maithri
Everything posted by maithri
  1. That was brilliant, First time I have seen the video-and I used to like them as a group. Must see if I can get a DVD somewhere. And I will get a cd as well next time I come to SL so I can listen to it as I drive past Weligama etc. Maithri
  2. maithri replied to neasmh's topic in General
    The chains are maintainance free-the lubrication is by the engine oil and the tension is set by automatic adjusters. Apart from regular oil changes no further action is needed, at the rate you change oil in SL at around 5000KM's the oil will hardly ever be an issue for the chain. In my view most of the current problems with timing chains are due to poor design, all the so called wonder boys had to do was go to the library and read up on old timing chain set ups most of which are still used very effectively by BMW and Mercedes engines, Why try to re invent the wheel-when the current one works very well! If anyone has a nissan with a QG16 engine have a look-they even tried to re invent the chain-a disaster-as the "chain" streches and causes the engine to run out of timing putting the engine warning light on as well. It makes little or no extra noise in this state but crops up as an electronic fault with the crank or cam sensor initially- be ware the repair in the UK will cost nearly £900 as the parts alone cost £400. Maithri
  3. The solution seems to have been self evident! I live in the UK where AC is relatively new in cars as well as in buildings! We strictly replace like for like and the only choice seem to be re conditioned or new. I do not know of anybody who repair or dismantle AC compressors outside specialist re conditioners. Most of our AC repairs are replacing leaking components and re filling the refrigerent Gas. after vaccuming and re lubricating the system. I can understand replacing a faulty compressor with one that will fit in it's place but it must also meet the abilities of the engine to turn it and the system to handle the pressure output. Otherwise the repair will not be effective and will be a waste of time and money possibly leading to further problems. Maithri
  4. maithri replied to neasmh's topic in General
    Timing belts are lighter in weight and cause less noise and need no lubrication. Chains in old 1970 etc. engines were more reliable but noisy and weighed more so not as fuel efficient. There are more pros and cons but at the end of the day cost seems to override everything else! The modern chain set ups seems to have forgotten all the lessons learnt in the old days, they seem to have very poor tensioners and seems to last even less time than a good quality timing belts. I see this on a weekly basis in cars like the Nissan primera and Almera, Vauxhall corsa's Volkswagen Polo's etc. These and many others end up with loose timing chains causing very expensive repairs. A belt maintained correctly will give it's intended service very well and other repairs like removing the cylinder head is very much simpler when a belt drive system is fitted whilst a chain system takes a lot longer to dismantle and the potential for oil leaks is greater after re assembly. So the argument seems to go on! I have little faith in the new timing chains used in the modern engines. But a well designed and fitted chain will give a longer service life in a well maintained car. My opinion of course! Maithri
  5. Have you done anything to the AC recently, is the change only when the AC is on and without the AC the car is normal? A little more info and doing the basics like checking the Air Filter and the plugs is certainly a good idea. Also I dont understand the codes FB14 etc. used in SL but try and say how old the car is and it's engine size etc. I will try my best. Maithri.
  6. Guys, some great songs and must say I have enjoyed a fair few in the past in my private world that used to be my car! One regret, How come none of you guys in Sl listen to any Sinhalese songs- I enjoy a lot of Sinhalese songs in my car and I know several people in the UK the same as me-I have a whole collection from Chandimal Fernando-Fantastic, Darmaratne Brothers-takes me back to the 70'S?? C.T. Fernando-I can sing most of these in the privacy of my car as badly as I do and not get booed, Latha Walpola-Sing them Too!- I prefer the uplifting baila and the up beat stuff rather than the more serious Amaredeva! Why??? You ask Nostalgia and the need to be part of something we no longer are??????? You need to try my wife's car radio-always blaring out some baila or ther inc.Mohideen beig! And my 5 year old daughter sings them too! Any suggestion on some Sinhalese Tracks for an up lifting driving experience-Guys please! Maithri.
