i am interested in installing a HID headlamp for my demio 2009. Can someone pinpoint me a location to buy in SL?
This is going to be a bit difficult to source due to the fact that only the fully loaded ones came with HID. Try your luck at Delkanda and other recon parts shops such as EuroNipp0n and US C@r P@rts.
Thanks Davy. May I also know if there are any cons in installing a hid headlamp? Will there be unnecessary stress on the electrical system?
No, there shouldn't be any issues. Especially if you're thinking of simply dropping in a pair of Demio HID headlamps. Even if you install an aftermarket kit, you should be fine if it's done properly. Xenon lamps consume less power and emits less heat compared to halogen.
