MrCat Posted September 21, 2015 Posted September 21, 2015 Unfortunately I can’t be of any help on your query, but since you are looking for it specifically, have you had much good experience with Liqui-Moly products? I`ve used: “Diesel Purge”, “Diesel Clean and Boost” and “Diesel Algae Stop”. I find the first two products work very well, but the latter I can only hope that it does what it`s supposed to do . Quote
MAS Posted September 21, 2015 Author Posted September 21, 2015 (edited) Hi MrCat, No experience with the brand. But they have a Radiator Stop Leak (made in Germany) that has good reviews. My aluminium core has a pin size hole (cant even see it) in the water line, leaking coolant. I want to try this out first before attempting to spot weld it Edited September 21, 2015 by MAS Quote
MrCat Posted September 22, 2015 Posted September 22, 2015 Ah ok, good luck with the hunt.. hopefully you`ll get a favorable reply from some who knows better.. Quote
Kavvz Posted September 22, 2015 Posted September 22, 2015 Unfortunately I can’t be of any help on your query, but since you are looking for it specifically, have you had much good experience with Liqui-Moly products?I`ve used: “Diesel Purge”, “Diesel Clean and Boost” and “Diesel Algae Stop”. I find the first two products work very well, but the latter I can only hope that it does what it`s supposed to do . “Diesel Algae Stop” as in for a car you use infrequently or for a boat or something? Quote