  7. Hi all, Sorry I only saw this today, so did not have an oppertunity, how ever you seem to have tried most of the common reasons. Just 2 areas first for you to look at, Make sure the exhaust is not partially blocked-specially the cat. Also try driving the car with the Air Mass meter (Air flow meter) un plugged if this makes the car go really well your problem is almost certainly with the air mass meter or the wires or connection between it and the ecu. If these do not show a fault I would check the cam shaft and fuel pump timing-It's possible someone fitted the cam belt slightly wrong. These cars were not really well engineered so many problems crop up as time goes, added to that we no longer have a Dealership network through which technical problems filter down in to the public and the trade domains. I am waiting for some software up dates from my diagnostic equipment maker which I am told will bring my Rover and Land Rover diagnostics right up to date, I am sure a local company to you must have equipment like this-to my knowledge the Snap-On and the Sun systems are not really suitable, I am not sure about the Bosch kit, Mine is from a company called Actia and is very good on Vw, Peugeot, Renault,Vauxhall, Ford applications and adequate on Mercedes,Bmw etc. With the latest up grade I am told Rover and Land rover plus a few others are brought up to speed- so ring around and ask if the Garage has the kit or look for a Rover specialist or better still a Diesel specialist. Maithri
  8. Big does not mean safe and small does not mean un safe-watch F1 accidents I have seen some of the carbon fibre used to make the F1 shells-feels brittle and pretty flimsy, but very few drivers suffer major injury when in a collision. So This car needs to be tested. Then compared with European rivals like the Smart etc. The re is no real need for the motoring population in SL to travel in Hi-Ace vans when all they need is a car. If the thing cost less in running cost in real terms as in actual Foreign exchange rather than Tax then it benefits not only the owner but the society in general as well. So a "cheap Indian car" may be far better than a cheap pile of throw away Japanese rubbish ("re Conditioned" used Japanese car) In my younger days we used to Hark back to the well built European Morris'e Peugeot's etc, and laughed at the flimsy Datsuns and Toyota's. Look who's laughing now! So I think the time has come to stop looking at everything Chinese and Indian as cheap and poor quality and Join the Juggernaughts of the world economy and embrace some real progres. For all we know the Tata might be an excellent car for the South Asian markets! Maithri
  9. Guys, O2 sensors fail for many reasons but the warning light comes on mainly when the heater in the sensor is faulty. This is easy to monitor for the ecu so as soon as no resistance is felt it puts the light on but if the car is running ok be careful not to ignore it as the car will start to overfuel and cause premature failure of the cat and lead to excessive wear to the cylinder bores. How ever a cat is not needed in Sri Lanka to stay within the law-so as long as you have no second checking o2 sensor fitted after the cat it is not worth spending money on unless you want to be eco friendly. The cat does not perform any other function other than cleaning up the gasses emitted by the engine by converting co into co2. 95 octane fuel is common in the west and the O2 sensors generally last around 60,000 miles in good working order. If you test the signal output using a scope you will see the function starting to become erratic much earlier. So I would not blame the fuel unless you see a lot of different models suffering the same failure. Probably down to some poor quality engineering process used by the manufacturer of the sensor.
  10. Who told you George Bush was Human! Economic might and military might does not hide a morally bankrupt nation!
  11. Hi, Low profile tyres in Sri Lanka may be 55% etc but here in the west we would refer to 45 or below as low profile as 65, 60, 55, and 50's tend to be the norm for most car makers. They rarely cause discomfort or extra road noise. They are superior to standard tyres which have 80 profiles because they allow less sideways flex when cornering hard so keeping the footprint of the tyre intact in the road giving extra stability and safety. The lower profiles cut down this flex even further and were mostly designed for high performance cars like porche ferrari and the performance end models of the other car makers. The enhanced appearence of more alloy wheel and less rubber filling the wheel arch was siezed upon by the youth of today so we now see 1000cc 3 cylinder engine cars with fat low profile tyres making them look good but with poor comfort levels and the extra drag making them even slower and less economical! Flat tyres- I would refer to a punctured tyre that lost all or most of it's air as a flat tyre. I am not familiar with the model cruse from Daewoo(Cheverolet) What size tyres have you got and what makes you think they are flat or run flat? I can clarify if you give me more details. Added safety-when travelling at speed a tyre deflating or blowing out can cause you to loose control of the car and in the congested roads and motorways we travel in can cause serious danger to all of us. Run flat tyres keep most of their shape when the air has escaped from the tyre and provide much enhanced steering and braking compared to a completely flat normal tyre-in fact it's highly un-likely to make you loose control of the car even at high speed. That's why I said added safety. To look good buy a tyre and wheel combination that that fits your car without fouling the body-the more you cover the wheel arch the better they look says the styling guru's. Ideally from a technical point of view keep the same diameter or the rolling circumference as the original size so the gearing and the speedo reading does not vary. But this may not be possible as the original tyres may be too small to fill the area. So the styling decision is yours! The spelling-it's your choice to spell it the American way and mine to spell the British way-we are both right-at least in the free society I live in we can hold our own options!
