FreakSL Posted April 4, 2013 Posted April 4, 2013 Hey Guys im in a look to buy a good single carburetor , if anyone can let me know a place or someone who has it please be kind enough to pm me thanks in advance Quote
H.C Posted April 4, 2013 Posted April 4, 2013 Searched for one 3y back and only able to find one with upul , malabe . (Worse than my one) Then I decided to rebuild my one and thanks to my mechanic now its back to stock condition with functioning power valve, auto choke, etc. Whats wrong with your original one.? Im really familiar with D15B3 carb setup, so can help you if you need any details. Quote
Simplelife Posted April 4, 2013 Posted April 4, 2013 Agree with HC...i was also faced simillar situation onmy previous car. Couldnt find a better carb, so i decided to rebuild my carb.. wuts up wit ur current one? Quote
FreakSL Posted April 4, 2013 Author Posted April 4, 2013 Agree with HC...i was also faced simillar situation onmy previous car. Couldnt find a better carb, so i decided to rebuild my carb.. wuts up wit ur current one? mhh exactly dont know mechanic told me that , some parts are missing and one openning is closed , so the car power is very low, it become worst when A/C is switched on, hard to drive up hill with the A/c on. will it help with a repair kit ?? Quote
Rumesh88 Posted April 5, 2013 Posted April 5, 2013 mhh exactly dont know mechanic told me that , some parts are missing and one openning is closed , so the car power is very low, it become worst when A/C is switched on, hard to drive up hill with the A/c on. will it help with a repair kit ?? A repair kit will help depending on the parts that are missing if they are actually missing. You do not get everything in a repair kit. For a mechanic the easiest way to explain a problem is to say that "some part are missing" and the easiest solution is to find a replacement of the whole thing. If it is some thing like a mechanical linkage that is missing then of course you may have to find a replacement carb. Didn't your mech told you what's missing? As H.C says it is always better to rebuild your existing one than trying to rebuild an unknown one. Is it possible to post a picture of the carb? Quote
FreakSL Posted April 5, 2013 Author Posted April 5, 2013 A repair kit will help depending on the parts that are missing if they are actually missing. You do not get everything in a repair kit. For a mechanic the easiest way to explain a problem is to say that "some part are missing" and the easiest solution is to find a replacement of the whole thing. If it is some thing like a mechanical linkage that is missing then of course you may have to find a replacement carb. Didn't your mech told you what's missing? As H.C says it is always better to rebuild your existing one than trying to rebuild an unknown one. Is it possible to post a picture of the carb? I told the mech to clean it and fix it as it is so i can take it to someone else who can see it and fix it , can you guys suggest me a place ? Quote
H.C Posted April 5, 2013 Posted April 5, 2013 <blockquote class='ipsBlockquote'data-author="FreakSL" data-cid="236975" data-time="1365136119"><p> I told the mech to clean it and fix it as it is so i can take it to someone else who can see it and fix it , can you guys suggest me a place ?</p></blockquote> As Rumesh mentioned post few pics of the carb with all the connections. I think Rumesh is a mechanical engineer and knows these carbs really well . I can recommend my mechanic ,who fixed my carb. but his garage is at Horana. Quote
Rumesh88 Posted April 5, 2013 Posted April 5, 2013 <blockquote class='ipsBlockquote'data-author="FreakSL" data-cid="236975" data-time="1365136119"><p>I told the mech to clean it and fix it as it is so i can take it to someone else who can see it and fix it , can you guys suggest me a place ?</p></blockquote> As Rumesh mentioned post few pics of the carb with all the connections. I think Rumesh is a mechanical engineer and knows these carbs really well . I can recommend my mechanic ,who fixed my carb. but his garage is at Horana. @FreakSL My scope here is limited to helping someone to diagnose the problem and finding a solution. It is mostly helpful to those trying out their hands at DIY jobs but may not be for everyone. However, if H.C can recommend his mech in Horana it may be worth going the distance than handing over your carb to an unknown makabaas. D5 series carbs are masterpieces of Jap ingenuity but when it comes to maintaining them you've got to find mechanics of the matching caliber. If you can post some pics I would be able to identify the missing pieces if any. More often than not what most mechanics do is to make the engine to tick over somehow and disconnect or block the thing that they do not understand. Quote
