Smart key for toyota allion
I have damaged my toyota aliion smart key housing. Does anyone knows where to buy a key housing. Its really expensive at Toyota lanka.
Regards,
Sajith
I have brought on for Toyota Prius from place called Rex....ย Motors at Colombo. You can search its advertisement at ik...... website as smart key.ย cost is Rs.4500. But i thinkย its also too expensive for just for plastic housing.
  • Author
Yup. Found a place in Piliyandala, it cost 4500.
11 hours ago, AutoFocus said:
Having original replacement from the agent is really worth it.ย
There are things that are worth going to the agent for. This is certainty not one of them. It's just a small piece of plastic that houses the key fob.ย
  • Author
5 hours ago, Davy said:
There are things that are worth going to the agent for. This is certainty not one of them. It's just a small piece of plastic that houses the key fob.ย  ๏ปฟ๏ปฟ๏ปฟ๏ปฟ
Agreed, agent will charge around 40K for the key, I assume they will still charge insane amount for the plastic. Ebay search does not give me anything similar to my existing key. May be I should go with the local key repair man for 4500.
Thanks for all the replies.
Sajith
Sajith
$_12.JPG?set_id=880000500F
Is this the key type? If so starting from $7 but don't know about the quality.ย
  • Author
Is this the key type? If so starting from $7๏ปฟ๏ปฟ but don't know about the quality.ย
Yup, thats the key. Finally found it in ebay, 9$. Saw your post bit late. Too bad.
Sajith
