February 11, 20179 yr The sensor which triggers the fan relay. and also clean the rad fins from any thing which may block the flow of air through it.
February 11, 20179 yr 7 hours ago, asanka_rg said: I met an auto electrical guy and check the fan. Fan is working in both speeds. then I checked the fan starting temp without ac. It's 98celcius (coolant temp). At that point the heat gauge is above the middle. is that fan starting temp is correct ? (thermostat temp rating was 82 celcius) ย what should I do as per the above readings. If you read the above figure (98 C) through OBD port then you may have a problem with the ECT sensor (I said "may" because on the other hand your gauge could be inaccurate). For all what I know the fan starts at 97.5C at slow speed and switches to high speed at 102.5C. If you read a figure of 98C through OBD port then your ECU is doingย its job by starting the fan at the right apparent temperature but by then if the gauge goes above half mark then actual coolant temperature may be a couple of degrees above 98C assumingย the gauge is correct. I hope you get what I mean here. Edited February 11, 20179 yr by Rumesh88
February 12, 20179 yr Author hi I changed the thermo switch (temp sensor). I drove up hill. Looks fine gauge is steady bit below the middle mark. ?? thanks everyone for giving me valuable comments on this. I'll update other thread regarding the vibration on drive with brake. ?
April 21, 20188 yr Having a similar kind of issue. Same car HT51S. First it started with random heat going maximum. I cleaned the radiator and filled new coolant. Problem was ok for about a month and my radiator fan died suddenly. (Maybe it overworked previously.) Replace and it was fine for a month. Then again around 1 month after I saw RPM meter varies as idle. I did a engine tuneup and OBD scan reveled issue with Camย sensor. (P0335) I replaced both Camย and Crank sensors. Again it was fine few days andย again it heated up. After letting it cool down I reached home without any issues. (Without AC that is as a precaution) Once home I checked and saw little coolant was missing. Guess through reservoir.. Could this be ECT sensor, Thermostat, Radiator cap or something else. Whats the correct way orย place to find out.ย
April 23, 20188 yr Having a similar kind of issue. Same car HT51S. First it started with random heat going maximum. I cleaned the radiator and filled new coolant. Problem was ok for about a month and my radiator fan died suddenly. (Maybe it overworked previously.) Replace and it was fine for a month. Then again around 1 month after I saw RPM meter varies as idle. I did a engine tuneup and OBD scan reveled issue with Camย sensor. (P0335) I replaced both Camย and Crank sensors. Again it was fine few days andย again it heated up. After letting it cool down I reached home without any issues. (Without AC that is as a precaution) Once home I checked and saw little coolant was missing. Guess through reservoir.. Could this be ECT sensor, Thermostat, Radiator cap or something else. Whats the correct way orย place to find out.ย Coolant missing means that its going into the coolant reserve and overflowing (or entering into the cylinder, worse case scenario). How certain are you that the fans are working properly? And do you see any coolant on the floor after you park the car?Go to a good garage and get them to do a bottle test and a pressure test, they will test for any leaks or head gasket damage.Also when your car overheats you should turn the ac on, not turn it off. Sure there is additional load but when the ac is on it makes sure that the radiator fans are on always [emoji16] Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
April 23, 20188 yr 9 hours ago, The Stig said: Coolant missing means that its going into the coolant reserve and overflowing (or entering into the cylinder, worse case scenario). How certain are you that the fans are working properly? And do you see any coolant on the floor after you park the car? Go to a good garage and get them to do a bottle test and a pressure test, they will test for any leaks or head gasket damage. Also when your car overheats you should turn the ac on, not turn it off. Sure there is additional load but when the ac is on it makes sure that the radiator fans are on always Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk ย Yesย its going into the coolant reserve and overflowing. There are coolant on engine and surrounding which were overflew.ย Fans I checked with the mechanic and they working as intended at correct speeds. Done bottle test and no bubble so they told gaskets are ok. And no leaks either.ย Sure next time will keep AC on. Thanks Stig. Update 2: So I went to new garage and unfolded the history. After initial checks they went straight for thermostat. It was faulty and opens only a little. Also showed signs of a previous seize. Checkedย water pump and it wasย squeegeeing when raotate from hand. Bothย needed to be replaced. Its getting fixed now. Will update with the progress soon.ย
April 24, 20188 yr How's the rad cap? was a compression leak test done? Edited April 24, 20188 yr by Twin Turbo
May 2, 20188 yr On 4/24/2018 at 7:59 AM, Twin Turbo said: How's the rad cap? was a compression leak test done? Radiator cap was in good shape. If you mean "compression leak test" is on radiator, yes done and was ok.ย
May 2, 20188 yr Update 3: Much better experience after Pump/Thermostat change. Although on a test ride in heavy traffic again heat went up and came down few times. Although the radiator was cleaned before the mechanic suggested to check again. Cleaned inside and outside along with AC condenser. So far seems the issue is ok now. After a journey I feel the car get less hot (engine compartment) now. With that again back to lower RPM issue, No problem as long as the vehicle is on the move. But when at complete stop the RPM goes below 700 and car starts a little vibrate. Not sure whether a ICV or TPSย issue.ย
July 22, 20188 yr Author On 5/2/2018 at 9:50 PM, SKAF said: Update 3: Much better experience after Pump/Thermostat change. Although on a test ride in heavy traffic again heat went up and came down few times. Although the radiator was cleaned before the mechanic suggested to check again. Cleaned inside and outside along with AC condenser. So far seems the issue is ok now. After a journey I feel the car get less hot (engine compartment) now. With that again back to lower RPM issue, No problem as long as the vehicle is on the move. But when at complete stop the RPM goes below 700 and car starts a little vibrate. Not sure whether a ICV or TPSย issue.ย Have you changed the coolant sensor?
August 22, 20188 yr On 7/22/2018 at 11:05 AM, asanka_rg said: Have you changed the coolant sensor? Nope. And the RPM issue fixed after a proper clean up in throttle body.ย
October 1, 20188 yr We had a similar issue with a FB-15, it started with loss ofย ย cold air with the AC in traffic and later the Radiator temp was rising also. After inspection, we found out that one of the two fans on the radiator was having a shotty connection after some water had got in to theย connector, it would sporadically not power up the fan but as the AC fan was running halfย of the time, and with the air blown in through the shell was temperatureย was somehow managed, but once the AC fan died, the last line of defenceย failed and it started over heating.ย ย
