4 answers to this question
The new tyre will give the overall wheel a larger diameter than stock, which will:
- Slightly increase ride height (by about 6mm)
- Cause the speedometer to indicate slightly lower than the correct speed (by a negligible amount)
The best alternative would be 195/65/15 or 185/60/15 which might be hard to find.
Go to the below website, type in the two tyre sizes and check for yourself:
https://tiresize.com/comparison/
Why do you want to upsize anyway?
Edited by Davy
Garage owner told me will have less ground clearance issues. I wonder whether there is any fuel saving in the long run.
Well the additional clearance you're going to get is 6mm as I've mentioned above.
Fuel saving, no. The replacement tyre is 10mm wider than stock, which will contribute to the tyre footprint being larger on all corners and thereby cause a bit more drag than stock while improving handling (and looks) of the car.
  • Thanks 1
Did you search the forum ? There was a old thread which discussed about same thing. (I will find it for you when get a free time).
P.S : Here are some threads
Edited by kusumsiri
Added links
  • Thanks 1
