Toyota Vitz - Burning Smell When Accelerating
Hi All,
Reasonably I bought a Toyota Vitz 2007 model. There a Burning smell coming when sudden accelerations. This is happening at random intervals.
Please help !!
9 answers to this question
Trust you drive with your windows closed. If so, you should not get any smell from outside unless the door rubber seals are damaged or the external air vent of your AC system is not closing properly. Let's first sort out if the smell comes from outside or inside.
Did you experience that when car is idle as well?
If so try to locate the are of the car where smell comes in (No scanners for this, only scanner is your nose :mosking: )
I also think it comes through AC vent. leme check on that.. but this happened 2 times randomly when i was trying to overtake.
If so get it attended on priority. Otherwise you will have to change your cabin filter every few hundred kms. Also do you get belt slipping noise at times?
Yes I m going to replace the belt this weekend
Then most probably it could be due to loosen belt. Replace the belt before get in to A/C.
