September 28, 201511 yr Yup it did. I quite like the RFTs cz once I was doing 150+ in katu expy( not good I know ) and right rear punctured due to some metal part. Didnt lose control at all and was kinda saved. I think it would've been far worse if the tyre failed and went down to the rim.. Well if I get rid of them before the car arrives, will it be equipped with a spare or just the air compressor? Wow? No kidding? That's a pretty pro-argument for run flat's and I guess that's why most cars now come RFT's I guess...But then again I've never had any major blow outs at high speeds like that at all...And I've had a daily driver for a good 8 years or so now, so I guess it comes down to driving habits / need for safety and individual preference. To answer your question: You won't get a spare as the car is spec'd for RFT's but as the complimentary air compressor fits inside the tool compartment / first aid compartment that will always be there. And I'm not sure the agents will offer you a discount even if you switch to regular tyres but as the primary motivation behind buying this car (I'm guessing) is comfort its an option worth exploring, especially if this car isn't really going to be on the highway that much. If that's the case, you may want to consider asking Gummybr or any other sales staff member at the agents if they can pull some strings and get you a different tyre option before you pick up your car. Edited September 28, 201511 yr by Kavvz
September 28, 201511 yr Author Wow? No kidding? That's a pretty pro-argument for run flat's and I guess that's why most cars now come RFT's I guess...But then again I've never had any major blow outs at high speeds like that at all...And I've had a daily driver for a good 8 years or so now, so I guess it comes down to driving habits / need for safety and individual preference.To answer your question: You won't get a spare as the car is spec'd for RFT's but as the complimentary air compressor fits inside the tool compartment / first aid compartment that will always be there. And I'm not sure the agents will offer you a discount even if you switch to regular tyres but as the primary motivation behind buying this car (I'm guessing) is comfort its an option worth exploring, especially if this car isn't really going to be on the highway that much. If that's the case, it won't hurt to ask Gummybr or any other staff member you are negotiating with if they can pull some strings and get you a different tyre option for you before you pick up your car. Thank you Kavvz I'll talk to him Well it was a brake calliper probably of a large vehicle which got cut into the tyre.. Bad timing.. I felt really alive after realising the worst scenario Tyre was totally unrepairable yet did not fail. EDIT: Plus drove it to a tyre shop without damaging suspension or the wheel Edited September 28, 201511 yr by sasika
September 28, 201511 yr Thank you Kavvz I'll talk to him Well it was a brake calliper probably of a large vehicle which got cut into the tyre.. Bad timing.. I felt really alive after realising the worst scenario Tyre was totally unrepairable yet did not fail. EDIT: Plus drove it to a tyre shop without damaging suspension or the wheel I wasn't there and I'm not familiar with the X1 so I can't say for sure but just as a heads up: On most cars (unless they are armoured or for some odd reason they defy convention and are designed with centre tyre supports like the armoured cars) the run flat feature is designed into the sidewalls of the tyre not the centre tread part of the tyre or the rim. So if you have a major blow out where the sidewall is damaged, the weight of the car will end up resting on the edge of the rims which as we all know are susceptible to damage / warping if you drive on them. So if the sidewalls blow out regardless of whether they are RTF's or not, the safest option is to pull over and get the car towed, otherwise you may end up damaging the rims and / or your suspension... [Now that I think about it a bit: Overall, even after a puncture where there is no sidewall damage and the TPS indicates lowered pressure, you would have to get the tyres inspected for damage and repaired. The only advantage being that, unlike regular tyres, you don't have to pull over and put on the spare before driving to the closest tyre centre to get them attended to. But for regular tyres, as running an air compressor and pumping the tyre back up before quickly driving to a service centre works for all but the most severe punctures; the benefit of RFT's could be considered marginal for the most common types of punctures (as long as you have an air compressor in the boot).The only situation where the RFT's are distinctly superior would be in scenarios like you described; where a tyre loses air rapidly and the stiffer sidewall gives the driver some degree of enhanced control while slowing down and pulling over, if the sidewall is still relatively intact that is...The drawback though is the higher purchase price of RFT's, and more importantly, the loss of ride comfort on uneven roads.] Edited September 29, 201511 yr by Kavvz
September 29, 201511 yr Author I wasn't there and I'm not familiar with the X1 so I can't say for sure but just as a heads up: On most cars (unless they are armoured or for some odd reason they defy convention and are designed with centre tyre supports like the armoured cars) the run flat feature is designed into the sidewalls of the tyre not the centre tread part of the tyre or the rim. So if you have a major blow out where the sidewall is damaged, the weight of the car will end up resting on the edge of the rims which as we all know are susceptible to damage / warping if you drive on them. So if the sidewalls blow out regardless of whether they are RTF's or not, the safest option is to pull over and get the car towed, otherwise you may end up damaging the rims and / or your suspension... [Now that I think about it a bit: Overall, even after a puncture where there is no sidewall damage and the TPS indicates lowered pressure, you would have to get the tyres inspected for damage and repaired. The only advantage being that, unlike regular tyres, you don't have to pull over and put on the spare before driving to the closest tyre centre to get them attended to. But for regular tyres, as running an air compressor and pumping the tyre back up before quickly driving to a service centre works for all but the most severe punctures; the benefit of RFT's could be considered marginal for the most common types of punctures (as long as you have an air compressor in the boot).The only situation where the RFT's are distinctly superior would be in scenarios like you described; where a tyre loses air rapidly and the stiffer sidewall gives the driver some degree of enhanced control while slowing down and pulling over, if the sidewall is still relatively intact that is...The drawback though is the higher purchase price of RFT's, and more importantly, the loss of ride comfort on uneven roads.] You said everything
September 29, 201511 yr Sasika, since more gizmos equal high probability of things going wrong you can use that as an excuse for not buying the 200 as well.
October 2, 201511 yr Author Sasika, since more gizmos equal high probability of things going wrong you can use that as an excuse for not buying the 200 as well. Yah and since it's under the luxury tax and if our govt thinks luxury tax should be 200k next year... Better safe than sorry
October 15, 201511 yr Author Hi guys, I got the car delivered by D*MO.. A C180 Avantgarde. Pretty impressed with their service as well.
October 16, 201511 yr Hi guys, I got the car delivered by D*MO.. A C180 Avantgarde. Pretty impressed with their service as well. As in they swapped the RF tyres out for you?
October 17, 201511 yr Author As in they swapped the RF tyres out for you? No I didn't request them, but the ride is so smooth and quiet. I wouldn't be exaggerating if I say that most of the potholes are not felt in this. Fuel economy though is not as advertised, manages 8-10. They said that figure should improve upon the tuning up of engine. But who care if it does 5 1.6 engine is surprisingly punchy as well.
October 17, 201511 yr No I didn't request them, but the ride is so smooth and quiet. I wouldn't be exaggerating if I say that most of the potholes are not felt in this. Fuel economy though is not as advertised, manages 8-10. They said that figure should improve upon the tuning up of engine. But who care if it does 5 1.6 engine is surprisingly punchy as well. Well, I guess that's the air suspension kicking in and doing its thing. And it will get better with regular sidewalls, which you'll find out if you go that route when it comes to replacement tires...But congrats on the purchase either way
October 18, 201511 yr Author Well, I guess that's the air suspension kicking in and doing its thing. And it will get better with regular sidewalls, which you'll find out if you go that route when it comes to replacement tires...But congrats on the purchase either way I'll remember your recommendation Thank you
