Honda Civic Sedan 2019
If you go to nity pick on how they open the door, close the bonnet, wash the car there is no place in Sri Lanka that will satisfy you. In my case I leave the car if it is agent and check the car at the time of collecting. Usually they inspect the car before taking over (not Stafford) and any damages are noted.
If the car is not on warranty, I don't go to the agent I stay with the car and get specific things like oil change, brake check done through a friendly garage or service. Do the washing and vacuum at home.
I don't get the point of all this fuss when your car is exposed to three / two wheeler and morons at the parking lot.
Most of my dings and scrapes happened when the car was parked.
12 hours ago, kush said:
If you go to nity pick on how they open the๏ปฟ door, close the bonnet, wash the car there is no place in Sri Lanka that will satisfy you.
How did UNIMO do back when you owned the Lancer? I've been taking mine to their Katugasthota and Kurunegala branches, they've been exceptionally careful when handling the car (I still do the washing and vaccuming myself though)
Edited by Hyaenidae
I took it to Orugodawatte, they were ok and at least listened to my requests like not to wash the engine. (they wiped with a wet cloth to get dust off from the visible areas).
What i liked about them is you could see what was going on.
Same with Kia but they take ages so I left the car at their care, as it was a Picanto used for the school run and on a 5 year warranty with them did not bother.
  • 1 year later...
Guys, I'm seeking advice for my Honda Civic Sedan EX 2018 AC issue.
This year Jan, found AC is not working and cannot feel the cool. after show it to Maheshย motors Makola,ย ย I refilled the gas and AC back to normal.ย again last month found same issue.ย
I have seen this model having this AC issue. Is there any solution ?ย
Most probably your AC condenser is leaking which is the root cause for the AC issue in the new Civic.. you will have to replace the AC condenser and then refill the gas.. it will cost you around 70k I guess.. this was discussed in the other Civic 10th generation thread in detail by @misnadย and others, you can refer that for more info..
Thank you Dee jay for your advice & it's encouraged me to google on this issue. further my car is not running due to I'm out of country. it's just weekly engine starting for 30 mins.
Found this Civic famous condenser failure news forย ย 2016-2018 Civics and some vehicles it will cover under warranty.
https://www.carcomplaints.com/news/2019/honda-civic-air-conditioner-lawsuit-condenser.shtml
https://static.nhtsa.gov/odi/tsbs/2019/MC-10163796-0001.pdf
Edited by Damien79
add more info
