sri Lanka (mostly multinationals who have to follow their corporate rules) have mandatory advanced driving training for their heavy vehicle drivers and some even have motion detectors fitted to their lorrys which actually monitor and record each journey. If a driver is found to be speeding, braking excessively or driving erraticaly he gets the sack immediately. When I first heard about this I thought it a bit excessive, but I guess its better for all concerned if more transporters follow suit.
Newbie Ae100 Sprinter Help
I ran a 1987 AE91 Sprinter Cielo for about 4 years some time back and it was an excellent car both in terms of performance, economy and durability. It had a 1500cc 5A-FE narrow angle DOHC engine - which is essentially an economy tuned engine, and a 5 speed manual box but with a little tweaking and a straight through exhaust I was able to get 10 km/l in colombo and some pretty decent performance when I put my foot down. In fact I used to enjoy making many a eg8 eat my dust on the open road..... If yours is a 1500, I think it will have the same engine. You can check the valve clearances but it's a shim type engine so there's not much you can do to adjust it yourself short of fitting new ones. My advice would be not to mess around with that unless you have a noisy valve-train. I had a bad experience with a reputed garage botching up the job when I needed to replace two burned valves (result of hard driving) and had to spend three times as much getting the job re-done. They had actually ground the valve stems because they couldn't find the right shims. As for tuning, there's not much to be done if it's EFI, you just have to make sure your Injectors, spark plugs (stick to Denso) Air Filter and Plug Wires are in good order. I ran it on 95 Octane and used a good injector cleaner added to the fuel once every 6 months or so. If your milage is high stick to mobil or Castrol semi-synthetic. Mobil XHP Mineral Oil is also an excellent alternative and it'll be much easier on your purse. For Air and Oil filters, just stick to the Genuine Toyota ones and you can't go wrong. For the spare-wheel bolt, the best place to try would be one of the pavement stalls down Panchikawatta. However be prepared to bargain and be patient or they'll rip you off... Otherwise any good lathe works should be able to turn one out for you easily. All the best with your new Aquisition !
Where Can I Get A Durable Snail Horn?
I've used Hella on my last 3 cars and had no problems with them. However you need to be careful to fit them in such a way that water cannot get into them (either splashed from oncoming cars or in a high pressure car wash). They are rather delicate in that sense and as they are sealed, there's very little you can do after they get wet. Alternatively there is an Indian brand called 'Roots' which I fitted to the Mini over 10 years ago and it still works just fine. I think it's the same one that comes on the ambassador cars. You can take them apart and clean them when required and also adjust the pitch as required.
Autolanka Funniest Moments
I Guess the picture below clearly demonstrates why you should entrust sign painting only to guys who understand the language...........
Peugeot 407
Actually the new Santa Fe looks pretty good and judging by the reviews it's got in Europe and Aussie seems to be a decent drive as well. Has anyone tried out the diesel ? Getting back to the topic of the 407s, I've been examining a number of them closely on the road, and from what is visible from the rear the undercarriage looks pretty untidy with all sorts of bits and pieces protruding out below the rear crossmember. - a recipe for disaster on our roads.
Peugeot 407
Hey Guys, Going through the papers last Sunday, was very surprised to see the number of Brand New imported, registered Peugeot 407 s (including diesels) put up for sale by their owners. A number of them were even advertised by the agents. Is there something wrong with these cars, that their owners seem to be dumping them so hastily ? Or is it simply that they are pre-price hike imports which the owners are trying to make a fast buck on ? Anyone know anything about this ?
