Magnum Posted May 11, 2017 Share Posted May 11, 2017 Lets use this thread to share the automotive stuff we find on the internet. Videos, articles, pictures you found interesting or used to do any DIY work. I'll start off with few stuff. 2 Quote Link to comment Share on other sites More sharing options...
Magnum Posted May 11, 2017 Author Share Posted May 11, 2017 Lugging your engine I found this being done by many people to save fuel or just by being lazy to downshift. Quote Link to comment Share on other sites More sharing options...
Magnum Posted May 11, 2017 Author Share Posted May 11, 2017 6 Different Types Of Turbocharger And The Advantages Of Each Setup "What's the difference between single, twin, twin-scroll, variable geometry, or even electric turbochargers? What are the advantages of each setup" https://www.carthrottle.com/post/engineering-explained-6-different-types-of-turbocharger-and-the-advantages-of-each-setup/ 1 Quote Link to comment Share on other sites More sharing options...
Magnum Posted May 15, 2017 Author Share Posted May 15, 2017 Quote Link to comment Share on other sites More sharing options...
Magnum Posted May 15, 2017 Author Share Posted May 15, 2017 Pretty surprising results Quote Link to comment Share on other sites More sharing options...
Magnum Posted June 14, 2017 Author Share Posted June 14, 2017 (edited) In general terms, a wider tire has a greater contact patch with the ground, so can provide traction. The tread pattern/depth will have a lot to do with how the tire performs during inclement whether. Take for instance a race tire which is rated at a width of 325mm. this tire would provide excellent traction for the vehicle. And this would be true, unless the tire was driven on the street where there is water. The car would not have the traction needed to sustain type of safe operation. Take the same 325mm tire and place it on snow. You can expect a loss of traction. In fact, a skinnier tire will work better in snow than a wide tire would. The reason for this (I believe ... no empirical evidence) is because it has more weight per square inch due to the smaller contact patch. It also cuts through to the ground better instead of riding on top of compacted snow. There are other factors involved here as well. If a tire is made to last longer (say made of harder rubber), it may not have as good of traction as a tire of the same width and softer material. Tread patterns themselves have a play in traction. Side wall height, tire flex, and inflation also have a play in it. Another area to consider is what is the physical dimensions of a tire will you be able to fit under your vehicle? There is a trade-off here as well. Another trade-off is cost, the wider the tire, the more expensive it will be (all other things being equal). Unfortunately, there are so many variables when considering traction, you just cannot put a generalized statement upon a single given factor, which is width in your case. To provide the best tire for your application takes research, bringing all of the factors together to determine your best course. Edited June 14, 2017 by Magnum Quote Link to comment Share on other sites More sharing options...
Magnum Posted July 19, 2017 Author Share Posted July 19, 2017 Quote Link to comment Share on other sites More sharing options...
Magnum Posted November 22, 2017 Author Share Posted November 22, 2017 (edited) The first successful usage of common rail fuel injection system in a production vehicle began in Japan by the mid-1990s. Dr. Shohei Itoh and Masahiko Miyaki of the Denso Corporation, a Japanese automotive parts manufacturer, developed the common rail fuel system for heavy duty vehicles and turned it into practical use on their ECD-U2 common-rail system mounted on the Hino Ranger truck and sold for general use in 1995. Denso claims the first commercial high pressure common rail system in 1995. Edited November 22, 2017 by Magnum Quote Link to comment Share on other sites More sharing options...
ajm Posted November 22, 2017 Share Posted November 22, 2017 (edited) On 11/22/2017 at 4:06 AM, Magnum said: The first successful usage of common rail fuel injection system in a production vehicle began in Japan by the mid-1990s. Dr. Shohei Itoh and Masahiko Miyaki of the Denso Corporation Expand https://en.wikipedia.org/wiki/Common_rail "Modern common rail with electronic control for Passenger cars is an Italian invention taken over and developed for mass production by supplier Giant Bosch." Edited November 22, 2017 by ajm Quote Link to comment Share on other sites More sharing options...
