mazda-svt Posted June 1, 2012 Share Posted June 1, 2012 Hi guys need your valuable suggestions on this topic.My car is a Mazda Familia BJ5P 2001 Model(Face Lift)There is an error in my auto transmission box,the mechanic said that i have to replace a auto box,My plan is to convert in to manual,I need experts ideas,because am in a big trouble.is it practical with my familia?? Thanx Quote Link to comment Share on other sites More sharing options...
mazda-svt Posted June 1, 2012 Author Share Posted June 1, 2012 Sorry guys there is an error in my topic,it should be auto to manual Quote Link to comment Share on other sites More sharing options...
jdnet Posted June 1, 2012 Share Posted June 1, 2012 No. You are better off leaving it automatic. Changing transmissions between auto and manual isn't just a plug an play kind of thing. there are a lot of changes that need to be done and the cost would far exceed that of putting in a new auto box. What exactly is wrong with the transmission you have now? Quote Link to comment Share on other sites More sharing options...
Clark's son Posted June 1, 2012 Share Posted June 1, 2012 Just sell the auto vehicle and buy a manual if you really like to shift_by you'r self. You'll save some money because auto vehicles are pricy than manuals here Quote Link to comment Share on other sites More sharing options...
Crosswind Posted June 2, 2012 Share Posted June 2, 2012 On 6/1/2012 at 7:23 PM, mazda-svt said: Hi guys need your valuable suggestions on this topic.My car is a Mazda Familia BJ5P 2001 Model(Face Lift)There is an error in my auto transmission box,the mechanic said that i have to replace a auto box,My plan is to convert in to manual,I need experts ideas,because am in a big trouble.is it practical with my familia?? Thanx what exactly is the error? I have a funny feeling that your mech is a makabaas who only knows how to replace things. Search the forum for auto tranny repair. There are few ppl in the country who r good at repairing auto trannies 2 Quote Link to comment Share on other sites More sharing options...
maheshw Posted June 2, 2012 Share Posted June 2, 2012 On 6/1/2012 at 7:23 PM, mazda-svt said: Hi guys need your valuable suggestions on this topic.My car is a Mazda Familia BJ5P 2001 Model(Face Lift)There is an error in my auto transmission box,the mechanic said that i have to replace a auto box,My plan is to convert in to manual,I need experts ideas,because am in a big trouble.is it practical with my familia?? Thanx As other's state just mention the error on your gear box. experts here will able to give u a solution other than replaceing your gear box... Quote Link to comment Share on other sites More sharing options...
GayanR Posted June 2, 2012 Share Posted June 2, 2012 If u can ask that mechanic what exactly is the problem.Most makabases here tell you to replace the autobox coz they are lazy to repair it or dont know how to repair.dont convert it to manual Quote Link to comment Share on other sites More sharing options...
priyanka Posted June 2, 2012 Share Posted June 2, 2012 i think the second hand value of your car will be reduced if u convert it in to a manual these days very difficult to sell a manual one so i think u better repair it and keep Quote Link to comment Share on other sites More sharing options...
Magnum Posted June 3, 2012 Share Posted June 3, 2012 What if you are converting a manual car to automatic with the engine? and the car has had an automatic gearbox before Quote Link to comment Share on other sites More sharing options...
Magnum Posted June 3, 2012 Share Posted June 3, 2012 On 6/3/2012 at 9:39 AM, Magnum said: What if you are converting a manual car to automatic with the engine? and the car has had an automatic gearbox before bump Quote Link to comment Share on other sites More sharing options...
Nilantha Posted June 6, 2012 Share Posted June 6, 2012 (edited) On 6/1/2012 at 7:23 PM, mazda-svt said: Hi guys need your valuable suggestions on this topic.My car is a Mazda Familia BJ5P 2001 Model(Face Lift)There is an error in my auto transmission box,the mechanic said that i have to replace a auto box,My plan is to convert in to manual,I need experts ideas,because am in a big trouble.is it practical with my familia?? Thanx Converting Auto to Mannual is not complicated. you have to find to replace, 1. Mannul Gear Box, 2. Fly wheel, Clutch bearing, Clutch plate and pressure plate, 3. Some models want to change starter motor, 4. Clutch paddel set, Clutch pump and oil line set. 5. Gear Box mount, 6. Gear Lever and Gear changing cable set. 7. Engine plate. (fly wheel cover plate, it will come to between gear box and the engine. a steel plate) if you can find this set from recon sparepartz shops its easy to do the change. but i don't know about Mazda spares easy to find. according to toyota cost will be around 100,000/- but i am sorry i don't know about mazda. if you do this conversion using recon mazda parts, no one can find the conversion. Edited June 6, 2012 by Nilantha Quote Link to comment Share on other sites More sharing options...
