Kavvz Posted January 18, 2013 Posted January 18, 2013 (edited) Guys! What is the normal procedure for changing gear oils (Manual) ? Is it necessary to flush out all ? Drain all and refil The google gods say: Edited January 18, 2013 by Kavvz Quote
NRX Posted January 18, 2013 Posted January 18, 2013 (edited) What kind of car do you have? Why not just google the owner's manual up? machan Car is FB13, mine is a non-jdm and it's next to impossible to find anything on the net, I've been searching for more than 1 year. Anyways I could find a Haynes manual but also in it it mentions only the capacity of the gear box, not the viscosity Edited January 18, 2013 by NRX Quote
Kavvz Posted January 18, 2013 Posted January 18, 2013 (edited) machan Car is FB13, mine is a non-jdm and it's next to impossible to find anything on the net, I've been searching for more than 1 year. Anyways I could find a Haynes manual but also in it it mentions only the capacity of the gear box, not the viscosity Ah a Nissan! Awesome. You could always call the dealer? Or google for Nissan Sentra with the year of manufacture: I did a quick search and found a likely source for gear oil viscosity see: Bob is the oil guy! Edited January 18, 2013 by Kavvz Quote
NZer Posted January 19, 2013 Posted January 19, 2013 (edited) machan Car is FB13, mine is a non-jdm and it's next to impossible to find anything on the net, I've been searching for more than 1 year. Anyways I could find a Haynes manual but also in it it mentions only the capacity of the gear box, not the viscosity Just drain using the nut and replace with manual transmission oil. Very very simple From the top of my mind i think the viscosity is 80 or 90. Edited January 19, 2013 by NZer 1 Quote
kmcsb Posted April 2, 2013 Author Posted April 2, 2013 i found mobil 2000 10w-40 semi synthetic..will it be ok to use an 160k old engine..hw about protection and performance...??? Quote
CJ5 Posted April 3, 2013 Posted April 3, 2013 Well, PitStop has the 20w50GTX on tap. So they put in only hat was needed. If the levels drops I will take small can and top it up from there. Yeah, 20w50 suits local conditions as the temp never drops beyong 25 here anyway, so i don't see why we need to pour in 0,5 or even 10 in to the crankcases. Even U****d M****s recommends 20W-50 (Valvoline Premium Conventional) for new Mitsubishis. I have done 105000kms and use that type of oil with no complaints. Quote
Ek3 Ferio Posted April 3, 2013 Posted April 3, 2013 Just drain using the nut and replace with manual transmission oil. Very very simple From the top of my mind i think the viscosity is 80 or 90. Some mechanics says it is ok to use 15W-40 engine oil for the manual gear boxes as well. Any idea regarding this? Quote
CJ5 Posted April 3, 2013 Posted April 3, 2013 Some mechanics says it is ok to use 15W-40 engine oil for the manual gear boxes as well. Any idea regarding this? Gear oil viscosity is usually 90, very thick, and 40 is quite thin compared to the 90. An A/T works on thin oil because the mechanisms are totally different. If thin viscosity oil such as 40 is used in a manual gear box or differential AFIK it will be ruined in a few kms. Quote
The Don Posted April 4, 2013 Posted April 4, 2013 Seems CJ5 is pretty close. Manual transmission oil is a lot thicker than engine oil http://www.castrol.com/castrol/multipleproductsection.do?categoryId=8000016&contentId=7000384 Quote
