Clark's son Posted April 24, 2017 Posted April 24, 2017 There is going to be a fuel station strike from today onwards What's the situation I needed to pump some diesel and have up the idea after seeing a que atleast 1km long. When is it going to end Any news will be helpful Thanks Quote
kush Posted April 25, 2017 Posted April 25, 2017 Ended yesterday they have commenced distribution, should be back to normal by today 25th evening. Quote
matroska Posted April 25, 2017 Posted April 25, 2017 yep; called off but anyway had it persisted for a few days - an empty tank in the car would have been the least of concerns Quote
Rumesh88 Posted April 25, 2017 Posted April 25, 2017 Decided to stay at home today. I did not want to queue up for hours and in the end put my luck to test. Quote
Luck Posted April 25, 2017 Posted April 25, 2017 2 hours ago, Rumesh88 said: Decided to stay at home today. I did not want to queue up for hours and in the end put my luck to test. Correct Quote
matroska Posted April 25, 2017 Posted April 25, 2017 (edited) 2 hours ago, Rumesh88 said: Decided to stay at home today. I did not want to queue up for hours and in the end put my luck to test. well there was less traffic today as well I had about 15 litres (more than enough for a few days) left BUT as a precautionary measure i tried activating thel-higanna mode ... basically just drove a bit smoother - amazing what mileage you can achieve when you put your mind to it ... Edited April 25, 2017 by matroska Quote
john cooper Posted April 26, 2017 Posted April 26, 2017 16 hours ago, matroska said: well there was less traffic today as well I had about 15 litres (more than enough for a few days) left BUT as a precautionary measure i tried activating thel-higanna mode ... basically just drove a bit smoother - amazing what mileage you can achieve when you put your mind to it ... Still the good old neutral gear to use at extreme situations. Quote
Iced-T Posted April 26, 2017 Posted April 26, 2017 I had to travel from Colombo to Negombo and back on Monday. Had a full tank of fuel but wanted to save as much as possible since there was no indication when the strike would be over. So I ran the car without aircon. One of the worst days of 2017... It was so hot! Quote
