Instructions
  • 1
    Locate the vacuum switching valve. It has three vacuum hoses and a two-wire electrical connector attached to it. On four-cylinder engines, the VSV is located on the rear of the engine below the intake manifold. On six-cylinder engines, the VSV is under the V-Bank cover (a plate with fins), which must be unbolted using an Allen wrench, and then removed by lifting it off its retaining clips. The VSV is next to the intake manifold.
  • 2
    Check the resistance. Remove the electrical connector from the VSV and check the resistance across the terminals using an ohmmeter. The resistance should be 33 to 39 ohms (at an air temperature of 68 degrees). Resistance outside this range indicates that the VSV is bad.
  • 3
    Continuity test. Verify, using the ohmmeter, that there is no continuity between either VSV terminal and an electrical ground on the engine. Any continuity at either terminal indicates the VSV is bad.
  • 4
    Blow test. Remove the vacuum hoses from ports E and G. Blow air into port E and check that it comes out at port G. If it does not, the VSV is bad.
  • 5
    Apply voltage and blow air. Apply battery voltage across the VSV terminals using wires from the battery terminals. Blow air into port E and see if it comes out of port F. If it does not, the VSV is bad.
    Tips & Warnings
    • For the four-cylinder engine, it may be necessary to raise the front of the vehicle and place it on jackstands to obtain access to the VSV.
    • The VSV on the six-cylinder engine can be tested either on the engine or removed. If you remove the VSV, be sure to mark the vacuum hoses and ports before disconnecting them.
    • Do not depend on a jack to support the front of the vehicle
