81
Everything posted by Rumesh88
It is normal to feel some blow-by pressure if you hold your hand on the oil cap but that's not the way to determine that you have an issue with the engine. However, it is a good idea to get your PCV value checked or still better to get a complete tune up done.
Get the injectors cleaned and tested first because then you will know whether you would have to relace them if you decide to go for an overhaul.
You need to do an ultrasonic clean up and a test for the injectors for better results. Search the forum for keyword Asnu for the experience of those who have done it. Asnu is the brand name of a test rig for injector cleaning and testing but also there is a place in Battaramulla by the same name. I will send you a message with details of couple of places where you can get a compression test done. You will have to check with them for I haven't had any recent contacts with them.
That much of oil consumption is not alarming. If you have a knocking it could be due to fuel starvation. Get the injector washers checked for cracks due to thermal stress. If so replace them. They do not cost much. BTW make sure the mechanic has proper tools to remove the OCV filter because in most Toyota engines this particular hex-head is mutilated.
Removing/inspecting/cleaning/replacing if necessary of OCV filter and PCV would not solve the bigger issue. But still worth giving it a try if your oil consumption is something like 1/2L between services. It is not major issue.
I don't know exactly what happened to me trinity but it took me a long time to realize that my interest in automobiles has been on the sideline in the recent past. In fact I take more interest in the upkeep of my physique these days. My apologies to OP for going OT.
Agree with Ruslan's comments above. Just to clarify further, when you say you have a oil burning issue but there is no smoke, how do you know there is a oil burning issue? Does the oil level go down in between services? How much oil do you have to fill up? BTW did you get the OCV filter of your VVTi system and PCV valve either checked up or cleaned recently?
It is an open ended question. Whether it is worth or not depends on many factors. You need to find yourself answers at least for the following basic questions. What is your basic requirement of a car? A daily runner? How many km a day? Is fuel economy a concern? Is performance a concern? What is your budget? Does is match with the price of the car you have in mind? Have you left enough financial headroom for common issues like a possible traction battery replacement and ABS repair for example? I have a 2014 Axio bought at zero mileage. I intended to it sell by the first half of this year. But I had to shelf my idea because of my unstable financial situation due to Covid -19. So I decided to keep the car for one more year because for me it is worth and sensible.
He should not have disconnected the old battery without a back up. No that it is done drive for few more days to see if the idle speed settles down to its previous value.
Need Info on Getting Down Genuine Kia Spare Parts
Rumesh88 replied to YesinLegend's topic in General Automotive
Try this guy 0711281495, 0779935695. -
Just two questions. 1.What is the charging voltage when measured at 2000 RPM with all electrical loads switched on and off? 2. Do you use the vehicles mostly (say 90% of the time) during daytime an on long runs ( say 50km)? For the batteries to fail in the manner described there must be some contribution from your charging system.
Engine rough idle - EGR code and EVAP failure
Rumesh88 replied to Faizul Hasan's question in Mechanical problems
Get the EGR cleaned first. -
No. PCV is on the cam cover and can be removed easily.
- 11 replies
- ek3
- vibration issue
- (and 8 more)
Did you get the PCV valve checked and cleaned at anytime?
- 11 replies
- 1
- ek3
- vibration issue
- (and 8 more)
Was the battery swap done without a backup?
You need to get your car scanned before blindly replacing the ABS module. BTW where are you from?
When you say "engine oil burning" it is not quite specific. In every internal combustion engine - from brand new to used - there is some degree of engine oil burning. However, as a rule of thumb, in between services if you need to add more than 1/2 L of engine oil then it is a concern. If that is the case first thing to do is to do a compression test to determine if the issue is due to worn out piston rings or due to leaky valve guides. If it is due to valve guides you can get them replaced. But still depending on the age of the engine you may have to go for a full overhaul. I do not see a point in replacing the engine with a reconditioned one. If the compression test fails go for a complete overhaul.
Toyota Ist - Intermittent Ignition Knocking Problem
Rumesh88 replied to Tech Mate's question in Mechanical problems
Tech Mate is unlikely to respond because he has not logged in since 2014 October. What is the car in question in your case?- 32 replies
- ignition knock
- Toyota IST
(and 1 more)
I can't believe I typed 1 and 2. I must have smoked something. Corrections done. Thank you. 3. As for the piston effective piston travel yes the travel is shorter because the intake val.s are open. 4. You don't get exhaust fumes in the intake manifold unless you have an EGR.
The higher expansion ratio in an Atkinson engine compared to that in a Otto engine is a direct consequence of the lower compression ratio. Apart from that, there is nothing particularly done to achieve a higher expansion ratio in an Atkinson engine. The mechanical (ie the effective piston travel ) difference between two engines is in the compression stroke. As for the your comment on expelled gases, it does not contain a particularly high CO2 content. It is just the same air/fuel mixture at the intake manifold.
Check engine with engine miss in suzuki swift
Rumesh88 replied to maskventura's question in Electrical problems
Just don't go on changing parts when you can read the stored fault codes with a proper scanner. Those codes will give an idea. It could be the EGR valve getting stuck intermittently.- 6 replies
- suzuki swift
- check engine indicator
(and 1 more)
What the reduction in oil volume between service intervals like?Say if it is like 1L every 5000km then you can live with it or go for a oil at next viscosity level like 15W-40. However, just check the PCV valve for excessive carbon deposits.
- 6 replies
- high milage
- toyota
(and 1 more)
Bringing in electronic goods via BIA - HiFi setup
Rumesh88 replied to carboy2011's topic in The Lounge
Please refer to SL customs website. You get a higher duty free allowance if you do your hopping at BIA Duty Free. http://www.customs.gov.lk/traveller/home -
- 189 replies
- 1
- mitsubishi
- a72v
(and 7 more)
If you cannot play any of the channels check first if the antenna wire is connected at the back.
