The Stig
Everything posted by The Stig
  1. I dont think you do, OD is the 4th gear. It should be always on, no reason to turn it off unless say you are going downhill or need engine braking. Turn OD on and give it another go
  2. There is a guy called "dave computers" on GLK forum, get in touch with him. From what i hear his service is excellent and the price isnt too bad either.
  3. Ahhh hub caps getting his panty wet
  4. how exactly would revving the engine higher and using a lower gear avoid sucking in water ? arnt engines that are revving higher suck in a larger volume of air compared to a low revving engine ?
  5. L stands for "low" and is meant to be used when you are going downhill and want engine braking or when you are towing a big weight. S stands for "sports"; well i dont really need to explain what sports stands for do i ? Generally it delays the gear shifts and let the engine rev higher to make use of high end torque and horsepower. And please run a search, these have been discussed in depth before
  6. Gone are the days where people actually knew what they were doing. "hey my neighbor has a car i got to get a newer and bigger one" is the general mentality these days
  7. The Stig replied to MasterDon's topic in News & Updates
    Wow that was brilliant ! ! ! Good work SN
  8. I dont think this particular car came with an air bag. But even if it did i suppose the bag wont deploy if the the car skidded and hit the ramp sideways given the fact that this is an old car without many electronic gadgets to measure the G forces; but should have deployed if it was a face first collusion though. Ahhhh yes i think i have made a boo boo there, you must be correct
  9. Its got a beat barrel and shift light on the speedo Probably one of the "ricer" morons
  10. Hmmm interesting, so they dont give a gain at all
  11. Looking good max, any ideas for a front mount for the sti ?
  12. Wow you are really bad at maths, 300% of $3000 is $9000 not $38000. Do they have "tuition sirs" in US ? if so i recommend getting 10 of them for you
  13. I dunno how its now but back then it was only about 15% of the item, even now i dont think it will set you back more than 3000.
  14. How can you say "very bad record for long runs this season" when only 2 races have been completed ? ? ?
  15. Ai ai ai all this "koheda yanne malle pol" talks are hurting my brain. Someone recommend this guy a good doctor
  16. The unbranded stuff are still around for 6-7k but the original Philips ones i found were around 15k minimum. Most sellers only had 6000k but i wanted 4300k so i bought it even though the cost is a tincy bit high.
  17. Nope definitely not original, minimum would be around 15k. I got my kit from ebay and still it cost me 18k+ shipping
  18. Translation- i need some English lessons
  19. Why exactly should this not go under post whoring and be posted under a new thread ?
  20. VVTi pretty much covered the whole testing part i guess. Could be possible that its not faulty at all and it didnt trigger cause the change of speed from the impact wasn't sudden enough. Maybe the damage to the car was cause of debris fallen onto the car instead of damaging it by the head on collusion ? also if the impact was a bit sideways its possible that the unit disregarded the deployment, they are designed to measure g force in a head on collusion so an accident at an angle; say you slides and hit the wall at 30 degrees might have not registered properly on the unit. quite possible, its not perfect after all. Some cars came with a mechanical airbag sensor, they work simply like a clock spring. Those things were well known for accidentally deploying.
  21. Yep the newer ones have an accelerometer which triggers when the G force is a little higher than what a car will experience in say a hard braking situation. But older cars did have something called a "crush sensor' (not entirely sure of the technical term is), but i doubt the B4 didnt have an accelerometer sensor. You clearly have no idea what you are talking about. A crash is also a rapid deceleration ! The accelerometer measures the G force of the deceleration and takes a mathematical decision to deploy or not. Say you were going at 120 and suddenly braked and say your car dropped its speed to 85kmph that means the sensor registers it at 1g and , but if you hit a wall after that it will come to stand still in 1 second i.e about 3g and the sensor decides there is no way this cars brakes can generate such a massive g force (takes into account the sudden change of g force) and deploys the air bags. (For those who dont under stand what a G is; if you change your speed by 35kmph in 1 second you have experienced a 1g) So you dont necessarily have to hit and crush the air bag sensor in modern cars cause it measure the change of velocity, not if the unit had hit something or not. Judging by the speeds you mentioned i would definitely say your air bag sensor is malfunctioning for sure.
  22. This topic has been hacked to death [sortKey]=date&search_app_filters[forums][sortKey]=date&search_term=car+audio&search_app=forums&st=25"]http://forum.autolanka.com/index.php?app=core&module=search&do=search&andor_type=&sid=17ab0a643df139a68b47a7c908ff2f35&search_app_filters[forums][sortKey]=date&search_app_filters[forums][sortKey]=date&search_term=car+audio&search_app=forums&st=25 Next time please run a search before opening up a new thread
  23. I dont think they would be too happy about fitting third party equipment under their name, some also give a warranty so i dont think they can guarantee the quality of third party parts.
  24. Well you know what they say " bere bandagatha num gahana ekai athe"
  25. Hey MG didnt see a pic of the project in a long time, would love to see some snaps of the progress