Magnum Posted November 22, 2017 Author Share Posted November 22, 2017 (edited) On 11/22/2017 at 8:28 AM, ajm said: https://en.wikipedia.org/wiki/Common_rail "Modern common rail with electronic control for Passenger cars is an Italian invention taken over and developed for mass production by supplier Giant Bosch." Expand This refers to the modern common rail system with an ECU. While my post refers to the earlier one. Oops! Just noticed I used the wrong pic Edited November 22, 2017 by Magnum 1 Quote Link to comment Share on other sites More sharing options...
ajm Posted November 22, 2017 Share Posted November 22, 2017 The first mass-production passenger car with the common rail system used worldwide ubiquitously now was the Alfaromeo-JTD. The system was jointly developed by Bosch and Fiat group. Quote Link to comment Share on other sites More sharing options...
Magnum Posted December 21, 2017 Author Share Posted December 21, 2017 1 Quote Link to comment Share on other sites More sharing options...
SteveMayers Posted January 18, 2018 Share Posted January 18, 2018 DIY: How to rearrange 3 pin plugs for 9007/9004 HID kits. Quote Link to comment Share on other sites More sharing options...
DSF Posted January 30, 2018 Share Posted January 30, 2018 http://www.japantradecar.com/info/Fraud_Warning/Why_Is_Export_Certificate_Important.aspx Quote Link to comment Share on other sites More sharing options...
Magnum Posted January 31, 2018 Author Share Posted January 31, 2018 J.D Power Vehicle Dependability Study U.S Japan Germany 1 Quote Link to comment Share on other sites More sharing options...
Magnum Posted November 17, 2018 Author Share Posted November 17, 2018 Quote Link to comment Share on other sites More sharing options...
Magnum Posted December 18, 2018 Author Share Posted December 18, 2018 1 Quote Link to comment Share on other sites More sharing options...
BuBi Posted March 8, 2019 Share Posted March 8, 2019 https://www.youtube.com/watch?v=b9ztUlve9jc Quote Link to comment Share on other sites More sharing options...
Magnum Posted April 11, 2019 Author Share Posted April 11, 2019 The Drift King Story Keiichi Tsuchiya began racing at a young age as most great drivers do. As he was learning to drive he began experimenting with the side brake or E-brake lever. Sliding the back end of the car out and counter steering was fun and taught him the basics of car control. Unlike many great racecar drivers he did not go to a racing school or have a rich family that was into the racing scene that could nurture his racing talents. He just had the basic passion to drive. Driving through local mountain roads he began to build a sense of where a car needs to be at each turn to achieve maximum speed through a corner. This not being a safe and smart way of learning to race he never the less learned much from running (Touge) mountain pass roads. From time to time he found himself off a cliff with his KPGC10 Skyline or against the side of a wall. Having snow in the wintertime further trained him to drive well on loose surface conditions enhancing again his car control skill. The more he drove on these roads and conditions of various road surfaces he began to get comfortable with sliding the car through a corner. He started to drift not because it was a quicker way around a corner but it was the most exciting way. Enter the Drift King. Drifting a car through a corner is not the fastest way around most turns any racecar driver will tell you strait out. This is where Keiichi Tsuchiya was crowned the Dori Kin or Drift King. In Option drift contests; style and technique are evaluated for exhibition values. Lately contests have been judged on racing lines and setup for multiple corner drifting, this is more difficult. Back in 1977 Keiichi began his racing career driving many different cars in amateur racing series events. Racing these underpowered cars was difficult but again a great learning experience. Later Keiichi was picked up to drive the ADVAN sponsored AE86/1984 Corolla GT-S. During many races on a downhill corner he would drift the car and carry a better corner speed than his competitors. This technique is what made him the Drift King not as most believe that he was first in the drift scene. As he proved his style of driving his reputation grew. He is a racecar driver now and still takes to the mountains for illegal racing this also made his reputation grow. After videos featuring him and his persistent mountain running/Drifting