This is just to share my experience related to the fuel efficiency of "Honda Grace", I've been using a Grace since 2017 normally it does 30KM/L when long run like A/Pura-Kandy, A/pura-Colombo. So far it has done 60K+ and average shown is 21+KM/L.
I've faced no Dual Clutch issue yet, and hope no in future.
  • 9 months later...
  • 2 years later...
I have a 2015 hinda grace and I have bren having an issur where the car goes into limp mode then overheats, I have changed the water pump twice as I was advised by the mechanic to do so but I stikk have the issue
Well, apart from just changing the water pump, did you do any actual diagnosis to see if the cooling system actually works? Is the radiator working fine? Are there no blocks in the water ducts? Are there no leaks? Does the fan come on and off as it is supposed to? Are the thermostat and other sensors working fine? Did you read the ECU for any error codes (which it should have since it goes into limp mode)?