Crosswind Posted June 6, 2012 Share Posted June 6, 2012 On 6/6/2012 at 1:57 AM, Nilantha said: Converting Auto to Mannual is not complicated. you have to find to replace, 1. Mannul Gear Box, 2. Fly wheel, Clutch bearing, Clutch plate and pressure plate, 3. Some models want to change starter motor, 4. Clutch paddel set, Clutch pump and oil line set. 5. Gear Box mount, 6. Gear Lever and Gear changing cable set. 7. Engine plate. (fly wheel cover plate, it will come to between gear box and the engine. a steel plate) if you can find this set from recon sparepartz shops its easy to do the change. but i don't know about Mazda spares easy to find. according to toyota cost will be around 100,000/- but i am sorry i don't know about mazda. if you do this conversion using recon mazda parts, no one can find the conversion. Right! and you don't need to change the instrument cluster, wire harness and the ECU? 1 Quote Link to comment Share on other sites More sharing options...
jdnet Posted June 6, 2012 Share Posted June 6, 2012 On 6/6/2012 at 2:27 AM, Crosswind said: Right! and you don't need to change the instrument cluster, wire harness and the ECU? excuse the retard. he never knows what the heck he's talking about. Apparently replacing all those parts isn't complicated at all. Lol. Quote Link to comment Share on other sites More sharing options...
YALA Posted June 6, 2012 Share Posted June 6, 2012 why bother doing it when you can just replace the with a recon auto tranny...assuming that you cant fix the current one...either way you still didnt say whats wrong with the one you have Quote Link to comment Share on other sites More sharing options...
Dragonfly Posted June 6, 2012 Share Posted June 6, 2012 Why the hell u want to remove a Mazda auto box? Fix it or replace with a reconditioned. Quote Link to comment Share on other sites More sharing options...
Komisiripala Posted June 6, 2012 Share Posted June 6, 2012 i'm also interested to know why you want to replace? of course, more out of curiosity than judgement. any good mech will find the parts for you. what you need to really think about is: 1. are you really ready to be shifting gears in traffic? this depends on whether your daily commute involves a lot of traffic. 2. are you willing to deal with the retarded (thanks JDNET i love that word!) disgruntled local market when you try to sell your car? along these lines, how long do you plan to keep the car and how long are you willing to try to sell it. i'm where you are right now. my car is kota uda because the auto box handed in its resignation. my garage at mount said the torque convertor is broken. for that i have to be Jack Brabham at the wheel. so i carried it to indika in kolonnawa (who previously fixed my CVT) and he showed me gunk in the gear oil filter and said "well there's your problem". the senior members in the ball-licking-lion-pride and indika are hell bent on fixing the auto. keeping things the way they came. i prefer manual. why? cos i spent 8k restoring the box, 38k fixing it in jan and am looking at another 35-40k bill now. and there's no guarantee it'll have a fit in another three months or not. and its a hella lot more fun to drive! however your car and my car are in completely different leagues in the local market but i hope this is sufficient food for thought for you. chew on it a bit. Quote Link to comment Share on other sites More sharing options...
Nilantha Posted June 6, 2012 Share Posted June 6, 2012 On 6/6/2012 at 2:27 AM, Crosswind said: Right! and you don't need to change the instrument cluster, wire harness and the ECU? no want to change wire harness. but want to check reverse sensor socket and speed meter sensor socket. but all not big change. Quote Link to comment Share on other sites More sharing options...
ferrarif50 Posted June 6, 2012 Share Posted June 6, 2012 On 6/6/2012 at 7:00 AM, Nilantha said: no want to change wire harness. but want to check reverse sensor socket and speed meter sensor socket. but all not big change. This guy is giving MAKA BAS advices all the time !!!!! 1 Quote Link to comment Share on other sites More sharing options...
Randika perera Posted March 14, 2021 Share Posted March 14, 2021 Can I know, Auto to manual car converting prices Quote Link to comment Share on other sites More sharing options...
Sajith thushanka Posted October 18, 2021 Share Posted October 18, 2021 On 3/14/2021 at 12:50 PM, Randika perera said: Can I know, manual to Auto car converting prices Expand Quote Link to comment Share on other sites More sharing options...
