Ekendra Edrisinghe Posted February 4, 2011 Share Posted February 4, 2011 The previous owner on the my vehicle had fitted HID Xenon lights using the old lamp reflectors. My previous vehicle had the normal lights and to me they seemed to appear brighter at night with greater night visibilty. My guess is that the old reflectors do not match up with the HID Xenon lights. Can anyone suggest a HID Xenon expert that I can go to so as to get this rectified? Quote Link to comment Share on other sites More sharing options...
0 H.C Posted August 4, 2013 Share Posted August 4, 2013 (edited) Yep, good deal. I got those unbranded ebay 3000k bulbs, wire, and two ballasts for 21$. But couldn't find mounting plates for cheap. Edited August 4, 2013 by H.C Quote Link to comment Share on other sites More sharing options...
0 Komisiripala Posted August 5, 2013 Share Posted August 5, 2013 here's the hi's and lo's. high beam. 3200K 35watt: low beam. 6000K 35watt: phone camera isn't the best... Quote Link to comment Share on other sites More sharing options...
0 ferrarif50 Posted August 6, 2013 Share Posted August 6, 2013 On 8/4/2013 at 6:50 AM, Charith H Jayasinghe said: How did they install projector lenses to normal headlights? or did you bought a headlight with projectors? Quote Link to comment Share on other sites More sharing options...
0 Charith H Jayasinghe Posted August 6, 2013 Share Posted August 6, 2013 (edited) On 8/4/2013 at 6:29 PM, H.C said: Yep, good deal. I got those unbranded ebay 3000k bulbs, wire, and two ballasts for 21$. But couldn't find mounting plates for cheap. Hope you can fix it with double sided gum stickers I mean the ballast. My previous kit was applied to inside wall above tyres. Edited August 6, 2013 by Charith H Jayasinghe Quote Link to comment Share on other sites More sharing options...
0 Charith H Jayasinghe Posted August 6, 2013 Share Posted August 6, 2013 On 8/6/2013 at 2:04 AM, ferrarif50 said: How did they install projector lenses to normal headlights? or did you bought a headlight with projectors? It was installed to existing headlights after remove front cover using a heat gun. Projectors were fixed to the reflector. They had to remove the cap like part extending from the reflector to cover the H4 bulb. Quote Link to comment Share on other sites More sharing options...
0 Komisiripala Posted August 6, 2013 Share Posted August 6, 2013 Bara stereos in Dehiwela had the projector kit men. Fits most lights. 27,000 with hid set and installatoon Quote Link to comment Share on other sites More sharing options...
0 H.C Posted August 6, 2013 Share Posted August 6, 2013 <blockquote class='ipsBlockquote'data-author="Charith H Jayasinghe" data-cid="244850" data-time="1375766689"><p> Hope you can fix it with double sided gum stickers I mean the ballast. My previous kit was applied to inside wall above tyres.</p></blockquote> Managed to fix them at home with thick wire ties and 3M double sided tape. But mounting plates would be neat and tidy. Quote Link to comment Share on other sites More sharing options...
0 Charith H Jayasinghe Posted August 6, 2013 Share Posted August 6, 2013 On 8/6/2013 at 3:22 PM, H.C said: On 8/6/2013 at 5:24 AM, Charith H Jayasinghe said: Hope you can fix it with double sided gum stickers I mean the ballast. My previous kit was applied to inside wall above tyres. Managed to fix them at home with thick wire ties and 3M double sided tape. But mounting plates would be neat and tidy. I didn't need a wire tie. I was passed nicely with sticker, I mean the size of large face of ballast. They were pretty decent. Quote Link to comment Share on other sites More sharing options...
0 H.C Posted August 7, 2013 Share Posted August 7, 2013 No machan , this is for the fogs. Ive two separate kits placed in the usual mounting area. So not enough room to paste them properly other than mounting vertically with mounting plates. Quote Link to comment Share on other sites More sharing options...
0 Charith H Jayasinghe Posted August 7, 2013 Share Posted August 7, 2013 Did you just fix hid for fog lights? Or with with halo rings? How much did the fog lights costs? Quote Link to comment Share on other sites More sharing options...
0 H.C Posted August 8, 2013 Share Posted August 8, 2013 (edited) yep,fixed 3000k h3 and those fogs have projector lence like glass cover, so no glare.(they are identical to komis fogs as Eg,Teg have some similar parts). Got them from Ebay. Total cost was around 10k including the tax.No halo rings. Just 2 hours of DIY as had to remove the front bumper,otherwise its just plug & play. Edited August 8, 2013 by H.C Quote Link to comment Share on other sites More sharing options...
