Sylvi Posted December 4, 2012 Posted December 4, 2012 thanks Sylve My Honda EK3 got Plastic galss for headlamp and i belive the reflectors also plastic. so i'll not install 80w bulbs. I have seen lots of types of Bright Head light and which is called, HID, Projection bulb....etc. so are they relaible? and will this suit for plastic reflector lamp case..etc sira 'sira', For the information I have received HID kits, the best is 6000 K for normal use. If it is higher than that Police might object to you. I read a news article few days ago, the authorities wanted to ban high wattage head lights. High tone horns also. I use normal stranded 55/65 wattage bulbs. Which is OK for driving in the night in Colombo roads and as well as out of Colombo roads. Plastic H/L can get effected to high wattage bulbs due to high temperature produced by the bulb. Sylvi Wijesinghe. Sylvi Wijesinghe. Quote
H.C Posted December 4, 2012 Posted December 4, 2012 (edited) Mate, Dont install Hids to normal reflectors as they will scatter the light and will be a real headache to oncomming traffic. I think its ilegal to fix hids to non projector headlamps now. I think its better to check the condition of your reflectors and dirrection of your headlight beam first. Still worried ,go for high out put bulbs like osram night breaker. This topic has been discussed recently . Bit of search will help you futher. Edited December 4, 2012 by H.C Quote
razordj Posted December 5, 2012 Posted December 5, 2012 thanks Sylve My Honda EK3 got Plastic galss for headlamp and i belive the reflectors also plastic. so i'll not install 80w bulbs. I have seen lots of types of Bright Head light and which is called, HID, Projection bulb....etc. so are they relaible? and will this suit for plastic reflector lamp case..etc sira Sira, there were some recent "sira" topics discussed on the same matter. Try to use some search keywords like 'philps' and 'osram' and you will get a couple of good threads. Also there were people here who would hit you with large bats if you run your car with HID installed in non-projection housings. (The light will scatter, and will blind the oncoming traffic. Plus now its against the law) Quote
sira Posted February 12, 2013 Author Posted February 12, 2013 Finally I got philips Exteam vison form UK cost was 30£ it very good. some times with Kioto White beam, you cannot drive with little rain. this is fantastic Thank you for your idesa sira Quote
prvnrox Posted March 20, 2013 Posted March 20, 2013 sira are those 55/65?? I too need a set.visibilty in my ek3 is also very poor with incoming traffic and rain Quote
sira Posted March 24, 2013 Author Posted March 24, 2013 Yes, it is . same wattage. do not use 95w or soem thing like that. this is wonderfull. by the way, you need to install relays initially. because my on got 1.5 voltage drop and this was fixed by installing relays. sira Quote
