rpm problem
upalranku
  On 4/17/2019 at 8:23 AM, upalranku said:
my allion 2013 cars rpm goes very low and car start vibrating when it is in idle, (N). but when it starts first time in morning it works fine. what may be the problem
What is the RPM you see when it start Vibrating. Did you do a Tuneup recently ?
Yes it may be due to battery replacement as well. Why dont you remove the battery terminal for about 10mins and re-plug it. 'Normally if you remove the battery and put it back the RPM goes high according to my past experience.
In normally these vehicles should have 600 - 750 RPM at idle, depending up on whether AC clutch is engaged or not.
Anyway if you have not done the Tuneup recently, better try a Tune up too.
Do you see the Check Engine light on while the Engine is running ?
  On 4/17/2019 at 11:32 AM, hrm said:
Then drive for 100km or so and see. Maybe ecu got reset due to battery replacement and need some relearning to get things normal.
Agree. If this started happening immediately after battery replacement, it's probably because the ECU was reset. Driving a few kms in mixed conditions (with AC on) should allow time for the ECU to re learn.
engine light off