0 Charith H Jayasinghe Posted August 8, 2013 Share Posted August 8, 2013 (edited) so you had to pay tax? how much? I've brought down some but yet haven't come across tax. I'm also planning to fix those. How much did they take to fix? Edited August 8, 2013 by Charith H Jayasinghe Quote Link to comment Share on other sites More sharing options...
0 H.C Posted August 8, 2013 Share Posted August 8, 2013 On 8/8/2013 at 8:12 AM, Charith H Jayasinghe said: so you had to pay tax? how much? I've brought down some but yet haven't come across tax. I'm also planning to fix those. How much did they take to fix? Fogs came in a bit larger box and had to pay around 3000rs for it. I installed them at home with some helping hand from my wife! Quote Link to comment Share on other sites More sharing options...
0 sampa Posted September 18, 2013 Share Posted September 18, 2013 I think the issue is with the Holder of the light. In Nissan there are few cars (FB15, wingroad ect) comes with "H4B" bulb type. Different is H4B holder is smaller than the normal H4. When you fix the normal H$ to H4B the bulb does not fix properly to the holder hence the light will scattered. I removed my exixting H$ and fix it to Allion which has normal H4 Holder. and it works fine. If you can see the bulb type of the regional bulb u had in you FB15 you will see the difference Quote Link to comment Share on other sites More sharing options...
0 Charith H Jayasinghe Posted September 21, 2013 Share Posted September 21, 2013 Not that actually, it is due to mechanism which use to create light. Halogen use heated filament and in HID uses an arc. Filament make light source over shape but arc more cylindrical(from Internet) and even in bi xenon uses single arc where as H4 uses 2 filaments. These deference makes light more scattered and ineffective in conventional reflectors. Quote Link to comment Share on other sites More sharing options...
0 kani Posted July 3, 2015 Share Posted July 3, 2015 hiim looking for a HID H4 6000k kit with warranty, or a CREE H4 LED kit with warranty, plz let me knw if anyone is therethanks Quote Link to comment Share on other sites More sharing options...
0 Kavvz Posted July 6, 2015 Share Posted July 6, 2015 (edited) kani said: hiim looking for a HID H4 6000k kit with warranty, or a CREE H4 LED kit with warranty, plz let me knw if anyone is there thanks Sorry I can't help you out right away with a name or location you can go to; but some locations in the Colombo area where you can go enquire are listed throughout this thread. Anyways, props to you 'kani' for : 1. Using the search function 2. Posting in a relevant thread 3. Doing all this on your first post. Good on you, and welcome to Autolanka! Btw: 'kani' where are you located? And when you say 'looking for a HID H4 6000k kit with warranty, or a CREE H4 LED kit with warranty' do you need it to be an installed unit sold with a warranty in Sri Lanka, or can you make do with a warranty on the product off the seller' ebay site / manufacturer's website? ( If its the latter you will have to check with the manufacturer or seller if the warranty is still valid if you have it installed yourself in Sri Lanka.) Edited July 6, 2015 by Kavvz 1 Quote Link to comment Share on other sites More sharing options...
0 shanal123 Posted February 25, 2016 Share Posted February 25, 2016 Hello, I want to convert my light from halogens to HID. I've already bought an HID kit (35w, 4300K). I'll be getting HID projectors next week. So basically is there any place that could do the retrofit for me? I don't have the tools to go about cutting into my headlight assembly and would rather let someone who actually knows what they are doing, do the job. Going through the thread, seems like bara stereos can perform the job? Any other recommendations(I'm in Panadura so ideally Colombo would be the furthest I'd want to travel to)? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Ekendra Edrisinghe
Top Posters For This Question
16
16
15
12
Popular Days
Feb 5
18
Aug 10
15
Aug 9
14
Jun 20
11
terrabytetango 16 posts
Charith H Jayasinghe 16 posts
Magnum 15 posts
kelum_wj 12 posts
Popular Days
Feb 5 2011
Aug 10 2011
Aug 9 2011
Jun 20 2012
Popular Posts
VVTi
Dunno about the all the HID conversions, but I sure wish that people learn NOT to use the High Beams in city running. I swear to God one of these days if I am in that kinda mood, I will crash in to o
terrabytetango
I can't stress this point enough, and I'm sure I've stated it before: Your car's standard halogen headlight will not properly reflect the light from an HID bulb. This is because of the difference in s
VVTi
I was a bit against changing in to HIDs but after a few days of constant night driving and seeing most of these monkeys in Allions, Elites and all kind of new cars and the absolute uneducated Godaya n
193 answers to this question
