im looking to get new alloys (Bigger size) for my car.....
mazda 323 hatchback (Yom: 1992)
Current Size is following
Alloy: 13inch
Tyre: 175.70R 13
Mazda recommended alloy and tyre size is (Door Printed Striker )
175.70r13 82S
175.65r14 82h
185.60r14 82h
Can i use 16 or 17 inch alloy wheels?this will damage to car?
Reason for bigger wheel is ground clearance is very low.
Alloy: 13inch
Tyre: 175.70R 13
175.70r13 82S
175.65r14 82h
185.60r14 82h
Its not advisable to change the size of wheels and tyres as you wish outside of what the manufacturer has recommended as it could lead to various complications. Go to these links to get an explanation.
http://www.1010tires.com/Tools/Tire-Size-Calculator
http://www.tacomaworld.com/forum/tirecalc.php?tires=165-70r14-185-70r14
Edited by CJ5
Alloy: 13inch
Tyre: 175.70R 13
175.70r13 82S
175.65r14 82h
185.60r14 82h
If you don't worry much about the speed and the mileage calculation,
1. Use same rim and go for tyre with large balloon size
2. buy 15' alloy and tire
Pros:
You get good ground clearance
Cons
larger the radius higher the tyre price
Alloy: 13inch
Tyre: 175.70R 13
175.70r13 82S
175.65r14 82h
185.60r14 82h
Hi
I have the same car and also had the same issue , would recommend to go maximum 15” as you may face issues with the tyre walls hitting the inside of the wheel arch.
I’ve put 185/65/15 which as solved the problem to a great extent and still got clearance to load and not touch the wheel arches
Planing to get 185/65/15..with 15 alloy...thanks ...lot....
like to get following design..
post-52073-0-49594800-1372684476_thumb.j
Edited by Nimz77
Compare Current and New..Can you explain this....please(sorry im new to cars)
175.70R 13 vs 185/65/15
post-52073-0-19533400-1372685203_thumb.j
Edited by Nimz77
That's more than 3% of the present diameter which is not good.
Mmmm....Could please advise me with good one...please...why not good 3% diameter..?can you explain...
Did you check out this site giving your stock tyre size and the size you wanted to upgrade to???? That will will tell you what CAN happen. (not that it WILL happen)
What will happen if you fit a bullock cart size wheel to a car? Same thing.
2.5-3% is the maximum you can change the diameter. beyond that will be problematic to use the car.
Sorry for extending topic;
Please share your views on fixing nissan fb15 new shell with alloys, as I've seen many of them are kept with their stock plastic cover as it somewhat looks good than old fb15 stock wheel cover. What sort of design it will looks good? Expect views and photos from AL designers and fb15 owners.
Guys,
My previous tires were 215/65/16, and it was Falken and its out of stock at the moment. So they asked me to go for 215/70/16, I think its bit over 3% ryt.
So it's not good to put these tires....?
There may be some people who has come across this situation, Can someone please shed some light on this. :locomotive:
Guys,
Guys,
Finally I made my mind for Dunlop GrandTrek ST 20, Is there any one who can give me any update on this tire?
  • 6 months later...
Guys does anyone know a place where I can see BBS RS alloys in SL? Even used one in good condition?
And what is the specs I should look for if I'm going for new alloys in my E30.
Edited by MkX
I saw a set in US Auto Parts, Hill Street Dehiwela (the branch close to Dehiwela town) recently
Thanks I shall pay a visit then.
Alloy: 13inch
Tyre: 175.70R 13
175.70r13 82S
175.65r14 82h
185.60r14 82h
You won't be able to get extra ground clearance fitting larger rims because you will have to keep the overall diameter of your wheels the same as before. You do this by reducing the height of the side wall of the tyre as you go up rim sizes (the so called low profile tyres).
  • 8 months later...
Is that OK to use different size tires in front and rear?
front(165/70/13)-goodyear
rear(185/70/13)-achilles
Seems OK considering you're just using a wider baloon size.
Just make sure the balloon size (165 or 185) on the front doesn't exceed the stock size cos it could result in the tyre rubbing against the wheel-well on full steering lock. Currently your bigger tyres are at the back, so should be all-right IMO.
You may use this Calculator to determine tire diameter and circumference. The two sizes you have provided are different in both circumference and diameter.
http://www.csgnetwork.com/tiresizescalc.html
However running them in tandem is your choice, any mechanical worries? May be not, handling may be impaired.
How is (165/70/13) and (185/70/13) different in circumference / diameter?
edit: I just used your calculatror and i'm seriously baffled on how it's possible. My grade 7 maths says that the diameter and circumference is purely based on radius which is (RimDiameter/2 + tyreHeight)
Edited by Watchman
Correct on the Rim Diameter + Tire side wall Height = Outer Diameter of tire.
In this case aspect ratio + rim diameter is same but section width is 165 vs 185. My understanding is maintaining same aspect ratio and increasing section width may have a slight increase in overall diameter of the tire.
However I can confirm though I have used this calculator and have actually measured tires several times to confirm numbers and have not come across any discrepancies.
May be OP can help us by actually measuring the tire.