  12. Don't rubbish TATA, the Koreans and the Malaysians had Japanese technology to start with-Tata had Mercedes-Yes! Jaguar's are currently Fords in Disguise mostly and the Land Rovers appeal more to the high end niche markets than the man on the street. Tata will reduce cost as well as selling the car to the massive Indian market through their local expertise-so opening a huge additional market for the product. After all business all about selling more for greater profit. So I am glad that the workers in the UK get to keep their Jobs and a load more Indians will get work as well as a chance to drive these well known brands. We the Sri Lankans Talk big, fight a useless war, and wait for the government to find us jobs to be paid with freshly printed money from an Indian printing press! Maithri.
  13. TIRES OR TYRES-FLAT OR RUN FLAT!!! Tires=American spelling Tyres=British (UK) spelling Flat- do you mean they look as if they need more air? That's normal appearance for Radial tyres-Do not over inflate due to the appearance check and set tyre pressures when the tyres are cold and use an accurate pressure gauge. The pressure will increase with tyre temperature so check before you drive the car too far at the start of the day. Run flat Tyres- Fitted to several BMW and New Mini models for added safety-in the case of the Mini due to the lack of space for a spare tyre. The car must be fitted with a tyre pressure warning system so the driver knows there is a problem with the tyres as full handling and brake performance is still impared if you have one tyre down. The ride comfort is not as good with run flats as the tyre sidewalls are very strong so road noise is also a little higher. Am I answering your query or rambling on? Maithri
  14. Hmm, Mark 2 escort-back to my early days I presume it is a 1970's crossflow engine? First clean the carb, make sure float valve is ok and it actually closes. Check the gap on the contact points(Platinum points in SL) and all the spark plugs are ok and in working order. By now it should run with minor adjustment to the mixture screw on the carb-set idle to around 800 RPM and turn in clockwise till the engine starts to run un evenly and then slowly turn it back anti clockwise till smooth again. If all is ok by now it should start to clEAR THE FUMES AT THE EXHAUST END! Oh! I forgot make sure the engine is warm and the choke is off completely before attempting the above adjustment. Now drive it around the local area and see how it runs. You may need to unwind the mixture screw by maximum of a further 1 turn to smooth out the acceleration. This used to be a basic tune up with a check on the ignition timing left out as I presume you will not be able to access a strobe type timing light. AND GET IT FIXED! You have a classic.-I am no Ford fan but these were easy to run and look after. And fun!
  15. maithri replied to neasmh's topic in General
    GUYS, It,s simple, if your car has a Timing belt change it at the correct interval, this varies from car to car and from one model to another even when the same code engine is fitted sometimes-there is no rule as to who fits timing belts and who dosent, petrol or diesel! On most modern engines if the belt brakes the valves will collide with the pistons and cause expensive damage regardless of any attempt to start the car-a whole lot cheaper and simpler to change it when due and sleep in peace. I have to price many jobs with broken belts and the cost almost always exceeds 1000 pounds sterling whilst the average cost of replacing the belt tensioner and the idlers as a kit is around £250. No contest! Imagine a Volvo S80 with all 20 valves damaged estimated at £2300 for repairs! If in doubt change it. That is the policy of a wise man/woman! Maithri.
  16. Hi, Do not attempt to adjust or fix your seat belt. These are not items that should be repaired. Just check and see if any object or trim is obstructing the belt. If you have a fairly modern car be ware as they have pre tensioners which can be an explosive. Yes, deadly if it goes off in the wrong place! These are mostly fitted to cars with air bags! Maithri.
