toyota vitz 2017 model vibration issues
I have noticed a slight vibration in my toyota vitz 2017 model 1000cc car when car is in "D" or "R".same time I noticed a vibration from dash board as well. is it normal for toyota vitz?if it is a problem what is the solution for the matter?
4 answers to this question
Thanks for your reply. That thread does not provide a good answer for my vehicle issue. My one is 2017 model one and it vibrates when car is stopped in d and r mode. At the same time steering wheel side dash board part starts to vibrate and when i shift the gear to N both vehicle vubration and dash board vubration sound reduces gradually.
I understood that vibration is a commen issue in 3cylinder engines. But what i want to know is whether this vibration issue causes the vibartion/rattling noise in dash board when car is stopped in d mode or  r mode.
If it is not normal how to resolve the matter
have you tried switching off the AC while the car is vibrating? that way, may be you can identify if it has got a faulty idle up sensor? (I'm just guessing from a previous experience I had). If the vibration is not there in the N mode it might not be the engine mount no? some issue with the transmission system like gearbox mounts? Best bet is to get it inspected by a qualified mechanic ?‍♂️
Edited by ghostwriter
