Allion Or Corolla Or Civic
Umm... Asking since I don't know, I have no experience with this engine, but if the engine is as smooth as a petrol engine, why would you be chucking in another flywheel to reduce vibration?
2C engine when become old you have to do proper adjesments on tappets, injectors and injection pump etc. here most ppl can't do it properly. so when run the engine, 4 pistons compression, fuel injection, fire etc. r not equal, so engine generate vibration. if the flywheel bit heavy this unbalance can balance some. so can control vibration
  • Replies 50
  • Views 21.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Don't worry about 2c engine? He's not buying a townace you idiot. He's buying a 2007 or newer car. Having an engine that would make the car sound like a tata lorry is something to be worried about.
  • Don't worry about 2C engine. city driving it will do 12kml with AC and 17kmpl outstation with AC if Manual gear one. i can sure that.
  • terrabytetango
    terrabytetango
    Better invest in land instead.
Going on what you say, it sounds better to take the trouble to find someone to do the adjustment and fix the problem, rather than changing the flywheel, which sounds like a makabaas fix of treating the symptoms while leaving the problem.
So you say a 2C diesel engine is as good as a petrol if in perfect condition.. and then you say that in SL you dont get 'perfect 2C' engines? So how is your advice of any value?
yes proper way is to do adjustments. but expensive. normally toyota lanka takes around 35000/- to calibrate injection pump and so on. so ppl running with some vibrations (also telling with every one 2C engine is not good have vibrations and bla bla). as a goda wedakam some one can change flywheel. it can buy around 5000/-
who is telling there is no perfect 2C engine? some one was telling here 2C has lot of vibration. so i told reasons to vibration.
i think the best diesel engine is 2C (According to maintain cost, fuel consumption etc.) it has fixed to lot of models of toyota CE100, CE110, CE192, CE212 carina, Caldina, crown, vista, CR27, CR36, CR41, etc. also when converting Europe petrol vehicles to diesel ppl mostly used 2C
i agree it's so common and easy to maintain since all garages are familiar with 2C.
And i do disagree the comfort fact, because at the moment i'm using a toyota car with 2C-T engine,as heavy runner in colombo, E01 weekly.
Have to say that the regular diesel vibration is evident with speed.
And please note that the vibration is so personalised term with what you consider as benchmark.if you compare a van , yes it's comfortable.
But in compare to average petrol car or euro diesel at same age (E46 or 406HDI) It's nowhere near friend.
And what i've to say is fixing such an engine(from early 80's) to 2007- car (141 D) is just a crime according to my book.
Edited by chan5
You said the 2C engine is as quiet as a petrol engine. Then you say that the 2c has vibrations etc. Hence negating your first statement.
Is that short and sweet enough for you?
as i told you before. doing adjustments u can reduce the vibration. how your engine mileage now?
I think the allion would suit well for you.it's vry economical in every way....interior is gud and spacious and the materials used are also gud.it bears the name of toyota and has a gud resale value.than a civic u will find it more spacious and economical(although i dnt like the interior of fd 1)if u want more performance together with fuel eco,then go for a 1.8 one
I too got to know from a friend that diesel, manual 141 had given them amazingly good km/l results in an outstation tour he participated.
Any diesel would give roughly the same figures, the e46 gets around 13 in city and about 17 in long distance drives and keep in mind that the e46 is a car that weights much more than the 141 so what exactly is so magical about this engine ? Please do enlighten us.
Edited by The Stig
Just note that I've ZERO knowledge abt this Engine & fuel figure stated by friend was 19-20 Km/L.....
it's says 180k , but i don't believe that value , and i've done engine overhaul with genuine parts in a reputed garage for toyotas.
With all sort of adjustments , new injectors , pump service, and engine mounts too.
Still it's 2C which has it's own drawbacks.
I'm impress by the simplicity of maintenances , for ME it's around 10 kmpl colombo heavy traffic and 15 on E01 (Steady speed at 90kmh).
That's i'm expecting for more than 10year old car, but the same engine in brand new 141 corolla-? they've not bothered putting new engine (atleast 3CTE) even after almost 30 years of 2c?
I say it's a crime on daylight
highly unlikely , in colombo
Hey are you ok? Should I repeat my 1st post??
"....amazingly good km/l results in an outstation...."
What "colombo" u talking about ???
this's your original post , where does it say OUTSTATION .?
Agree!
how many KM have you done after overhaul? did you calibrate the injection pump?
Pls read post no 24
is this YOUR 24th post?
Ok or ret*rd,
can you tell ME where does it say a fuel figure? . What's the number of amazingly good?.
Stop being ja***ss men.
Ok, it's 20,000km, and i've done injector pump Calibration too.
Now What?
Ok or ret*rd,
Ayyio Salli
Retarded
Nilantha:
Me:
The Stig:
Me:
chan5:
:heat:
Now What?
when after 25000km do adjust tappet clearance. from where did you do injection pump calibration? Demo or Toyota lanka?
Ayyio Salli
Retarded
Nilantha:
Me:
The Stig:
Me:
chan5:
:heat:
Sorry, i didn't find it's important to connect all your posts here and there, and assume it was same friend with same trip in same car , it was my bad.
Ok I'll admit, 2C does 20kmpl
i did it from toyota lanka, and i'll try doing this tappet thing again,
there's a slight doubt in my mind,
i remember a saying .
"If it didn't break , never fix it "
