haliq2009@gmail.com Posted October 28, 2014 Share Posted October 28, 2014 Hi Guys just bought a rec es8 2002 one month Back facing a issue as my ABS light is permanently on from yesterday. Pls advice what to do. Quote Link to comment Share on other sites More sharing options...
0 Fixzit Posted October 28, 2014 Share Posted October 28, 2014 Go to an empty area and hit the brake hard at about 40kmph..turn off the ignition off and turn on.. if the abs light dsnt go off.. do an OBD scan and find out exactly where is the problem.. 1 Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 28, 2014 Author Share Posted October 28, 2014 Tx will try it. Quote Link to comment Share on other sites More sharing options...
0 Rumesh88 Posted October 28, 2014 Share Posted October 28, 2014 (edited) On 10/28/2014 at 12:48 AM, haliq2009@gmail.com said: HiGuys just bought a rec es8 2002 one month Back facing a issue as my ABS light is permanently on from yesterday. Pls advice what to do. One simple possibility is due to dirty or faulty ABS sensors. If the scanner shows a ABS sensor get all of them cleaned first and see if the fault disappear. You can get them cleaned anyway for they must have become dirty now unless they have been cleaned before. If the sensor is faulty then you would have to change the faulty one. BTW I just noticed that OP is using a email address as his log in. If it is a real email then it is not such a good idea to use it in a public forum. Edited October 28, 2014 by Rumesh88 Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 28, 2014 Author Share Posted October 28, 2014 Guys. Tx for your inputs Guys but my batery light started sparking luckily got near a garage they said it is A faulty alternator. What do you guys recomen to replace the alternator or make the same as I cannot move the vehicle currently. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 28, 2014 Author Share Posted October 28, 2014 How much do you tink it wil cost and where can I buy one. Quote Link to comment Share on other sites More sharing options...
0 The Don Posted October 28, 2014 Share Posted October 28, 2014 On 10/28/2014 at 12:13 PM, haliq2009@gmail.com said: Guys. Tx for your inputs Guys but my batery light started sparking luckily got near a garage they said it is A faulty alternator. What do you guys recomen to replace the alternator or make the same as I cannot move the vehicle currently. Depends on whats bust on the alternator. It could be the voltage regulator which is repairable, bushes or the coil. See if it can be repaired, if not you can replace with a used item. Quote Link to comment Share on other sites More sharing options...
0 maheshw Posted October 29, 2014 Share Posted October 29, 2014 On 10/28/2014 at 1:01 PM, The Don said: Depends on whats bust on the alternator. It could be the voltage regulator which is repairable, bushes or the coil. See if it can be repaired, if not you can replace with a used item. may be i am wrong. had similar issues on alternator on a ek. reapired two times. not solved. fixed a recon device. all went. cost only 8k. parts are freely available. better to identify the exact issue. Quote Link to comment Share on other sites More sharing options...
0 The Don Posted October 29, 2014 Share Posted October 29, 2014 On 10/29/2014 at 7:24 AM, maheshw said: may be i am wrong. had similar issues on alternator on a ek. reapired two times. not solved. fixed a recon device. all went. cost only 8k. parts are freely available. better to identify the exact issue. With repairs it often depends on the quality of the repair. You can normally even buy the regulator as a separate part sometimes brand new. But most newer alternators are not servicable which is a shame....... Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 29, 2014 Author Share Posted October 29, 2014 Tx guys for all ur replies got the alternator repaired. Need to see how it will run! 1 Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 29, 2014 Author Share Posted October 29, 2014 Tx guys for all ur replies got the alternator repaired. Need to see how it will run! Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 30, 2014 Author Share Posted October 30, 2014 Hi guys need ur advise on where cud I fined es8 recon spares as I need to replace a Abs censor as the alternator issue is two different issues. Quote Link to comment Share on other sites More sharing options...
0 The Don Posted October 30, 2014 Share Posted October 30, 2014 On 10/30/2014 at 6:43 AM, haliq2009@gmail.com said: Hi guys need ur advise on where cud I fined es8 recon spares as I need to replace a Abs censor as the alternator issue is two different issues. First check the new price before you look at used parts when it comes to things like abs sensor. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 30, 2014 Author Share Posted October 30, 2014 Thanks any suggestions I called tech motor they didnt have sensors Quote Link to comment Share on other sites More sharing options...
