tiv
    89
Everything posted by tiv
  1. I saw a car just like yours at kandy suvasevana hospital a few days ago, was it you? Looking good! Also a variant of Vitzs came from factory with a similar wheel design including my wifes one They are enkei 14 inch, I'm not a fan of these , will be swapping them for 17s soon
  2. This works but the fuse is not shown here also the stock horn will have only a 12v lead, will mostly be self grounded.
  3. Do not use that, expensive to fix if you burn something or if the horns screw up. wiring directly to the integrated hifi relay, may maynot go well depending on the load set by your horns so to be safe use the oem line as a trigger and fix a new relay with socket separately, that way the car is always safe. You can always go back to oem with just a scissor. do not go to stuff that relay inside the factory boxes, anchor it elsewhere. Use a relay with socket always. Get the power feed to the relay from the battery with a fused line with the fuse being like 2cm from the battery terminal, throughly insulated and zip tied to a place. 10A fuse is enough then ground the relay to a nearby nut, take the power out from the relay and wire up your horns, if the horns have 2 pins, clip 2 ground wires to the horn and secure that ground to a separate nut, not the nut holding the horns to the body, if the horn has any openings face them down as water pooling inside will damage the horns. use zip ties, clips and crimping tools. Do not attempt if you are not confident. Double insulation on normal wires, triple insulation on joints. The above way bth 12v feeds going into the relay are fused, thereby nothing can short circuit. cars aRe constantly moving And getting wet, so wiring is a bit overdone unlike static indoor wiring at homes also that battery tap wire with the fuse that you set can be used for all future mods, ie car amp, fog lights, light bars, more horns, neons, whatnot Just need to 1 up the fuse when needed to match the load. using wiring capable of at least taking 20A
  4. 407 => 4.5 mil => RUN
  5. tiv
    Landsail Tyres
    Is tyrebass .lk reliable???
  6. tiv
    Landsail Tyres
    Yes true, they bring some of the awkward tyre sizes, that being low profile they’ve found their way into may aquas g sports and even older mercs. Locally they’ve become Popular with ricer boys running large rims lol
  7. tiv
    Landsail Tyres
    I've heard many reviews of these being good tyres, theres a big local demand as well, yet to use them though Another underrated brand is Westlake, they arent bought down now.
  8. Most cars dont come with relays, and most of the entry level models come with only one note/ single horn. People do this different ways, including just running both the horns through the existing wiring. If you do not have a factory relay to hold the load, Doing this u can blow a fuse, or heat / melt up the wiring, and also burn the horn switch inside the steering wheel. Also the horn wont be loud enough piss off the fellow in front. The safest way to do this is, not to meddle with the factory wiring even if there is a relay, just make a new harness for the horn, a separate relay, triggered by the horn with supply direct from the battery via a a good fuse link. High quality wiring, clamps and crimping is a must with 1 layer of insulation and 1 layer of heatshielding/ braiding. And zip ties to anchor the wiring. Crimping and heat shrink it's better than soldering, if possible or atleast solder, do not twist wires and tape. If you do have a relay in the factory loom, you can just split the existing line and upgrade the relay in the fuse box for your new horn set. Try to get Bosch ( not that knock off yellow tin BEOSCH) or Hella, I've been using them for decades with no trouble, mostly hella- over 15 sets in different cars now. So called Toyota premium horns sold by vendors are a joke to me. If you are not competent pls dont attempt it, as you can always pop an airbag or burn your car up or hurt the ecu, or wiring loom. Abd thus If you arent into DIY, Give it to a good electrician and watch him do the above steps.
  9. I use a Bush mechanic from the Katugastota area for my work, anything Mitsubishi I give to the agents. If u are interested I ll pass the contacts But its not a posh joint, small place in a narrow road, but will know your car in and out
  10. So I have this habit, I go up the hantana range to a secluded spot way up in the hills and fly my drones, I do it almost every 2 weeks in my montero sport. Since my car is in the garage being painted, i took the family Montero v98
    Seems the ground clearance is lower than the Montero sport that I managed to peel or off the rear bumper costing 90k for the fix, a ledge that I cross frequently
    Dad has been swearing since morning now. This is gonna be a fun weekend
    1. Show previous comments  8 more
    2. tiv
      tiv
      @Gummybr will pm u
       Your Jimny will hop through it no issues.
      @Hyaenidae some bits like clips and all dont move that much ne, they are out of stock
      @Magnum the way the suspension behaves its totally different in the 2
      Lot of overhang in the pajero, ands heavy
      If u loose traction on a slant it will start to sway and hit something.