kmcsb Posted April 7, 2013 Posted April 7, 2013 yes mine auto choke doesntwork after repairing A/C....also when i switched on ac car gets vibrate....will it resolve by doingrepair my car..thts mean do i need carb repair kit???? Quote
hrm Posted April 7, 2013 Posted April 7, 2013 yes mine auto choke doesntwork after repairing A/C....also when i switched on ac car gets vibrate....will it resolve by doingrepair my car..thts mean do i need carb repair kit???? Seems this is related to the idle up circuit. check this with an electician first. Quote
FreakSL Posted April 11, 2013 Author Posted April 11, 2013 gave a good tune up and cleaning to the carb from Upul in malabe , and gave a good service to the A/C, but when the A/C is on sometime suddenly the idle up to 2000rpm and stays for a minute or so and back to normal. also i can hear a noise of electric shortage inside the bonnet when the A/C on and changing the gears. the place i serviced the A/C said there are few disconnected valves , may be fixing that would solve the problem ? sigh Quote
Komisiripala Posted April 11, 2013 Posted April 11, 2013 Had a very similar problem on the datto. I think your a is the culprit. The condensor might be hearing up. Heck on its cooling. Maybe a condensor fan or fan shroud would help. Check the AC cutoff also. It should be around 8-10* Celsius. Any lower and your compressor is on a big load. And rotar type compressors make thy electric short noise when they are overloaded. These days are really hot mate. I feel for our old cars trying to keep up with our demands on the AC. My mechanic services the AC and when I finally thought all was well, a fuse blew. Huta Quote
FreakSL Posted April 11, 2013 Author Posted April 11, 2013 (edited) Had a very similar problem on the datto. I think your a is the culprit. The condensor might be hearing up. Heck on its cooling. Maybe a condensor fan or fan shroud would help. Check the AC cutoff also. It should be around 8-10* Celsius. Any lower and your compressor is on a big load. And rotar type compressors make thy electric short noise when they are overloaded.These days are really hot mate. I feel for our old cars trying to keep up with our demands on the AC. My mechanic services the AC and when I finally thought all was well, a fuse blew. Huta Guess I can go to a A/C repair place and tell them issue ? probably fixing up the disconnected valves and all, that dude told me that the original condenser which comes with the EG8 is not gonna work for the Sri Lanka , also how did you fix your one ? Edited April 11, 2013 by FreakSL Quote
Komisiripala Posted April 11, 2013 Posted April 11, 2013 Fan shroud installed. And AC thermostat fixed. Gassed the AC also. Still have a slight issue in deep traffic but now more or less working. I'll be switching to a bigger engine and getting my mech to completely overhaul the AC and iron out any differences. Quote
FreakSL Posted April 13, 2013 Author Posted April 13, 2013 now the A/C doesnt work, I heard a electric shortage may be some thing blew , normally when I switch on the a/c car idle become little bit low and there is a difference of pick up, now when I switch on the a/c nothing happen only the fan is working and it won't get cold at all, gaarah, Quote
H.C Posted April 13, 2013 Posted April 13, 2013 Check AC related relay, fuse. Seems like AC compressor doesn't engage now. What's the fan that works now? Blower or condensor fan? Quote
FreakSL Posted April 13, 2013 Author Posted April 13, 2013 Check AC related relay, fuse. Seems like AC compressor doesn't engage now. What's the fan that works now? Blower or condensor fan? i guess its the blower Quote
Komisiripala Posted April 13, 2013 Posted April 13, 2013 you've blown a fuse or one of the power wires to the AC came loose. check those first. it is infinitely frustrating machan. now i've finally got everything working and lo and behold the car keeps slowly heating up. i don't htink i can drive around for more than 90 minutes before temperature become critical... Quote
FreakSL Posted April 14, 2013 Author Posted April 14, 2013 planing to go to a A/C repair place and show , need to connect all the lose and disconnet wires and check the fuse and what not, driving around without A/c in this heat is not funny at all... sigh !!! Quote
