Good job! Looks like the same should be done for the valve cover as well.
Thank you Davy, shall I use the same heat resistant paint for the valve cover too?
Yes, you can use the same paint. Give it a good cleanup, sand it with 1200 grit water sandpaper and then spray away! 2 to 3 coats should do.
