Uditha88 Posted August 2, 2011 Share Posted August 2, 2011 Friends, Why is a car hard to start despite engine is hot or cold. (All time) Have to try about 3 times to get it started. No issue in running condition. Quote Link to comment Share on other sites More sharing options...
0 Crosswind Posted August 2, 2011 Share Posted August 2, 2011 Battery? Starter motor? clogged petrol lines? 1 Quote Link to comment Share on other sites More sharing options...
0 Uditha88 Posted August 3, 2011 Author Share Posted August 3, 2011 On 8/2/2011 at 4:00 PM, Crosswind said: Battery? Starter motor? clogged petrol lines? Cross, * If battery is week, no crank occur right? and also it'll affect when in running. * Starter motor (no idea) * Cleaned fuel system by a bottle or "wurth". (by driven by that bottle) (but surely it'll not clean the fuel tank, lines up to from fuel tank to fuel filter) **And also has a doubt that shit fuel victim Any idea friends? Quote Link to comment Share on other sites More sharing options...
0 Nirosha Posted August 3, 2011 Share Posted August 3, 2011 weaken alternator?. i had a diesel car and gave similar kind of problem. the alternator coil was replaced (recon. coil rs. 1300.00, charade g101). worked very well for me. Quote Link to comment Share on other sites More sharing options...
0 CyRaX Posted August 3, 2011 Share Posted August 3, 2011 (edited) Best is to withoug further trying to start up the engine bring down a mechanic and check.And based on what he says we could help you Edited August 3, 2011 by CyRaX 1 Quote Link to comment Share on other sites More sharing options...
0 The Don Posted August 3, 2011 Share Posted August 3, 2011 I'd say the probably suspects are 1. Faulty plugs 2. Faulty HT leads 3. Faulty ditributor electronic ignition system (check the wires etc) 4. Fuel pump 5. Clogged fuel line, filter or injectors 6. Sensors I'll try plugging it into a diagnostic system just to see if it picks up anything 1 Quote Link to comment Share on other sites More sharing options...
0 Crosswind Posted August 3, 2011 Share Posted August 3, 2011 (edited) On 8/3/2011 at 1:14 AM, Uditha88 said: Cross, * If battery is week, no crank occur right? and also it'll affect when in running. * Starter motor (no idea) * Cleaned fuel system by a bottle or "wurth". (by driven by that bottle) (but surely it'll not clean the fuel tank, lines up to from fuel tank to fuel filter) **And also has a doubt that shit fuel victim Any idea friends? What kind of cranking do u get from the engine? Does it crank very slowly and eventually start after a few attempts? What's the car? Is you car a manual tranny? If so, next time before you start, shift the gear to third or 4th and rock the car back and forth. Shift back to neutral and hit the ignition. If it starts without any problem, likely culprit is the starter motor. As for the battery, ask any battery shop to check it. They also can check the starter motor and alternator. Those are simple things you can do before you move on to other diagnostics. Edited August 3, 2011 by Crosswind Quote Link to comment Share on other sites More sharing options...
0 Uditha88 Posted August 3, 2011 Author Share Posted August 3, 2011 (edited) Thanks friends, It's 1.5L EFI system. (Automatic Tranny) Any idea? Edited August 3, 2011 by Uditha88 Quote Link to comment Share on other sites More sharing options...
0 MasterDon Posted August 3, 2011 Share Posted August 3, 2011 On 8/3/2011 at 2:58 AM, CyRaX said: Best is to withoug further trying to start up the engine bring down a mechanic and check.And based on what he says we could help you waaw!...what great advice!...bring a mechanic to repair a car...why didn't I think of that? Quote Link to comment Share on other sites More sharing options...
0 toyota sucks Posted August 3, 2011 Share Posted August 3, 2011 On 8/2/2011 at 2:45 PM, Uditha88 said: Friends, Why is a car hard to start despite engine is hot or cold. (All time) Have to try about 3 times to get it started. No issue in running condition. 1st of all where did u pump fuel Quote Link to comment Share on other sites More sharing options...
0 Uditha88 Posted August 3, 2011 Author Share Posted August 3, 2011 On 8/3/2011 at 2:10 PM, toyota sucks said: 1st of all where did u pump fuel At Laughfs, Koswatta. Once pumped exactly the same day morning that shit petrol news fired. Pumped for the 2nd time from the same place later too. (After shit petrol case settled) Quote Link to comment Share on other sites More sharing options...
0 CyRaX Posted August 4, 2011 Share Posted August 4, 2011 (edited) On 8/3/2011 at 11:41 PM, Uditha88 said: At Laughfs, Koswatta. Once pumped exactly the same day morning that shit petrol news fired. Pumped for the 2nd time from the same place later too. (After shit petrol case settled) So for how long has the problem being there ? Edited August 4, 2011 by CyRaX Quote Link to comment Share on other sites More sharing options...
Uditha88
Friends,
11 answers to this question
