Aslam86 Posted January 2, 2018 Share Posted January 2, 2018 Does anybody know the name or part number for the following part? It is a hose connecting the air filter compartment and the engine. I have highlighted the part in RED. Quote Link to comment Share on other sites More sharing options...
MV-5 Posted January 2, 2018 Share Posted January 2, 2018 i know nothing about this engine setup. but at a glance this should be the breather pipe(hose). 1 Quote Link to comment Share on other sites More sharing options...
Rumesh88 Posted January 2, 2018 Share Posted January 2, 2018 What's wrong with the breather hose? It is just an ordinary straight piece of pipe. If you cannot find the original part you can use a similar hose cut to size instead. Quote Link to comment Share on other sites More sharing options...
MV-5 Posted January 2, 2018 Share Posted January 2, 2018 seems some coolant line goes around the middle of the hose. so probably there might be a internal metal tube (just only in the middle of the hose). if it is the case try to go for a original part, otherwise as Ramesh said no harm to go with a similar hose. I think this heating mechanism has no real benefit in a country like SL. Quote Link to comment Share on other sites More sharing options...
Aslam86 Posted January 6, 2018 Author Share Posted January 6, 2018 On 1/2/2018 at 3:52 PM, Rumesh88 said: What's wrong with the breather hose? It is just an ordinary straight piece of pipe. If you cannot find the original part you can use a similar hose cut to size instead. Expand Currently is broken and is tapped. Checked with Stafford while doing a service and they didn't have it. On 1/2/2018 at 5:11 PM, MV-5 said: seems some coolant line goes around the middle of the hose. so probably there might be a internal metal tube (just only in the middle of the hose). if it is the case try to go for a original part, otherwise as Ramesh said no harm to go with a similar hose. I think this heating mechanism has no real benefit in a country like SL. Expand It looked like a plain hose. Quote Link to comment Share on other sites More sharing options...
PRAGIN Posted January 7, 2018 Share Posted January 7, 2018 Its just a rubber pipe. If you want the Part number is 17153-PNA-010. Quote Link to comment Share on other sites More sharing options...