      This weekend I went in the vitara, she managed without any issue. but I was super careful. Had a spotter to watch tricky places n all
      To add I have 265 75 16s on the montero sport, AT one size up than standard.
      Whereas my dad has 265 65 17s on the montero, almost a road tyre
      The vitara comes with 215 55 17s again road tyre but is way lighter and nimbler,
    3. fiat fan
      fiat fan
      @tiv thanks for the detailed explanation. The phantam 3 series isn't available anymore. Most are used by now.
      I would like an Air 2, but I can buy two mini's for the price of one Air 2. Is it worth the extra cash?
      Also whats the situation on drone regulations now?
      The mini is under 250g, so the FAA in the states. has no issues(under 250g considered a toy). Is it the same in SL? Internet search has hazy information.
    4. tiv
      tiv
      Phantom 3 s are available, as they are constantly refurbished, there are guys who sell them as brand new.
      Unless you are a drone geek, no point on investing on an Air 2,
      start with a mini, but the thing is now minis are so rare, due to import restrictions.
      noobs who bought em crashed them in days, so a mini can go upto 130 with combo kit new now. Used ones at 105, 110 with come 80s with standard pack.
      anything lesser is broken as it has no sensors and is tiny and fast so fellas tried to kiss walls.
      Anything with a camera has to be register3d as CAA, so u got to do that online, and they give u a date to come show the drone. They put a code on it, thereafter you got to pay to fly it aka getting a permit.
      i do most of my flying in private property with permission thereby I don’t have to pay for permits, but I have registered the drones through the site, was not called for an inspection to date for the mini.
      The mavics don’t grasp attention, mavic mini most think it’s a toy, thus no one goes to register.
      phantoms on the other hand Attract hooligans to cute chicks to dogs. Then after like 30min, battery dying; a cop comes by
  11. I've noticed Defender values are plummeting
    Any particular reason?
    Lack of parts due to import bans?
    Or has the 2020 plastic sculpture affected the value of the old one???
    1. Magnum
      Magnum
      I think because of the new one, I heard one or two came down to SL
    2. Kavvz
      Kavvz
      Interesting as the new defender is completely different...I was actually figuared the opposite: The old defender would hold its value and the new one would drop in value due to a lack of sustained demand! :D
  12. Gosh this is an enormous amount of bullshit for a small repair, 600k? Gosh you could have bought a speedbike And the sub par work they've done, invain you could have taken this straight to the owner, actually who is a friend of a friend. I'm staying clear, my Bush mechanic seems to be divine compared to all this.
  13. Has anyone recently used CARS Paint shop kandy ? Their reviews in the past haven't been the best but I am being told by colleagues they are good now.
    Need a booth paint, stuck with primer due to the weather,
    1. Show previous comments  5 more
    2. fiat fan
      fiat fan
      Yup that one.
    3. BlueRaiden
      BlueRaiden
      Dont go to sewwandi auto paint polgolla. They do have a booth but the workers are careless.
    4. tiv
      tiv
      Decided to go with my painter, will wait till the weather improves
      Way too many bad reviews on cars after digging around a bit.
  14. During my accident chaos, the offender was a imbecile with a learners permit. As his stunt nearly killed me and almost took out a house with people, I was told by the police that if taken to court he may loose license permanently, And with a strict magistrate or poor defense can end up in jail for 2 years tops. Reason due to endangering lives/ gross negligence I cannot comment on the credibility of the above as it was not a lawyers word. My lawyer was like let’s sue him and the Lorry owner and buy a new Jeep lol.
  15. Jag Xf; I’d except it to be more troublesome but the Audi A6 and BMW 520d are fairly cheap to maintain cars, and with almost no issues, like I said a hybrid cayenne will be heaps more expensive to maintain than the above. If you like the exotic market, if looks aren’t a problem, and IF RUNNING COSTS ARE IMMATERIAL then go for it. Don’t attempt it even with a 6 figure Sum set in your head for maintenance And repairs, it will disappoint you.
  16. The fact that you are concerned about the maintenance cost and looking at independent garages is a giveaway that it’s a financial mistake, for expensive motors like these expect at least 1.5 times average Late model merc ownership costs, let alone repairs. At least 1mil, in maintenance a year, given u run liberally, with just maintenance, NO REPAIRS besides people are running away from aquas with hybrid batteries why would u want to be stuck with a pointless hybrid from an exotic manufacturer with deficient support just because they came in cheap through a loophole and now they are cheap for the obvious. Don’t board a sinking ship mate.