0 The Don Posted October 30, 2014 Share Posted October 30, 2014 On 10/30/2014 at 4:22 PM, haliq2009@gmail.com said: Thanks any suggestions I called tech motor they didnt have sensors Try the agent and then try after market options. As somebody has suggested the first thing to try is to remove the sensor from the hub and clean, and see if it makes a difference. Quote Link to comment Share on other sites More sharing options...
0 Davy Posted October 30, 2014 Share Posted October 30, 2014 haliq2009, How did you come to conclude that the ABS light is on due to a bad sensor? Did you have it checked? One or more faulty sensors is just one possible cause as Rumesh88 has correctly pointed out above. It can also be due to a faulty connection or a blown fuse in the ABS circuit. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted October 31, 2014 Author Share Posted October 31, 2014 Thanks guys it was sorted out as rumesh said it was fault connection. Tx all for all our replies. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted November 4, 2014 Author Share Posted November 4, 2014 Hi guys alternator issue came up again,earlier the other componant were replaced except the rotor was repaired because due to unavailability,do you guys think if the rotor is replaced it will last as my mechanic has found one pls advice as I am tired of the brake downs. Quote Link to comment Share on other sites More sharing options...
0 Davy Posted November 4, 2014 Share Posted November 4, 2014 On 11/4/2014 at 11:54 AM, haliq2009@gmail.com said: Hi guys alternator issue came up again,earlier the other componant were replaced except the rotor was repaired because due to unavailability,do you guys think if the rotor is replaced it will last as my mechanic has found one pls advice as I am tired of the brake downs. What exactly is wrong with the rotor/armature? Does it require re-winding or are the brush contact surfaces worn out? I don't think a good mechanic would have taken the risk and re-assembled the alternator, knowing that the armature is faulty. It's funny how a part that was "unavailable" is suddenly available for replacement now. So if you don't want to experience any more breakdowns, I suggest you either tell your mechanic to cut the crap and come straight or find a guy who will fix it properly. Also, if the rotor needs to be replaced, I think you are better off with a new or recon alternator altogether. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted November 4, 2014 Author Share Posted November 4, 2014 He says the rotor is damaged, Quote Link to comment Share on other sites More sharing options...
0 Rumesh88 Posted November 4, 2014 Share Posted November 4, 2014 (edited) I too smell a fish here because if the mechanic suspected a fault in the rotor he shouldn't have repaired the rest of the alternator like Davy said. BTW when you said your "battery light sparking" did you notice any problem like headlights getting dimmer or difficulty to start etc., basically the obvious signs of a drained battery?. Did they check the battery voltage before and after attending to the alternator? I get the feeling that your alternator output could be OK while the actual issue is something else. Edit: Just get your the alternator wiring checked for previous modifications to accommodate a non-standard alternator. (Usually your alternator should have a four wire connector at the back. Some of our electricians modify wiring to this connector to retrofit alternators with three-wire connectors). Edited November 4, 2014 by Rumesh88 Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted November 4, 2014 Author Share Posted November 4, 2014 Well I got the vehicle now with the replaced rotor well hope it will hold on,as the mechanic said nothing to worry as now the major potion of the alternator has been replaced, hope it will be OK. Well I believe that the mechanic is concerned on the prices and in the process tries to repair stuff as the alternator costs about 20,000. As after replacing the rotor costed only 4000 To replace rotor. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted November 5, 2014 Author Share Posted November 5, 2014 My mec has replaced the amarcha/rotor hope it will last. As I believe the main components are replaced. Quote Link to comment Share on other sites More sharing options...
0 The Don Posted November 5, 2014 Share Posted November 5, 2014 I think guys over here don't understand the use of the "Mark Solved" button. It is to mark the most helpful answer in solving your problem. Its a bit silly for the OP to mark one of his own posts as the most helpful answer It is a method of thanking other members who help you rather than promoting yourself and hilighting the solution to the problem. Quote Link to comment Share on other sites More sharing options...
0 haliq2009@gmail.com Posted November 6, 2014 Author Share Posted November 6, 2014 Hi don thanks for being judgmental as it was a mistake from my end to select solved as I thought that marking solved would help the other members who would need your valuable advice. Thanks a lot guys for taking time to text your advice. Quote Link to comment Share on other sites More sharing options...
haliq2009@gmail.com
Hi
24 answers to this question
