Removal Of Wiper Blade
Guys i need help on removing the wiper blades from a panda cross. I search the internet but every video i found which has this kind of wiper arm has a small clip to unlock the blade from the U hook. But this is bit different and i'm not sure how to unlock it. if anyone has experience please share how to unlock and remove it, that will be a really good help. I have attached two picture how the arm and blade look like since the arm cannot be lift 90 degrees.
post-45975-0-56716200-1463931369_thumb.j
post-45975-0-97634900-1463931391_thumb.j
Solved by GAPAUTO
try pulling/pushing towards driving side?
maybe this is the clip/hook you are looking for
Edited by fiatLife
  • Author
I tried to lift it but it doesn't seems to lift :(
try using a flat screw with mild pressure maybe
For me it seems like normal "U" hooked wiper arm. If you can show us other side of the connection much better.
  • Author
This is the underside of it, i tried lifting the top but it just comes out halfway and stop.
post-45975-0-10031200-1464362404_thumb.j
Edited by GAPAUTO