  17. This must like be nirvana when compared to the vitz, pretty car Congrats. something I’ve always wondered, do they do the facelift here, to the latest model, I’ve seen pakistanis or Bangladeshi troops going at it. +1 on the alloy wheels, many perks
  18. Anyone know of a place near kandy or nearest to get stuff chromed for a bike?
  19. Replace the rack mate, these repairs don't work long. U can find a recon one for cheaper in delkanda.
  20. My Montero Sport Saved my life today.
    Took a T bone collision to the rear quarter panel, from a lorry, the thing came straight to the drivers door. I accelerated and saved my self, just got discharged from the hospital after a checkup,
    No matter what new fellas say about crumple zones and what not, this thing is proper weight to weight. Just realise how strong these suvs are. Just a  large bump and I drove it home. Amazed realising it took tg awhile weight and was shoved to a side.
    The lorry was a proper mahiyangana sand lorry, full load, the c**t was driving on a learners permit, couldn't control his reverse into the construction zone, lost control and rolled right onto me down a slope, face first. If I was in my vitz or a smaller car, I'd be in a morque now.
    Cops took over the lorry momentarily but I deferred them.
    Repair cost approx 100k, given I need a new wheel arch and tail light. And its pearl white, expensive bitch to paint.
    Despite my parents and friends deciding to ruin his life legally, the driver is in the hospital after negotiations but I am not pressing charges or taxing him for the repair, as he will loose his livelihood and be in jail.
    Best part is, if the car rolled over, I would be in the mahaweli river.
    Dear friends, please give up smaller cars when money permits. Get something large and safe.
    Due to privacy concerns I am unable to share pictures.
    1. Show previous comments  11 more
    2. ghostwriter
      ghostwriter
      glad to hear you're ok and it may have been your luck that you decided to take the SUV instead of the smaller car when you went out.
      would have been better if you decided to press charges just so the person gets to understand the gravity of the risks they take without consideration on others' lives. he got to walk away with no hindrance today might result in him taking someone else's life in another day, doing the same mistake.
    3. fiat fan
    4. Magnum
      Magnum
      Glad to hear you are okay
  21. They even alter mileages of the CLA and C200 2019, sadly we have very poor examples as agents with a buttload of crap or indian waste being offered as brand new cars, hence these crooks have become the most well off society in this country.
  22. My budget was 7 to 7.5, I was trying to purchase it while keeping my old one, I could scrape up enough, for 3.8l As for the 3l, couldn't find a good example I even tried looking for the petrol 1st gen montero sport, Devindaz even guided me onto a few, never found one good enough, I'm not picky but atleast 50% reasonable condition is a must This one, 3.8l v6 with massaging seats, theres a handful here , it's got Rockford sounds as well. I've seen black and grey ones Those are JDM, distinctive 18 matte wheels and got a few extras. You ll turn the key again while the engine is running. It's that silent. And in tune so well, spurting water off the exhaust. Just ask unimo, they know The one I went to see was owned by a well off businessman, he was quoting 8.5 and was not bothered to even discuss a deal, well off budget. I'm not sure if it's worth the number. Mileage was 115k ish The 3l v6 ones go for 6.5 to 7mil, I guess the ideal no would be 8mil. It was like it rolled off the factory yesterday, that good, was sold within the week.
  23. Reliability Diesel and petrol in our context are equally reliable, If fact ive seen lesser problems in the petrol one. Diesel 4m40 has all the classic 4m40 issues pls search and most are manual 3.2 l 4m41 needs super diesel, timing chain kit issues are common, typical diesel engine hoo haa, pulley bearings etc The petrol one is super smooth, but not that gutsy. Gearbox feels pretty much the same in both. Both are equally noisy 2 to 4kmpl and 95 oc is advised , pls do not get optimistic on the fuel figures, they are not cheap to run, do not buy If fuel economy is a concern. 7kmpl is highly exaggerated and hard to reach even in a diesel The main problem is most of these vehicles are poorly used and maintained by cheap skates Run on poor quality petrol, mileages clocked back. Masked gearbox issues, hidden CELs, skipped preventive maintenance Poor botched repairs on suspension etc So find a good one and u are set for life, or look for another car. Dont try to get the cheapest one in the classifieds. I own a diesel one for ages, looked for a petrol recebtly one, and gave up due to the bad examples in the market. Do not buy a lemon keeping a margin of like 500,000 for repairs, bits are far more expensive and some repairs can only be done by the agents. Instead search hard and find a good car To add there is a marvellous 3.8l petrol variant, tight as a drum and super duper smooth, extremely silent but about 1 mil more expensive
