Hi all,
I have experienced considerable missfiring in cold start of my car swift 2003. I have done engine tune up about 3000km back. Now I can feel after starting the car after day or two car is having a hesitation. In D or R the missing is heavy. In p or N that is not much. Driving bit fix the issue. I haven't done a fuel filter cleaning or anything. Please give me some direction to fix the issue in proper way. Where should I start?
6 answers to this question
56 minutes ago, asanka_rg said:
Hi all,
When was the last time you changed Automatic Transmission Fluid?
Does the engine rev up above say, 1200 RPM at cold start? If it is "miss firing" I suggest you begin the diagnosis by inspecting the spark plugs for possible differences in color and/or deposits on the tip.
Start with checking the spark plugs, then check your coil packs. The reason you feel it more prominently on D & R is because of the load. Finally check your injectors, fuel pressure and petrol pump.
yes rpm is going like 1200 or 1300 and slowly getting around 700. Now the symptom is having in each start up even closer. Is it time to do a tune up ? Meanwhile I will see the spark plugs and injectors also. Fuel filter and pump too.
Was your EGR valve inspected and cleaned during the last tune up? If not I would do that first. Just blindly doing a tune up/clean up will not help in your case (because according to you the car runs normal once warmed up). When the plugs are removed for inspection make sure you identify the cylinder numbers and if two plugs,say 1 and 4 or 2 and 3 shows more deposits than the other two it could be a  sign of a bad coil pack shared by the respective plugs.
I got the issue fixed which was a leaky coil pack. there was a small hole in the coil tube. I found a used similar tube and fixed. problem goes away. thanks all for comments.