his driver’s license was suspended! For a professional racecar driver this was embarrassing. Unknowingly this worked to his advantage, his fan base and fame began to expand. You could say that he is a rebel of some sort or because he was just a person who went from nowhere to success out of determination with no racing background. He still has a bond for an old car that he grew up racing, drifting, and winning with, the Toyota AE86. You can see this by his video series dedicated to this car that is called AE86 Club. Toyota itself also felt that he is the person to represent the car most and presented him a restored AE86 through TRD. (Keiichi as a young fellow would go to Fuji speedway to watch skylines duke it out building him a foundation to get into the racing scene). Driving History: Keiichi Tsuchiya Born January 1956 1977 Debut in Fuji Freshman series. 1977-1984 Ran selected entries in All Japan Touring Car championship. 1984 Fuji Freshman series race (Toyota AE86)= 6 wins 1985 All Japan Touring Car championship (Toyota AE86) 1st in Class 3 1986 Corolla Sprinter Cup-2 podium places 1987 All Japan Touring Car championship (Honda Civic)-1 win 1988 Toyota Cup-1st overall All Japan Touring Car championship (BMW M30)-3rd in Class 2 Macau Guia race (BMW M3)-4th overall 1989 All Japan F3 championship All Japan Touring Car championship (Ford Sierra Cosworth)-1 win 1990 All Japan Touring Car championship (Ford Sierra Cosworth) Macau Guia race (Ford Sierra Cosworth) New Zealand Touring Car series (Toyota) 1991 All Japan F3 championship (Ralt-Mugen)-10th overall All Japan Touring Car championship (Nissan Skyline GT-R)-5th overall 1992 All Japan Touring Car championship (Nissan Skyline GT-R) 1993 All Japan Touring Car championship (Taisan Nissan Skyline GT-R)-1 win Japan Endurance series (Honda Prelude)-2nd Tsukuba 12 Hours 1994 All Japan GT championship (Porsche 911T)-1 win All Japan Touring Car championship (Honda Civic) Suzuka 1000kms (Porsche 911T)-1st in class, 2nd overall Le Mans 24 Hours (Honda NSX)-18th overall 1995 All Japan GT championship (Porsche911TRSR) All Japan Touring Car championship (Honda Civic) Suzuka 1000kms (Honda NSX)-5th overall Tokachi 12 Hours (Honda NSX)-1st overall Le Mans 24 Hours (Honda NSX)-1st in class 1996 All Japan GT championship (Honda NSX)-13th overall Entered NASCAR Thunder Special race at Suzuka Le mans 24 Hours (Honda NSX)-3rd in class 1997 All Japan GT championship (Porsche 911/Dodge Viper) Fuji InterTec race (Toyota Chaser) Suzuka 1000kms (Lark McLaren F1 GTR)-9th overall Entered NASCAR Thunder Special race at Suzuka Le Mans 24 Hours (Lark McLaren F1 GTR)-qualified 10th, retired from race 1998 All Japan Touring Car championship (Toyota Chaser)-7th overall All Japan GT championship (Toyota Supra)-8th overall Le Mans 24 Hours (Toyota GT-One)-9th overall NASCAR at the California Speedway. 1999 Japan Touring Car Championship(Advan Altezza Touring car). 2000-2001 he joined team ARTA racing a NSX once again in the All Japan GT championship. http://fastdrifting.blogspot.com/2006/09/quotes-from-drift-king-keiichi.html Quote Link to comment Share on other sites More sharing options...
Magnum Posted April 12, 2019 Author Share Posted April 12, 2019 1 Quote Link to comment Share on other sites More sharing options...
LForward1 Posted July 22, 2019 Share Posted July 22, 2019 Thanks for sharing,such a nice topic Quote Link to comment Share on other sites More sharing options...
AVANTE Posted November 16, 2019 Share Posted November 16, 2019 (edited) I've noted lots of people who don't know the proper way to use an A/C during the summer. Here are some tips: https://carfromjapan.com/article/car-maintenance/tips-using-car-ac-hot-weather-efficiently/amp/ Edited November 16, 2019 by □AVANTE□ Quote Link to comment Share on other sites More sharing options...
loui Posted November 18, 2019 Share Posted November 18, 2019 16 Driving Hacks...... Best place to repir Cars Wyndham Auto Repairs Quote Link to comment Share on other sites More sharing options...
loui Posted November 18, 2019 Share Posted November 18, 2019 CLEAN YOUR CAR AT HOME.. STOP PAYING SERVICE STATIONS Stop Paying Service Stations Quote Link to comment Share on other sites More sharing options...
Roy K. Carroll Posted December 14, 2020 Share Posted December 14, 2020 I found this being done by many people to save fuel or just by being lazy to downshift. Quote Link to comment Share on other sites More sharing options...