  17. Thanks! I am starting to get the picture now. Beware though, some cars need the throttle initial position to be re set by using a diagnostic tool for correct operation. Do you get many cars with EGR (Exhaust gas recirculating) valves. These clog up with soot and carbon-I know diesel Pajero's from the mid 1990's suffer from this. Do the garages get involved with these? I clean these using the same brand throttle body cleaner as mentioned above with good results. The product range from them is wide ranging and in my opinion does what it says it will do on the tin. Maithri.
  18. Hi guys, What is a tune up? I hear that a lot of you have one done on your cars in SL. What do they do? Why do you need it? How often do you need it? To me a car built in the 80 or earlier allows some adjustments to Plug Gaps, Contact breaker point gap/dwell angle, ignition timing, fuel/air mixture and idle speed. In a more detailed way you could adjust the valve clearences-tappets as some of you may know it. A more modern car has all these controlled by the ECU which is the computer chip with all the manufacturers default data set by the car maker. So suggesting that these can be adjusted is not accurate unless you are talking about re mapping the ecu for enhanced performance etc. So again I wonder what this tune up is. By the way I am a mechanic and I own and operate a garage in the UK. Please enlighten me guys, Maithri. P.S. Your problem sounds like somebody interfered with the idle speed and left it idling too fast.
  19. Even cheaper Tooth Paste-which is also finer so a better finish-apply with slightly damp cloth-buff in a circular motion and wipe off with damp cloth. Maithri
  20. Strange to see that Honda is marketed for the youth in SL. Here they are almost always driven by Pensioners or elderly who had the market hype "Reliable" sold to them. So for us here a Honda is almost always driven erratically on a Sunday afternoon at around half the prevaling speed limit by a flat capped Gent and his ever nagging old lady trying to do the Knitting and telling him to slow down even more-so the rest of us have to follow or carry out slightly dodgy overtaking manouveres to get anywhere at all. The nissans have been taken over by Renault of france and the product quality is slightly lacking. Mazda's we see here are fine even though they are owned by Ford as Ford Usa style build quality is poor. Of the 3 cars I like the Mazda best as it's less common and has more chrachter. The nissans-No No! I am not quiet old enough for the Honda's! Maithri
  21. Hi, If you were here in the UK I would check that there is supply at the Glow Plugs on switching the ignition on from cooling down. If the supply is ok I would try replacing the Glow plugs. HOW EVER If you try and prime the system and the car starts properly every time afterwards It is very likely that it has a leak most probably between the filter and the pump or the pump itself. if you have some basic knowledge you can check the supply yourself by using a bulb from a indicator(Signal) light and a couple of pieces of wire. Solder the wires to the bulb. Attach one wire to the feed terminal of one of the glow plugs and the other wire to a good earth point on the engine. Now make sure the wires are seperate and the bulb is not touching anything metal. Get someone to switch the ignition on-The bulb should light up at least for a couple of seconds if the supply is ok. If it does not light up at all you need to find why-That's a job for someone who knows what they are doing. Try Maithri
  22. Hi Nilantha, May I suggest a different course of action-Ignore them-let the idiots engage in all this idle chat-let us celebrate the great man,s achievement which I have watched for the last 5 days waking at 4.15AM, Maithri
  23. maithri replied to Duncan's topic in SUBARU
    Try www.zenperformance.co.uk I am friends with the team here and see some very special ones-including the one currently in Japan taking part in the time attack series! 0 to 60 around 2.5 seconds. Look them up. Maithri
  24. Mine will be a Peugeot 203 from the 1950's. Looking at buying one now as it happens. They are pretty rare here in the UK and seems to fetch up to 10,000 pounds sterling for a top one. I cant afford that so the hunt-the one I am looking for is the wrong colour etc for that period, so will see how it goes. In nearly 25 years here I have probably seen one parked up. Never seen one being driven on a road. Maithri.
  25. maithri replied to Duncan's topic in SUBARU
    I saw a couple on sale at a local dealer(agent). Can't say the looks are special, but Subaru's never looked great just drove fantastic. No doubt I will see one at Paul's soon to be up graded so I will get a closer look. Maithri.
