Sylvi
Everything posted by Sylvi
  1. 'Tilvin', How big the crack is, it on your driving area, if it is a small crack it can be repaired by using resin Sylvi Wijesinghe.
  2. 'rameez', Answering your last Question. Mr. Fernando do tuning of cars his father did this for long time then he took over from his farther. Sylvi Wijesinghe.
  3. 'VVTi', You are totally correct on the above post. Drilling the body is not necessary. Can use good Epoxy 5 minutes rapid adhesive like ARALDITE or FEVICOL. This also will not allow anyone to remove easily. Sylvi Wijesinghe.
  4. 'mahasenh', If you use a very small self taping stainless steel screw it is better than riveting the Badge. I do that for my Badges. "Sunlanka" (who used to do this those days), Yes they are correct riveting gives extra pressure on the Badge stands a risk of the badges being damaged. Sylvi Wijesinghe.
  5. It is better you call me my login name Sylvi ineted of any other relatin ship I help you as you wanted help from the forum members. Sylvi Wijesinghe.
  6. Tilvin, The coil you can buy from India they are prepared to ship out you have to transfer the cash through bank pay the freight here to DHL. REPLY I GOT BY EMAIL FROM INDIA THE LINK I GAVE TO YOU. 888888888888888888888888888888888888888888888888888888888888888888888888888888888888888888888888888888888 2400 plus tax and frieght Sent from my BlackBerry® on Reliance Mobile, India's No. 1 Network. Go for it! From: Wijesinghe <[email protected]> Date: Sat, 30 Jun 2012 17:44:25 +0600 To: <[email protected]> Subject: Hindustan spares Spare parts manager, Can you ship out a new Ignition coil if I give you the part number as under. Can transfer the cost before the shipment with air shipping cost by telegraphic transfer or by bank draft. Hindustan Ambassador Classic MPFI petrol which comes with Ignition Coil - 0221503407(Three Pins Model). Please do communicate by email with possibility.As early as possible like to have your telephone contract number Your're truly, Sylvester Wijesinghe.
  7. 'tilvin', Try tis web page address for spares. http://www.hmambassador.com/parts-dealer-locator.asp?strdealer1=MUMBAI Sylvi Wijesinghe.
  8. 'tilvin', It is possible to rewind any Ignition coil. I used to do these thirty years ago. But I am on a different automobile service now. Can you show the coil to me I will try to give you some solution for the coil. Winding wire and insulation cost today will be around Round rupees 5000/00 and labor I cannot estimate. Try to get down one from India. that will be the cheapest. Sylvi Wijesinghe.
  9. 'akboselk, According to your post I understand you have a car Manufactured in 2011. So your battery must be under 24 months. Because the Marutis are imported to srilanka and they are in their yard for some time before they are registered and given to buyers. There is no difference by trying to install a bigger amperage battery. Only thing the cost is little more expensive. I use a maruti van with a 35 ampere battery done little over 12000 KMs. So far no issues, regularly test the battery water level. My advice is to as you have recharged the battery wait for few more days and see the battery will go down again. Did you test the battery drain when everything is off switched on the car, that is very important if there is a high drain then battery can go down in few days? Some times there may be a fault in the battery you have. You start the car daily run for few min then stop the engine. OR have a small battery charger connected to keep the battery full allways. If you want to buy a new battery go in for new Maintance free Battery. Sylvi Wijesinghe.
  10. 'The bird on water', Try heat shrink Raychem rubber tubing. Can buy at electrical stores in Pettah on Maliban street. You can buy 6 inches two raychem tubes and use one first use a heat to shrink one then use the other one do same like early. Sylvi Wijesinghe
  11. 'Ripper', This person had not fitted the unit. he has some dificulty of connecting the A wire. Sylvi Wijesinghe.
  12. 'akboselk', Go to an electrician and get your alternator charging rate checked up it should be 14.5 volts when you accelerate the engine. Check at the same time any discharge when you stop the engine. Electrician should have a mille ampere meter to check that. If there is a high draw of current when the engine is stopped then there can be a battery drain in few days. Sylvi Wijesinghe.
  13. 'RehanaA', At last you procure a car. Best wishes is it new or used in Japan unregistered or registered one in Srilanka. I hope this thread will not run into few pages like what you started early. Sylvi Wijesinghe.
  14. Did you sort out your problem Ithink you called me in the morning. Sylvi Wijesinghe.
  15. Members, Today Lankadeepa news paper page 12 Carmart had advertised to say they still are the agents for Mazda vehicles and carry all spares this is a bogus story to say they had lost the Mazda agency. Sylvi Wijesinghe.
  16. Don, I have a Indian omni van. No more Chinese van I sold same about two years ogo. In side tire wastage of front driving side I notised after 10000 KMs. Sylvi Wijesinghe.
  17. 'don', The agents said it cannot happen as these vehicles are done to international specs and caster is pre set but when you test the caster it is negative on driving side wheel. Only thing to do is remove bottom arm and cut into two and have a adjustment bolts on a improvised plate with long slots on the bottom arm so it can be adjusted which is a time taking matter. To cut short everything I made three new holes on the body chassis and took the shock with the spring out by 2/3 rd of an a inch Then it came to the left hand side wheel measurements. Must run few thousand miles and see the difference. Sylvi Wijesinghe.
  18. 'Amila G', Yes you are correct. I had driving side tire wasting on inside. They wanted to me to take the strut shock absorber little to words outside I drilled three holes on the Vehicle frame and fitted the same it was corrected know both front tires have the same measurements. Sylvi Wijesinghe.
  19. 'soulja', There are so many kinds of oils invented in the world but never got on the ground level if you go on surfing the web. I think most of them were only done the experiments but like the Petrol Dieseline nothing were permanently existed so far. Sylvi Wijesinghe.
  20. 'Sira', Go to Nalaka next to Arpico show room First turn to left after Ibbavala traffic lights At Union place junction from eye hospital junction. I try the Wellawatha galle road near Savoy theater on the other side of the road as that place was recommend by the forum they could not do my Caster adjustment. Sylvi Wijesinghe.
  21. Jay Serasinghe', There are some welding transformers have this facility with DC 14 volts tap on the out put side of the wlding winding which is 40 volts AC. If you have a welding transformer this can be done with a 200 ampere diode to convert to DC. IF you want to make one buy a old welding transformer with a good winding i will help you to do same. It is 100% safe will not damage your electronics due to 14 volts DC. Or the voltage can be redused to 12 volts on the jump charger. Sylvi Wijesinghe. Sylvi Wijesinghe.
  22. Members, Few days back there was a advertisement i got on email that Indian company had deloveped a magnetic fuel saver and they are looking for a agent in Srilanka. So i respondered to the advertisement they were wery keen in sending a demonstrator with few samples which i have to pay for all expences in srilanka so I requested the cost of same it was indian (So your price Rs 900=00 per Single unit.) and wanted me to market same. I requested the test reports from Indian automobile authority they werre not having any of those. only to say they have sold few thousands of units with satisfied customers. I told them this is a scam I have tried this it is not working. After that they were silent with no reply. I do not know Damsha is a member of this forum if they give me a free unit I witt try out and give them publicty. Sylvi Wijesinghe.
  23. 'Clark's son', Is it the new battery came with the car or replased early. Sylvi Wijesinghe.
  24. 'VVTi', Did you realy fixed it? Can you explain is it on town running or country. Sylvi Wijesinghe.
  25. NPP, You can email me on [email protected] or contact me on 2573690/0712222420. Sylvi Wijesinghe.
