Ash123 Posted October 12, 2018 Share Posted October 12, 2018 Hi All, need advice I have aqua 2015, when I am pressing the break pedal kind of grinding noise coming from ECS area. This noise keep coming even driving (every time when pressing the brake) Someone told me this may be ABS break module issue. But there is no any issue with breaking system or any ABS alarm on screen. To make sure everything O.K I did scanning my car with local hybrid service place and found nothing wrong and all found in order. Has anyone come across this kind of issue please advice? I am planing to take my car to Edirisighe Hybrid hub for another inspection? Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted October 12, 2018 Share Posted October 12, 2018 HI, STOP DRIVING ! get the wheels removed and brakes checked .. before you loose control of the car. Quote Link to comment Share on other sites More sharing options...
Nishan.dj Posted October 15, 2018 Share Posted October 15, 2018 General question here is that does Aqua has break pads? What if they are worn out? @Twin Turbo Quote Link to comment Share on other sites More sharing options...
vag2 Posted October 15, 2018 Share Posted October 15, 2018 is it coming from the wheels or the Motor Generator? Most of the braking happens in the Motor Generator, brake pads are very seldom used and even can have rust built-up on rotors as a result of non-usage. Quote Link to comment Share on other sites More sharing options...
Magnum Posted October 15, 2018 Share Posted October 15, 2018 Did you drive through muddy or sandy roads? Sometimes dirt gets in between the pads and the disk. Quote Link to comment Share on other sites More sharing options...
tilvin Posted October 15, 2018 Share Posted October 15, 2018 Change new original brake pads and see the difference....?. Seems brake pads are worn. Quote Link to comment Share on other sites More sharing options...
vag2 Posted October 15, 2018 Share Posted October 15, 2018 On 10/15/2018 at 10:29 AM, tilvin said: Seems brake pads are worn. Expand hmm, shouldnt the Car have a dashboard indicator which shows if brake pads are worn? Quote Link to comment Share on other sites More sharing options...
gayanath Posted October 16, 2018 Share Posted October 16, 2018 Fully wearing of the brake pad is highly unlikely of a 2015 Aqua otherwise it has done at-least 150,000 km or severe issue in break system. Car millage? Usage under your ownership? Is it depend on the braking style? I mean, 1. any difference with sudden brake and gradual braking? 2. any noise when you release the brake? 1 Quote Link to comment Share on other sites More sharing options...
